Please check my partial diferentiation
  • MHB
  • Thread starter aruwin
  • Tags
    Partial
In summary, the conversation discusses the incorrect use of the quotient rule in calculating the partial derivatives of a function. The correct application of the product rule is demonstrated and the correct answer of 0 is obtained. The conversation ends with the individual expressing gratitude for the help.
aruwin
208
I have calculated 3 times and I still don't get the answer. The answer should be 0.
Here's the question and my work. Which part am I wrong?f(x,y) = 1/√(1-2xy+y^2)
Prove that ∂/∂x{(1-x^2)*∂f/∂x} + ∂/∂y{(y^2)*∂f/∂y} = 0
Hi aruwin, :)
You have used the quotient rule incorrectly when calculating, \(\displaystyle\frac{\partial}{\partial x}\left[\frac{y(1-x^2)}{(1-2xy+y^2)^{\frac{3}{2}}}\right]\mbox{ and }\frac{\partial}{\partial y}\left[\frac{(x-y)y^2}{(1-2xy+y^2)^{\frac{3}{2}}}\right]\).
Kind Regards,
Sudharaka
Sudharaka said:
Hi aruwin, :)
Kind Regards,
Sudharaka
Oh my gosh, yes. I have found what is wrong :)
Let's try using the product rule: $$ \frac{\partial}{\partial x} \left[ (y-x^2y)(1-2xy+y^2)^{-\frac{3}{2}} \right] $$ $$= (-2xy)(1-2xy+y^2)^{-\frac{3}{2}} + (y-x^2y)\left( - \frac{3}{2} \right) (-2y) (1-2xy+y^2)^{-\frac{5}{2}}$$ $$= \frac{(-2xy)(1-2xy+y^2) + (y-x^2y)(3y)}{(1-2xy+y^2)^{\frac{5}{2}}} $$ $$= \frac{-2xy+4x^2y^2-2xy^3+3y^2-3x^2y^2}{(1-2xy+y^2)^{\frac{5}{2}}}$$ $$= \frac{-2xy+3y^2-2xy^3+x^2y^2}{(1-2xy+y^2)^{\frac{5}{2}}}.$$ Hope it helps.
Thanks,guys!I have solved this question :)
FAQ: Please check my partial diferentiation
What is partial differentiation?
Partial differentiation is a mathematical tool used to calculate the rate of change of a function with respect to one of its independent variables, while holding all other variables constant.
Why is partial differentiation important?
Partial differentiation is important because it allows us to analyze how a function changes as one variable changes, while keeping other variables constant. This is useful in many fields such as physics, economics, and engineering.
How is partial differentiation different from regular differentiation?
Partial differentiation is different from regular differentiation in that it involves taking the derivative of a function with respect to one variable, while treating all other variables as constants. Regular differentiation, on the other hand, involves taking the derivative of a function with respect to one variable, while assuming all other variables are constant.
What are some real-world applications of partial differentiation?
Partial differentiation has many applications in the real world. For example, it is used in economics to analyze how changes in one variable, such as price, affect other variables, such as demand. It is also used in physics to calculate rates of change in complex systems.
How can I improve my understanding of partial differentiation?
To improve your understanding of partial differentiation, it is important to practice solving problems and working through examples. You can also read textbooks and watch online tutorials to gain a deeper understanding of the concept and its applications. Additionally, seeking help from a tutor or instructor can also be beneficial.
