Please could you checkif i got the 2d collisions right?
In summary: No problem, happy to help! Just make sure to double check your calculations and approach, and don't hesitate to ask for clarification if needed. Good luck!
lioric
306
A 0.30 kg puck A, initially at rest on a frictionless horizontal surface, is struck by a 0.20 kg puck B
that is initially moving along the x-axis with a velocity of 2.0 m/s. After the collision, the 0.20
kg puck has a speed of 1.0 m/s at an angle of θ = 530 to the positive x-axis.
a) Determine the velocity of the 0.30 kg puck after the collision.
total mommentum before collision + total momentum after collision
total momentum before collision in x
puck A
0.2 x 2 = 0.4
puck B
0.3 x 0
total = 0.7kgm/s
total momentum before collision in y = 0 for all
Total momentum after collision x
puck A
0.2 x 1 x cos 53=0.12
puck B
0.3 x V x cos 53
Total =0.7kgm/s
Total momentum after collision y
puck A
0.2 x 1 sin 53 = 0.1597
puck B
0.3 x V x sin53
Total =0
Resolve in x for puck B
0.3 x V x cos 53
Let Vcos 53 = Vx
0.3 x Vx + 0.12 = 0.7
Vx = 1.93333m/s
Resolve in y for puck B
0.3 x V x sin 53
Let Vsin 53 = Vy
0.3 x Vy + 0.1597 = 0
Vy = -0.53
V2=Vx2 + Vy2
V2 = 1.933332+(-0.53)2
V=√4.02
v=2.005m/s
Is this right?
puck A
0.2 x 2 = 0.4
puck B
0.3 x 0 = ?
total = 0.7kgm/s not correct
puck A
puck B
0.3 x V x cos 53 why do you think this mass is heading off at this angle?
Total =0.7kgm/s incorrect total remember
puck A
puck B
0.3 x V x sin53 might not be 53
Total =0
0.3 x V x cos 53
Let Vcos 53 = Vx
Vx = 1.93333m/s
0.3 x V x sin 53
Let Vsin 53 = Vy
Vy = -0.53
V2=Vx2 + Vy2
V=√4.02
v=2.005m/s
Is this right?
Probably not correct - see red above.
actually i knew there was something wrong
I did all of this all again since the pc froze.
previously i got it right
i knew there was a glitch since the answers looked different.
puck A
0.2 x 2 = 0.4
puck B
0.3 x 0 = 0
total = 0.4kgm/s
puck A
puck B
0.3 x V x cos θ
Total =0.4kgm/s
puck A
puck B
0.3 x V x sinθ
Total =0
0.3 x V x cos θ
Let Vcos θ = Vx
0.3 x Vx + 0.12 = 0.4
Vx = 0.93333m/s
0.3 x V x sin θ
Let Vsin θ = Vy
Vy = -0.53
V2=Vx2 + Vy2
V2 = 0.933332+(-0.53)2
V=√0.5902
v=0.768m/s
is this better?
puck A
0.2 x 2 = 0.4
puck B
0.3 x 0 = 0
total = 0.4kgm/s total momentum before collision in y = 0 for all
puck A
puck B
0.3 x V x cos θ
Total =0.4kgm/s
puck A
puck B
0.3 x V x sinθ
Total =0
0.3 x V x cos θ
Let Vcos θ = Vx
Vx = 0.93333m/s
0.3 x V x sin θ
Let Vsin θ = Vy
Vy = -0.53
V2=Vx2 + Vy2
V=√0.5902
v=0.768m/sis this better?
I don't expect it to be, from the way you calculated.
Step 1: calculate initial momentum. check you have done that.
Step 2: calculate components of final momentum of the block you have been given. Check you did that.
Step 3: deduce the components of the momentum of the other block. - Not the way you did.
Step 4: Add those components (as vectors) to find the actual momentum of that other block.
Step 5: Calculate the velocity of that block.
eg: I am about to randomly select some values for example - so as not to solve your actual question for you.
Let's pretend the the momentum of the incoming block was 5 units in the x direction.
Lets also assume that the components after collision were 3.5 in the x direction, and 1.5 in the y direction.
The components of MOMENTUM of the other block would be
1.5 in the x direction [since 1.5 + 3.5 = 5; the original value was 5]
-1.5 in the y direction [since 1.5 + -1.5 = 0; the original value was 0]
So the net momentum = 1.5√2 at 45 degrees
Given the second mass was 0.3 kg, that meant the velocity must have been 5 m/s at an angle of 45 degrees with the positive x-axis.
Note: I chose values that were very easy to work with - even to havng equal components so I could make use of the 1,1,√2 Pythagorean triangle.
I expect your values to be a bit more messy
Note: the use of an angle of 53 degrees usually implies to use sin and cosine values of 0.8 and 0.6 rather that the complicated/inconvenient, accurate figures, as the angles in a 3,4,5 Pythagorean are just over 53 degrees and just under 37 degrees.NOTE ALSO: there is a possibility that when you have found the final answer using momentum conservation, it may be inconsistent with kinetic energy calculations [there may appear to be an increase in total kinetic energy] The problem was that the question setter may have just chosen the speed and angle of the 0.2 kg mass unwisely.
thank you very much that was very detail
Related to Please could you checkif i got the 2d collisions right?
1. How do you know if a 2d collision is correct?
To determine if a 2d collision is correct, you need to consider the conservation of energy and momentum. This means that the total energy and momentum of the system before and after the collision should be the same.
2. What are the different types of 2d collisions?
The two main types of 2d collisions are elastic and inelastic collisions. In an elastic collision, the total kinetic energy of the system is conserved, while in an inelastic collision, some energy is lost due to deformation or other factors.
3. How do you calculate the velocity of objects after a 2d collision?
The velocity of objects after a 2d collision can be calculated using the equations of conservation of momentum and conservation of energy. These equations take into account the masses and velocities of the objects before and after the collision.
4. Can a 2d collision be perfectly elastic?
Yes, a 2d collision can be perfectly elastic if there is no loss of kinetic energy during the collision. This means that the objects involved in the collision bounce off each other without any loss of energy.
5. What factors can affect the outcome of a 2d collision?
The outcome of a 2d collision can be affected by various factors such as the masses, velocities, and angles of the objects involved, as well as external forces like friction. The type of collision (elastic or inelastic) also plays a significant role in determining the outcome.
