Please explain how can this be parrallel?
  • Thread starter uniquesoljuh
  • Tags
    Explain
In summary, the conversation discusses how to determine the total resistance in a circuit when resistors are in parallel. The participants also mention the use of a formula and the potential for circuits to be drawn in a confusing manner. They also provide a definition for parallel resistors and use an example to illustrate it.
uniquesoljuh
In this circuit, please tell me how they got the 4 ohms and the 12 ohms in parrallel when they look like they are in series
Please help me i am so desperate for an answer!
  • New Microsoft Office Word Document.pdf
What definition of "parallel" are you using?
As in resistors are in parrallel and they use the formula 1/Req= 1/R1+...Lewando trust me its very confusing
I know that circuits can be drawn to confuse intentionally-- the trick is to spot when this is happening. When resistors are "in parallel" they don't need to be drawn both vertically or horizontally-- as in your case they are drawn perpendicularly. But you should realize that you can redraw the circuit so they are literally parallel without changing any functional aspect of the circuit.
How about this unofficial definition: if there are 2 nodes, A and B with one resistor between them, then you place yet another resistor between them, those two resistors are "in parallel".
Your example shows exactly that.
In this circuit, the 4 ohm and 12 ohm resistors are considered to be in parallel because they are connected to the same two nodes or points in the circuit. This means that the current flowing through the 4 ohm resistor is the same as the current flowing through the 12 ohm resistor. In parallel circuits, the voltage across each resistor is also the same.
To calculate the equivalent resistance of parallel resistors, you can use the formula 1/Req = 1/R1 + 1/R2 + ... + 1/Rn, where Req is the equivalent resistance and R1, R2, etc. are the individual resistances in parallel. In this case, the equivalent resistance would be 3 ohms, since 1/Req = 1/4 + 1/12 and solving for Req gives us 3 ohms.
This means that the total resistance in the circuit is equivalent to having a single 3 ohm resistor. This can be seen as the current flowing through the 4 ohm resistor splits into two paths, one going through the 12 ohm resistor and the other going through the 3 ohm equivalent resistance. This is why we can say that the 4 ohm and 12 ohm resistors are in parallel, even though they may physically appear to be in series.
I hope this explanation helps to clarify how parallel resistors can be present in a circuit even when they may not seem to be in parallel at first glance. Remember, in parallel circuits, the current through each resistor is the same, while in series circuits, the current through each resistor adds up to the total current in the circuit.
FAQ: Please explain how can this be parrallel?
What does it mean for something to be parallel?
Parallel refers to two or more lines or objects that are always the same distance apart and never intersect. In other words, they are always moving in the same direction and will never cross paths.
How do you determine if two lines are parallel?
To determine if two lines are parallel, you can use a ruler or a measuring tool to see if they are always the same distance apart. You can also compare the slopes of the two lines - if they are equal, then they are parallel.
Can curves or circles be parallel?
No, curves or circles cannot be parallel because they do not have a consistent distance between them at all points. Parallel lines must be straight and have a constant distance between them.
Why is it important to understand parallel lines?
Understanding parallel lines is important in many fields, such as geometry, engineering, and architecture. It allows us to accurately measure and construct objects, as well as understand the relationships between different lines and shapes.
What are some real-life examples of parallel lines?
Some examples of parallel lines in everyday life include railroad tracks, the stripes on a road, and the lines on a ruled paper. In nature, rows of trees or crop fields can also be parallel lines.
