Please explain Taylor expansion in radiation.
In summary: The reason for using this particular form for the Taylor expansion is because it allows for easier manipulation and simplification of the equations. By choosing x_0 to be t-r/c and x to be (r' dot r)/c, we are essentially changing the independent variable from t to (r' dot r)/c. This makes the equations simpler and more manageable, and also allows for easier comparisons and analysis. Additionally, this choice of x_0 and x is specific to the problem at hand (finding the retarded scalar potential of an arbitrary source around the origin), and using this form allows for a more intuitive and direct approach to solving the problem.
yungman
5,755
293
For retarded scalar potential of arbigtrary source around origin:
[tex]V(\vec r, t) = \frac 1 {4\pi\epsilon_0}\int \frac { \rho(\vec r\;',t-\frac {\eta}{c}) }{\eta} d\;\tau' \;\hbox { where }\;\eta =\sqrt{r^2 + r'^2 - 2 \vec r \cdot \vec r\;' }[/tex]
Where [itex]\;\vec r \;[/itex] point to the field point where V is measured. And [itex]\;\vec r\;' \;[/itex] points to the source point.
For [itex]\;\vec r\;' \;[/itex] << [itex]\;\vec r \;[/itex]:
[tex] \eta \approx \; r- \hat r \cdot \vec r\;' \Rightarrow \rho(\vec r\;',\;t-\frac {\eta}{c}) \approx \rho (\vec r\;',\;t-\frac {r}{c} + \frac {\vec r \cdot \vec r\;'}{c}) [/tex]
This next step is where I don't understand how the book do the Taylor expansion. I am going to type the exact word from the book:
Expanding [itex]\rho \;[/itex] as a Taylor series in t about the retarded time at the origin,
[tex]t_0=t-\frac r c [/tex]
We have
[tex]\rho(\vec r\;',\;t-\frac {\eta}{c}) \approx \rho (\vec r\;',\; t_0) + \dot{\rho} (\vec r\;',\; t_0)\left ( \frac {\vec r \cdot \vec r\;'}{c}\right ) + \frac 1 {2!} \ddot{\rho} \left ( \frac {\vec r \cdot \vec r\;'}{c}\right )^2 + \frac 1 {3!} \rho^{...}_{ } \left ( \frac {\vec r \cdot \vec r\;'}{c}\right )^3 ...[/tex]
Why are they use [itex]\left ( \frac {\vec r \cdot \vec r\;'}{c}\right )\;[/itex] as x for the expansion. I just don't follow this. Please help.
thanks
Alan
Science news on Phys.org
What step don't you understand?
You have some function f(x) that you wish to do the Taylor's expansion about the point x_0, hence you wish to approximate f(x+x_0) for small values of x << 1.
So, if we choose r' << r, then:
[tex] x+x_0 \approx t-\frac{r}{c}+\frac{\mathbf{r}'\cdot\mathbf{r}}{c} [/tex]
We choose x_0 to be t-r/c and x to be r' dot r/c and do our Taylor's expansion about our x.
I don't understand why it is in power of [itex] \frac {\vec r-\vec r\;'}{c}[/itex]. How does this fit into x-x0?
The Taylor's expansion of f(x) about zero is the Maclaurin Series.
[tex] f(x) \approx f(0) + f'(0)x + 0.5f''(0)x^2 + \dots [/tex]
If we want to expand about some point x_0 then
[tex] f(x_0+x) \approx f(x_0) + f'(x_0)x + \dots[/tex]
Or something like that. So it seems that the author desires to do a Taylor's expansion of the charge distribution about the retarded time at the origin, t_0. That is, he is expanding the charge about the charge picture as time progressed at the origin where the charges are clustered. So you can think of \rho(r', t_0) as the charge distribution that occurred if the charges about the origin instantly communicated their information to the origin.
So if t-r/c is our x_0, then our x is r' \cdot r/c. So we expand out in powers of r' \cdot r/c.
Again thanks for your time. I thought Taylor expansion is:
[tex]f(x)\approx f(x_0)+f'(a)(x-a) +\frac { f''(x_0)(x-x_0)^2 }{2!} +...\frac { fn(x_0)(x-x_0)^n }{n!}...[/tex]
In this case, it should be x=t and [itex]x_0=\frac r c -\frac {\vec r-\vec r\;'}{c}[/itex] so the Taylor expansion should be:
[tex]f(t)\approx f(\frac r c -\frac {\vec r-\vec r\;' } c )+f' (\frac r c -\frac {\vec r-\vec r\;'} c)( t-\frac r c -\frac {\vec r-\vec r\;'} c) +
\frac { f''(\frac r c -\frac {\vec r-\vec r\;'} c)( t-\frac r c + \frac {\vec r-\vec r\;'} c )^2 }{2!} +...\frac { f^n(\frac r c -\frac {\vec r-\vec r\;'} c)( t-\frac r c +\frac {\vec r-\vec r\;'} c )^n }{n!}...[/tex]But the book use [itex] t_0=t-\frac r c [/itex] this mean the independent variable is [itex]\frac {\vec r-\vec r\;'} c[/itex]
[tex]\Rightarrow f'(t)\;=\; \frac {d (f(\frac {\vec r-\vec r\;'} c)}{d(\frac {\vec r-\vec r\;'} c)} \;\hbox { also}\; \frac {\vec r-\vec r\;'} c \;\hbox { is a constant at the given source and field point location!}[/tex]
I understand how the book come up with this, it is just:
[tex] x_0=t-\frac r c \;\;\hbox { and };\; x=\frac {\vec r-\vec r\;' } c [/tex]
The question is why!
Anyone please?
FAQ: Please explain Taylor expansion in radiation.
What is Taylor expansion in radiation?
Taylor expansion in radiation is a mathematical technique used to approximate the behavior of a function based on its derivatives at a specific point. It is commonly used in physics and engineering to understand the behavior of radiation.
How is Taylor expansion used in radiation?
Taylor expansion is used in radiation to approximate the behavior of a function, such as the intensity of radiation, at a specific point. This allows scientists to make predictions and understand the behavior of radiation in various scenarios.
What are the benefits of using Taylor expansion in radiation?
Using Taylor expansion in radiation allows for a more accurate understanding of the behavior of radiation in different scenarios. It also provides a way to make predictions and analyze the effects of changing variables on the intensity of radiation.
What is the formula for Taylor expansion in radiation?
The formula for Taylor expansion in radiation is: f(x) = f(a) + f'(a)(x-a) + f''(a)(x-a)^2/2! + f'''(a)(x-a)^3/3! + ... + f^n(a)(x-a)^n/n!, where f(x) is the function, a is the point of expansion, and n is the number of terms in the expansion.
Are there any limitations to using Taylor expansion in radiation?
While Taylor expansion is a useful tool in understanding the behavior of radiation, it is limited in its accuracy when the function is highly nonlinear or the point of expansion is far from the behavior of the function. In these cases, other mathematical techniques may be more suitable.
