Please guide me to recharge a battery
  • Thread starter Student12
  • Tags
    Battery
In summary: Not a good thing. Why did you not use the trick with the series light bulb?- It would be good to know the exact type of the...The battery is a lead-acid type and the adapter is not specifically made for charging it. The adapter is 12 volts at 2A max output.The battery is a lead-acid type and the adapter is not specifically made for charging it.The battery is a lead-acid type and the adapter is not specifically made for charging it.The battery is a lead-acid type and the adapter is not specifically made for charging it.In summary, the battery is damaged and it may not be possible to charge it.
Student12
Hi Guys. I am trying to charge my scooter's battery which is : 12 volts 2.3ah
The battery currently has around 3 volts.
I am charging it with an adapter : 12 volts 2.0ah
Can you help me how long would it take to charge and is it safe for me..
Thanks.
Thanks.
Welcome to the PF. :smile:
That sounds like the battery is pretty badly discharged. What type is it? Lead-acid?
Is your adapter made specifically for charging this type of battery? Are you certain it says "12 volts 2.0ah"? More likely it says 12V at 2A max output?
Likes Student12
BTW, beyond any safety issues, recharging a 12V lead-acid battery with a 12V source will not give you a very full charge.
Likes AlexCaledin
If the battery is only showing 3 volts measured at the terminals then it's almost completely flat.
How long it will take to charge will depend on the exact type of battery and what condition it is in.
You should be safe with a 12v charger regulated to deliver 2 amps.
Never ever consider charging with higher voltage or unregulated adapter in an attempt to get it charged faster.
Likes Stavros Kiri
Actually I believe the recommended charge time for a flat battery is something like 12 hours, so that a current of 0.2 amps would be ideal. 2 A seems a bit fast. If using 2A then do not exceed the charge time of about 1 hour.
Likes Stavros Kiri
Yes its a lead battery and the adapter is not specified for charging i m using it on my own and it say its 12v 2a...
tech99's warning is a good one. For such a flat battery, charging it at full speed does not seem wise...
Likes Stavros Kiri
Use the charger supplied with the scooter.
My scooter is on petrol its battery generator is dead i believe so..
I suggest putting a small bulb rated at about 12v 0.2 Amps in series and then charging for about 12 hours.
Likes NTL2009, Stavros Kiri and berkeman
A 12V lead-acid battery that has discharged to 3 volts is very likely failed. Even dropping below ~ 10.2 V for a short time does some damage to the plates. But attempt a charge and hopefully you will get some life out of it. The series light bulb is a good idea - it will limit current and protect your power supply and the battery.
Why is it so low? Did it just sit unused for a while? Is the charger in the scooter OK?
Likes berkeman
OP says the charger in the scooter is probably broken, so he needs to charge the battery just to get the motor started.
If possible that charger in the scooter needs replacing, if lucky he can get something cheap but working from a vehicle scrap yard.
Likes Student12 and Stavros Kiri
How long since the scooter was last used? If the battery has been left in a discharged state for many months, it may well be dead. Lead Acid cells last much better if their charge is kept topped up.
Do you have a meter to check the actual voltage on the battery on its own or when connected to your charging source?
You could perhaps find if the scooter charger works when pushing the scooter along and measuring the volts. (No good if it has an automatic gearbox.)
I left the battery charging for almos 2 hours on the same 12v 2.3a adapter ..
The current voltage is 10.8v and when i try to charge it again it makes a noise like boiling..
Likes Stavros Kiri
- It would be good to know the exact type of the battery. 2.3Ah sounds like sealed lead-acid?
- if so, then the maximal charge current for 2.3Ah battery should be something like 0.3-0.7A at most?
- actually, reviving it from 3V sounds like some bad zombie movie. I too think that the battery is done.
Likes berkeman
Did you ever read what it says on the side of the battery? They usually have instructions for charging conditions. BE sure to do that with the replacement you will need to buy.:wink:
Likes berkeman and NTL2009
I think that it's good that it picked up some voltage (10.8V, in 2 hrs) but the boiling sound not a good sign! (You charged it full speed.) I would say it's either almost dying or , in case it can be revived, make sure you use it a bit (to lower the voltage) before you attempt further charging, to see also how it behaves, but make sure this time to use the series light bulb trick that tech99 and berkeman suggested:
I think there is a [small?] chance you might be able to save it, but then find what the ideal charging and maintenance instructions are and try to follow them more consistantly, or do that with your next battery ...
P.S. Also with that type of charging equipment and conditions that you followed I think you should have tried 45' min charging intervals (not even 1hr). That's why you should better use the series light bulb trick, if you have another chance ...
Are you sure its a 12V battery ?
Likes sophiecentaur
He must read what it says on the side but I would have hoped he would have done that already! It's dangerous to try to charge a battery with the wrong charging conditions.
FAQ: Please guide me to recharge a battery
1. How do I know when a battery needs to be recharged?
A battery typically needs to be recharged when its charge level drops below 20%. Modern devices often have indicators that show the battery level, or you can check the battery settings on your device to see the current charge level.
2. What is the best way to recharge a battery?
The best way to recharge a battery depends on the type of battery. For rechargeable batteries, such as lithium-ion batteries, it is recommended to use the charger that came with the device or a compatible charger. Avoid using fast chargers as they can decrease the lifespan of the battery. For non-rechargeable batteries, it is best to replace them when they are depleted.
3. How long does it take to recharge a battery?
The time it takes to recharge a battery depends on the type of battery and the charging method. Typically, it takes 1-2 hours to fully charge a smartphone battery, while larger batteries, such as car batteries, can take up to 24 hours to recharge. It is important to follow the recommended charging time for your specific battery to avoid overcharging.
4. Can I overcharge a battery?
Yes, overcharging a battery can lead to decreased battery life and even cause it to overheat or catch fire. Most modern devices have built-in mechanisms to prevent overcharging, but it is still important to monitor the charging process and not leave the battery charging for an extended period of time.
5. How many times can a battery be recharged?
The number of times a battery can be recharged depends on the type of battery and the charging method. Generally, rechargeable batteries can be recharged hundreds to thousands of times before they need to be replaced. Non-rechargeable batteries, on the other hand, can only be used once and then need to be disposed of properly.
