Please help with a question about friction
  • Thread starter Prem1998
  • Tags
    Friction
In summary, the problem involves three blocks of different masses on a frictionless table, with a horizontal force F applied on each block individually. The coefficients of friction between the blocks are given by u1 and u2. The goal is to find the accelerations a1, a2, and a3 of the blocks for each case when the force F is applied on A, B, and C. To solve the problem, a drawing and free body diagrams for each block are necessary, along with relevant equations that link the variables in the diagrams. Without additional assumptions about sliding, it may not be possible to solve the problem.
Prem1998
148
Three blocks A, B, and C of masses m1, m2 and m3 respectively are lying on top of each other on a frictionless table with A on top and C on bottom. The coefficient of friction between A and B is u1 and between B and C in u2. Find the accelerations a1, a2 and a3 of the three blocks if a horizontal force F is applied on:
(a) A, (b) B and (c) C
The force F is applied on one block at a time and the accelerations are noted and then it is applied on the second one then the third one giving us three sets of accelerations.
I can't get anything in my head.
First thing to do is make a drawing. You will notice it's impossible to draw three blocks on top of each other :smile: but you can draw a block C on top of B which is on top of A.
Then for each case make a free body diagram of each of the blocks. See if you have enough information to solve, or if you still need some additional assumptions (about sliding or not sliding :rolleyes: )
Oh, and: you can't get started without some relevant equations. That's why there is a section 2 in the template. Check your notes or your textbook.
The equations link the variables that appear in your diagrams, so make a list of them (item 1 in the template :wink: ).
By the way, your thread may be deleted by a mentor for not showing any effort. See the guidelines
Related to Please help with a question about friction
1. What is friction?
Friction is a force that resists the relative motion or tendency towards motion between two surfaces that are in contact with each other.
2. What causes friction?
Friction is caused by the microscopic roughness of surfaces that come into contact with each other, as well as the intermolecular forces between the molecules of the two surfaces.
3. How is friction measured?
Friction is measured using a unit called the coefficient of friction, which is a dimensionless number that represents the ratio of the force of friction between two surfaces to the normal force pressing the two surfaces together.
4. How does friction affect motion?
Friction acts in the opposite direction of the applied force, which can cause objects to slow down or come to a stop. It also plays a crucial role in allowing objects to grip and move on surfaces.
5. How can friction be reduced?
Friction can be reduced by using lubricants, such as oil or grease, between two surfaces, or by using materials with smoother surfaces. It can also be reduced by applying a force in a direction that minimizes the contact between the two surfaces.
