Please I on this problem, I can't figure out what to do
  • Thread starter Stefff
  • Tags
    Figure
In summary: Yes, that's the correct coefficient of v(t) at zero delay. However, I'm not sure about your last equation. Remember that x(t) and v(t) are both functions of t, so you can't simply multiply them by a constant. Also, what happened to the summation over k? And why is there a v(t) term on the right side?
Stefff
Let e(t), for t = 0,±1,±2, . . ., be a realization of an IID sequence of zero-mean random
variables with variance σe^2, and let v(t) be the output of the filter:
v(t) = (B(q)/A(q) )e(t)
where B(q) and A(q) are polynomials in the forward shift operator q (i.e. qv(t) = v(t + 1)),
given by:
B(q) = 1 +Ʃ(from k=1 to m) bk*q^-k ---- bk →b subscript k
A(q) = 1 +Ʃ(from k=1 to n ) ak*q^-k -----ak →a subscript k
and the solutions to A(z) = 0 and B(z) are all inside the unit circle.
(a) Let x(t) be the output of the following filter:
x(t) = ((A(q) − B(q))/B(q)) v(t)
(b) Write the relationship between x(t) and v(t) as a difference equation. What is the
coefficient of v(t) (i.e. at zero delay)? Is this filter stable?
(c) Compute the expected value E[x(t − k)e(t − k)], for k = 0, 1, 2, . . ..
(d) Let y(t) be defined as:
y(t) = (B(q)/A(q))x(t)
Can this signal be used as a “one-step†ahead prediction of v(t)? Justify your answer.
(e) Compute the expected value and autocorrelation of v(t) − y(t).
3. The Attempt at a Solution [/b
You need to provide some attempt at a solution, or at the least an explanation of where you're stuck.
Thank you Haruspex.
I did substituted the A(q) and B(q) into the x(t) equation in order to find the relationship between the x(t) and v(t) to get the coefficient of v(t). Although am not sure if that is right or not hence, i could not tell if the filter is stable or not. I could not compute the expected value either.
I am actually got stock in b.
Then please post the working you have done.
given by:
Check your PMs. You *must* show your efforts toward the solution when you post questions here.
x(t) = [1 + Æ©(from k= 1 to n) akq-k -(1 + Æ©(k = 1 to m)bkq-k] * v(t)]/ 1 + [k=1]\sum[m] bkq-k
the relationship between x(t) and v(t) is therefore
[q-1x(a-b)]\[1 + b*q-1] + [q-2x(a2-b2)]\[1 + b2*q-2] +...+ [q-nx(an-bm)]\[1 + bm*q-m]
Thank you.
Thank you.
There are several things I don't understand in that last line.
First, there's no equals sign, so how does it express a relationship?
Second, there's no mention of v.
Third, what do the backslash symbols (\) represent?
Fourth, how can you use ellipsis (...) between a term that has a2 and b2 and a term that has an and bm? What happens when m and n are different?
x(t)/v(t) =
[q-1x(a-b)]/[1 + b*q-1] + [q-2x(a2-b2)]/[1 + b2*q-2] +...+ [q-nx(an-bm)]/[1 + bm*q-m]
i used the ellipsis because the sup and sub are equal i.e k, and tend to m and n.
Stefff said:
x(t)/v(t) =
Yes, but if each goes up one at a time then they won't reach m and n together.
To clarify the difficulty, try writing that out in full with m = 2, n = 1.
This is what i am doing for this question :
x(t) * B(q) = (A(q) - B(q) ) * v(t)
bk *x(t-k) = ak*v(t-k) - bk*v(t-k)
for zero delay ----- k=zero.. substitute into the equation
b0 *x(t) = a0 * v(t) - b0 *v(t)
therefore the coef. of v(t) be ... ( a0 - b0 )
b0 * x(t) = v(t) (a0 - b0)
is that correct ?
I feel the LHS should be written B(q) * x(t). B(q) is an operator, so the order matters.
But a0 = b0 = 1. Does that make things interesting?
And I would have thought the coefficient would be of the form x(t) = (coefficient)*v(t), so it would be a0/b0 - 1.
Thank you for the suggestions, i believe the coefficient of v(t) = 0 if a0 = b0 =1. i.e at zero delay. Any suggestion on how to go about with the c? thank you.
That sounds about right Steff. Now let's move to part c:
where
substituting v(t) into x(t) we get
x(t) = ((A(q) − B(q))/B(q))*(B(q)/A(q) )e(t) ---> x(t) = (((A(q) − B(q))/A(q))*e(t)
with a time shift to x(t) ---> x(t-k) the equation-> x(t-k) = (((A(q) − B(q))/A(q))*e(t-k)
Now for: e(t) with a time shift to e(t)---> e(t-k)
now we got both x(t-k) and e(t-k) ,,, multiply them together to get
e(t-k)
we obtain:
x(t-k)e(t-k)= (((A(q) − B(q))/A(q))*e(t-k) *e(t-k) ----->(((A(q) − B(q))/A(q))*e^2(t-k)
take the expected value :
E[x(t-k)e(t-k)]=((A(q) − B(q))/A(q))*E[e^2(t-k)]
and E[e^2(t-k)] = σe^2 since the mean is zero ----- it is equal to σe^2
So the result is E[x(t-k)e(t-k)]=((A(q) − B(q))/A(q))* σe^2
check this, this is what I am doing for this question.
let me know if its correct
e(t-k)
we obtain:
No, the A(q) etc. are operators. The '*' between (((A(q) − B(q))/A(q)) and e(t-k) does not represent ordinary multiplication, so you can't apply associativity like that.
Let's start with something a bit simpler: can you evaluate E[e(t) q-1 e(t)]?
Hint:
e(t) and e(t-1) are independent
Okay, can you evaluate E[e(t) q-1 e(t)]?
with your hint : e(t) and e(t-1) are independent
then E[e(t)]E[e(t-1)] ---> and that is zero since the mean is zero.
I am not sure if I got that right or not. can you give me more hints if its not correct
That's right.
When i first saw this question I was a bit non-plussed by the notion of dividing by an operator. So I did a bit of reading and it seems that x(t-k) = ((A(q) − B(q))/A(q))*e(t-k) means A(q)x(t-k) = (A(q) − B(q))*e(t-k), no more, no less. So I would favour working with that form.
So consider E[e(t-k) A(q) e(t-k)]. Can you evaluate that now?
Same it would equal to zero
as
E[e(t-k) A(q) e(t-k)] = A(q)E[e(t-k)]E[(e(t-k)] ----> and E[e(t-k)] is zero.
as
No. E[e(t-k) e(t-k)] is not zero. As you posted earlier it would be σe2.
What in general will E[e(t-k)e(t-j)] evaluate to?
In E[e(t-k) A(q) e(t-k)], expand A(q).
Perfect I see it now after expanding A(q) I would get σe2
zero for all j not equal to k
but if j=k then σe2
so I get for part c ---> answer is zero
How do you get that? (I'm not saying it's wrong - I genuinely don't know.)
Btw, it occurred to me that another approach is to consider that polynomials can be factorised. E.g. A(q) could be written as âˆ(1-ωiq-1). We're told all the roots ωi satisfy |ωi| < 1. As a result, A-1(q) = âˆiÆ©n(-ωiq-1)n.
this is the final equation I got for :
Need to compute E[x(t-k)e(t-k)]
x(t) = (SUM(ak*e(t-k)) - (SUM(bk*e(t-k) - (SUM(ak*x(t-k))
multiply x(t) by e(t):
x(t)e(t)= (SUM(ak*e(t-k)e(t)) - (SUM(bk*e(t-k)e(t)) - (SUM(ak*x(t-k)x(t))
then shift by j for both (x) and (e)
x(t-j)e(t-j)= (SUM(ak*e(t-k-j)e(t-j)) - (SUM(bk*e(t-k-j)e(t-j)) - (SUM(ak*x(t-k-j)x(t-j))
take the expected value:
E[x(t-j)e(t-j)]= E[(SUM(ak*e(t-k-j)e(t-j))] - E[(SUM(bk*e(t-k-j)e(t-j))] - E[(SUM(ak*x(t-k-j)e(t-j))]
lets look at each expectation by it self:
E[(SUM(ak*e(t-k-j)e(t-j))] = zero since k is never zero ...the shift difference between e(t-k-j)e(t-j)) is never the same
E[(SUM(bk*e(t-k-j)e(t-j))] similar to the above
E[(SUM(ak*e(t-k-j)e(t-j))] Since x(t) doesn't contain current values of e(t) it only contains past values . therefore for example E[e(t-1-j)e(t-j)] is zero.
so the result of the E[x(t-j)e(t-j)]= zero.
Can this signal be used as a ONE STEP ahead prediction of v(t)? Justify your answer
I got that
can you give me hints for
part c
I.e. x(t) = (A-B)e(t-k) + Ax(t-k)?
How do you arrive at that? I get:
Av(t) = Be(t)
Bx(t) = Av(t) - Bv(t) = Be(t) - (B/A)e(t)
To get a mix of t and t-k I would need to introduce a qk somewhere.
FAQ: Please I on this problem, I can't figure out what to do
1. Why is this problem so difficult for me?
This problem may be difficult because it requires a certain level of knowledge or skill in a specific subject. It's also possible that the problem is complex and requires critical thinking and problem-solving skills.
2. Can you give me some tips on how to approach this problem?
One tip is to break down the problem into smaller, more manageable parts. This can help you focus on one aspect at a time and make progress. Another tip is to try different approaches or techniques, as there may be more than one way to solve the problem.
3. How can I stay motivated when I'm struggling with this problem?
It can be frustrating when you're struggling with a problem, but remember to take breaks and step away from the problem if you need to. This can help you come back with a fresh perspective. It's also important to remind yourself that it's okay to ask for help or seek additional resources.
4. What resources can I use to help me with this problem?
There are many resources available to help with problem-solving, such as textbooks, online tutorials, and academic support services. You can also try reaching out to classmates or professors for assistance.
5. How can I improve my problem-solving skills?
Problem-solving is a skill that can be developed and improved with practice. One way to improve is to regularly challenge yourself with new problems and approach them with a positive and open mindset. Additionally, seeking feedback and learning from mistakes can also help improve problem-solving skills.
