TheFerruccio
- 220
Plot a deformed shape given the displacements
Preliminary statement: This class has a different convention.
Instead of writing x and y, ##x_1## and ##x_2## are the variables in their respective orthogonal directions.
I need to plot how shapes deform, so I am given an equation for the deformation in the ##x_1## direction, and the deformation in the ##x_2## direction, denoted ##u_1## and ##u_2##, respectively.
Problem Statement
Plot how a rectangle with sides a (horizontal) and b (vertical) deforms under the following deformation equations:
##u_1=k({x_1}^2+{x_2}^2)##
##u_2=k(2x_1+x_2)##
Attempt at Solution
As far as I can tell, I have never had to plot something quite like this. The closest I can relate to this is implicit functions and parametric functions. I know that the displacement is simply the original location ##x_i## plus the displacement ##u_i##
Thus, I can turn the displacement function into a function for the "final value" as such, denoting ##y_1## and ##y_2## as the final locations in the ##x_1## and ##x_2## directions, respectively.
##y_1=x_1+k({x_1}^2+{x_2}^2)##
##y_2=k(2x_1+x_2)+x_2##
I know what this is doing. These two equations combine to create a mapping from ##\mathbb{R^2}\rightarrow\mathbb{R^2}##. I can fix one of the directions to plot a line. In this case, I can take the ##x_1## and ##x_2## coordinates and plot a deformed line from an original line by holding one of my input variables constant, such as defining ##x_2=0## to see how a horizontal line located at ##x_2=0## gets deformed.
This would reduce the equations to:
##y_1=x_1+k({x_1}^2)##
##y_2=k(2x_1)##
Unfortunately, I still have no idea how I would go about doing this considering a and b are left arbitrary. I need some assistance to spark my brain and push me in the right direction with this. Wolfram Alpha has a parametric plotter, but it has no built-in functions to handle constants, and just assumes that everything is a variable. Does anyone know how I can approach this problem in an intuitive manner? My attempts to tackle it have just been failing.
Problem Statement
##u_2=k(2x_1+x_2)##
Attempt at Solution
##y_2=k(2x_1)##
