ineedhelpnow
- 651
how would i plot points in 3D on the ti nspire cx cas? like these 3 for example: (-4,0,-1), (3,1,-5), (2,4,6)
Rido12 said:I'm not sure about the TI-nspire cx cas...(geez, just a couple of years ago, my TI-84 was the new graphing calculator)...but the TI-84 can't graph 3D, you have to install an application that can do it for you. So if you can't find the 3D graphing tool on your calculator, most likely you'll have to install an application on it.
ineedhelpnow said:and also, I don't like wolfram alpha anymore :/
The purpose of plotting points on ti nspire cx cas is to visually represent data or mathematical equations in a coordinate plane. This allows for a better understanding and analysis of the data or equations.
To plot points on ti nspire cx cas, first open the Graphs & Geometry menu and select the "Points & Vectors" option. Then, use the arrow keys to move the cursor to the desired location on the coordinate plane and press "Enter" to plot the point. Repeat this process for each point you wish to plot.
Yes, you can plot multiple points at once on ti nspire cx cas by using the "List & Spreadsheet" feature. This allows you to enter the coordinates of each point in a table and have them plotted on the coordinate plane simultaneously.
To edit or delete plotted points on ti nspire cx cas, simply use the arrow keys to select the point you wish to edit or delete, and then press the "Menu" button. From the options that appear, you can choose to edit the coordinates, delete the point, or clear all points from the graph.
Yes, you can customize the appearance of plotted points on ti nspire cx cas by selecting the "Options" tab in the Graphs & Geometry menu. From there, you can change the color, shape, and size of the points, as well as add labels or data points to them.
