Plumbing Infrastructure Resources and Codes
  • Thread starter tj00343
  • Tags
    Resources
In summary, the conversation involved a mechanical engineer seeking advice on designing plumbing infrastructure for a large district. The engineer has experience with MEP work inside buildings but not with district-level design. They have learned Bentley softwares but need guidance on necessary resources such as handbooks and codes. The other person suggests consulting local authorities, specifically code enforcement, for applicable construction codes and points of inspection. The thread is then closed.
tj00343
63
Hi guys,
I'm a mechanical engineer working in a design firm in the construction industry.We have recently been tasked with the design of the Plumbing Infrastructure(Drainage, Water supply, and Firefighting) for a large district. We haven't undertaken this kind of work before since we usually do the MEP work(Water supply, Drainage, HVAC, and Firefighting) inside buildings. We have learned Bentley softwares for infrawork and have a general idea about where to start but we have no way of confirming the things we are learning. I was wondering what would be the best resources (Handbooks,codes, etc.) to start with.
Since you are in Lebanon, you need to consult your local authorities to find this out. Start with your government code enforcement folks -- they should be able to help you find the applicable construction codes and points of inspection. Thread is closed.
FAQ: Plumbing Infrastructure Resources and Codes
What is plumbing infrastructure?
Plumbing infrastructure refers to the system of pipes, fixtures, valves, and other components that make up a building's plumbing system. This includes both the water supply and drainage systems.
What are plumbing codes?
Plumbing codes are a set of regulations and standards that dictate the design, installation, and maintenance of plumbing systems in buildings. These codes are put in place to ensure that plumbing systems are safe, efficient, and sanitary.
Why are plumbing codes important?
Plumbing codes are important because they help to ensure the safety and functionality of plumbing systems. They also help to prevent potential health hazards and costly repairs due to faulty plumbing installations.
What are some common plumbing infrastructure resources?
Some common plumbing infrastructure resources include pipes, fittings, valves, pumps, and fixtures such as sinks, toilets, and showers. These resources are used to transport and control the flow of water throughout a building's plumbing system.
How often do plumbing codes get updated?
Plumbing codes are typically updated every few years to keep up with advancements in technology and changes in building regulations. It is important for plumbers and contractors to stay informed of these updates to ensure compliance with the most current codes.
