Plus-Minus Symbol In This Trig. Equation
In summary, the conversation is discussing a calculus problem involving trigonometric equations and the use of the plus-minus symbol in the solution. The speaker suggests that the symbol should be placed inside the arccos, while the solution skips checking the negative option due to the secant always being positive in the given domain. The plus-minus sign is used for a different reason, as the secant and cosine are even functions. The conversation also touches on the use of the Mean Value Theorem in the solution.
ecoo
86
Hey guys,
The problem is #49 and it is a simple calculus problem, but the part that I am confused on is how the solution solves the trig. equation. In the solving, the solution brings out the plus-minus symbol and puts it outside the arccos, but I feel as if it should be inside the arccos.
I understand that putting the symbol outside solves the problem perfectly, but it seems like a shortcut. How I think it should be done is to put the plus-minus symbol inside the arcccos (it would give us two different answers) and choose the answer that fits into the domain of the problem which is (pi/4 and -pi/4). When I choose the answer that fits into the domain, I can make it positive or negative because the secant is squared.
Thanks!
Mathematics news on Phys.org
I suppose what isn't written in the solution is that the secant is always positive in the given domain. Hence, the solution skips checking the negative option. The plus-minus sign on the following line, however, is there for a different reason: the secant (and in turn cosine) is an even function i.e. [itex]f(x) = f(-x)[/itex].
Admittedly, I haven't used the Mean Value Theorem in a while, but isn't the tangent at the point c supposed to equal the slope of the secant formed by the points at the ends of the interval? The slope of the secant on the function is 0. So there is only one place on the interval with a point that has a tangent line with a slope of 0.
Note the result of the solution in the jpg on the graph of the original equation.
Note that the problem in question refers to the MVT for integrals i.e. the MVT you're suggesting is applied to the antiderivative.
Likes thelema418
@da_nang, thanks! That's definitely what I missed when reading it!
Just to reclarify, was I correct in my thinking and that the solution took a shortcut (the plus minus should have went inside)? A plus minus then should have been added AFTER solving and throwing out the solution outside the domain because the secant function is even.
Thanks!
FAQ: Plus-Minus Symbol In This Trig. Equation
What is the plus-minus symbol in this trigonometric equation?
The plus-minus symbol, ±, indicates that there are two possible solutions to the equation. It represents both the positive (+) and negative (-) value of the solution.
How do you solve an equation with a plus-minus symbol?
To solve an equation with a plus-minus symbol, you must first isolate the variable on one side of the equation. Then, you can solve for both the positive and negative solution by plugging in the isolated variable into the equation twice, once with a positive sign and once with a negative sign.
Why is the plus-minus symbol used in trigonometric equations?
The plus-minus symbol is used in trigonometric equations because there are often two possible solutions to the equation. Trigonometric functions have a period of 360 degrees or 2π radians, which means there are multiple angles that can satisfy the equation. The plus-minus symbol allows us to represent both possible solutions.
Can the plus-minus symbol be used in other types of equations?
Yes, the plus-minus symbol can be used in equations other than trigonometric equations. It can be used in any equation where there are multiple possible solutions, such as quadratic equations or equations involving square roots.
How do you know which solution to use when solving an equation with a plus-minus symbol?
When solving an equation with a plus-minus symbol, both solutions are valid. Depending on the context of the problem, one solution may make more sense than the other. It is important to check your answer by plugging it back into the original equation to ensure that it satisfies the equation.
