PM sychronous motor parameter measurement
In summary, the alignment step for the q-axis is done by subtracting the square of the distance between the current vector and phase A.
awaiting
24
Hi everyone!
I am trying to find the parameters of a surface mounted PM synchronous motor using the application note AN4680 (PMSM Electrical Parameters Measurement) and had some queries regarding it.
The Ld process is mentioned as follows
1. Align the rotor to phase A. Phase A is connected to the positive potential (+) and phase B and C are grounded (-).
2. Lock the rotor shaft.
3. Apply negative step voltage. Phase A is grounded (-) and phases B and C are connected to the positive potential (+).
Usual level of the current is about 10% of the rated phase current.
4. Measure the step response of the current by a current probe. See Figure 11.
5. Calculate inductance Ld.
Lq inductance measurement
1. Align the rotor to the q-axis. Connect the phase B terminal to the positive potential (+) of the voltage source and phase
C is grounded (-). Phase A terminal is floating.
2. Lock the rotor shaft firmly because current step response in q-axis creates torque.
3. Generate a current step response in this configuration: phase A is connected to the positive potential (+) of the voltage source and phases B and C are grounded.
4. Calculate inductance Lq in the same way as Ld.I wanted to know how does step 1 in both the cases ensure the alignment of the rotor with d and q axis respectively. I tried to work it out mathematically, for d axis inductance measurement, if we connect phase A to +5V and ground phase B and C,
Vd=(2/3)*Va*cos(theta),
(from Park's transformation)
now if we assume theta to be zero, only then will Vq will be zero.
Similarly, if we connect phase B to +5V, ground C and open phase A, how is it concluded that we have aligned the rotor in the q -axis.
Secondly,during Lq (q axis inductance measurement) measurement it is mentioned that the current response creates a torque in the q-axis and the motor may rotate but I did not find any rotation in the rotor during both Ld and Lq measurement.
Could you please point out if I missing any point in the document.
I appreciate your help,
Thanks,
  • Freescale AN4680.pdf
The stator current vector is given by:
i_s = i_a + i_b a + i_c a^2, a = e^{j2\pi/3}
For the d-axis alignment step:
i_s = i_a - \frac{1}{2} i_a a - \frac{1}{2} i_a a^2 = \frac{3}{2} i_a
The stator current vector will be aligned with phase A, which means the magnetic axis of the stator field will be aligned with phase A, so the rotor will turn to align its d-axis with phase A.
For the q-axis alignment step:
i_s = i_b a - i_b a^2 = j\sqrt{3} i_b
The stator current vector will be at a right angle to phase A, which means the magnetic axis of the stator field will be at a right angle to phase A, so the rotor will turn to align its d-axis perpendicular with phase A, i.e. its q-axis is aligned with phase A.
Thanks for the reply!
I did not get an email notification of your post, hence missed it.
but I figured out the solution later on..
Related to PM sychronous motor parameter measurement
1. What is a PM synchronous motor?
A PM synchronous motor is a type of electric motor where the rotor is equipped with permanent magnets. These magnets are responsible for creating a magnetic field that interacts with the stator's electromagnetic field, resulting in rotation.
2. Why is it important to measure the parameters of a PM synchronous motor?
Measuring the parameters of a PM synchronous motor is important because it allows us to understand the motor's performance and characteristics. This information is crucial for designing and optimizing the motor for specific applications.
3. What are the parameters that need to be measured in a PM synchronous motor?
The parameters that need to be measured in a PM synchronous motor include the stator resistance, rotor resistance, inductances, and back EMF constant. These parameters are essential for calculating the motor's torque, speed, and efficiency.
4. How are the parameters of a PM synchronous motor measured?
The parameters of a PM synchronous motor can be measured using various techniques, such as the direct and indirect methods. The direct method involves physically measuring the motor's electrical, mechanical, and magnetic quantities, while the indirect method uses mathematical models and simulation software.
5. What factors can affect the accuracy of PM synchronous motor parameter measurements?
The accuracy of PM synchronous motor parameter measurements can be affected by factors such as temperature, frequency, and magnetic saturation. It is important to consider these factors and perform measurements under controlled conditions to ensure accurate results.
