PN Junctions vs Transistors When Building Logic Gates
In summary, logic gates are built using transistors instead of PN junctions because transistors offer more advantages and functionalities compared to PN junctions. This is why CMOS logic gates use transistors. Transistors can act as switches and are voltage-controlled, just like PN junctions. However, transistors have an additional third contact, which allows for better control and more complex operations. This makes transistors more efficient and versatile in their use compared to PN junctions.
Vishera
72
Is there any reason why logic gates are built using transistors instead of PN junctions? Wouldn't it be more cost-efficient to use PN junctions? I am referring to CMOS logic gates.
Also, what can a transistor do that a PN junction can't?
Thanks for the post! Sorry you aren't generating responses at the moment. Do you have any further information, come to any new conclusions or is it possible to reword the post?
It seems to me that both PN junctions and transistors act as switches. And both switches are voltage-controlled. So what advantage does a transistor have over a PN junction? When the voltage is high on a PN junction, it is in forward bias and it allows current to pass though. When the voltage is low on a PN junction, it is in zero bias and it does not allow current to pass through. When a NPN bipolar transistor's base voltage is high, it allows current to pass through. When a NPN bipolar transistor's base voltage is low, it does not allow current to pass through.
EDIT: Actually, I think I get it now. A PN junction has only two contacts while a transistor has three contacts.
I'm glad you realized the problem: transistors are made out of PN junctions!
Related to PN Junctions vs Transistors When Building Logic Gates
1. What is the difference between a PN junction and a transistor?
A PN junction is a type of semiconductor diode made from a P-type and N-type material, while a transistor is a device made from multiple layers of semiconductor material that can amplify or switch electronic signals.
2. How are PN junctions and transistors used in building logic gates?
PN junctions and transistors are key components in the construction of logic gates, which are used to perform logical operations in electronic circuits. PN junctions can be used to create AND and OR gates, while transistors can be used to create NOT and other types of gates.
3. Which is more efficient in building logic gates, PN junctions or transistors?
Transistors are generally considered more efficient in building logic gates, as they can be used to create a wider range of gate types and can handle larger currents than PN junctions.
4. Are PN junctions and transistors interchangeable in logic gate construction?
No, PN junctions and transistors have different properties and functions, so they cannot be used interchangeably in logic gate construction. However, they can be used together in combination to create more complex logic circuits.
5. Can you explain the role of PN junctions and transistors in digital logic?
PN junctions and transistors are essential components in digital logic, as they allow for the manipulation and processing of electronic signals to perform logical operations. By combining PN junctions and transistors in various configurations, complex digital logic circuits can be built to perform a wide range of functions.
  • Classical Physics
  • Atomic and Condensed Matter
  • Electrical Engineering
