Pneumatic/hydraulic energy storage
In summary, the conversation discusses the possibility of storing rotational energy into pneumatic or hydraulic energy. It is suggested to run a compressor from the shaft to compress air into a tank and then use the compressed air as needed. The idea of using liquids for energy storage is also brought up, but it is noted that compressing liquids is not effective. The use of hydraulics for energy storage is also mentioned, with examples of hydraulic systems in heavy construction machinery and hydraulic hybrid trucks. The energy in a hydraulic system is typically transferred from a power source to a location where it is needed, but it can also be used for energy storage through the use of accumulators.
physea
211
Hello! Are there any systems that you can store rotational energy into pneumatic or hydraulic energy? Let's say we have a rotational shaft. How can I take energy from it and store it as pneumatic or hydraulic energy? And then re-use it?
I suppose you could run a compressor from your shaft that will compress air into a tank. Then you can use the compressed air however you want.
Likes russ_watters and davenn
Tesla "turbine?"
Would that work with liquids? Any hydraulic system to have a look?
of course ... in use every day on heavy construction industry machines ... dozers, grader, excavators etc
You won't be able to compress a liquid very effectively, so that part won't work.
I know you could run a hydraulic system off of your shaft, but I don't know how you would store energy in a hydraulic system. Hydraulics are usually used to transfer the power from a power source, such as an engine or motor, to a location where that power is needed to do work, without needing mechanical linkages. However, if you're designing a system that can stored energy from a shaft, then you could incorporate hydraulics to get the energy back out of wherever you stored it.
You could pump the liquid uphill and store energy in GPE.
Likes russ_watters
Google hydraulic hybrid truck for applications of energy storage in hydraulic systems. The energy is stored in an accumulator, search term is hydraulic accumulator.
Related to Pneumatic/hydraulic energy storage
What is pneumatic/hydraulic energy storage?
Pneumatic/hydraulic energy storage is a method of storing energy using compressed air or pressurized fluid. It involves storing energy in a compressed state and releasing it when needed to perform work.
How does pneumatic/hydraulic energy storage work?
Pneumatic/hydraulic energy storage works by compressing air or fluid in a storage tank or container. When the compressed air/ fluid is released, it expands and moves a piston or turbine, which can then generate electricity or power machinery.
What are the advantages of using pneumatic/hydraulic energy storage?
Some advantages of pneumatic/hydraulic energy storage include its high energy density, low cost, and ability to store energy for long periods of time without significant loss. It is also a clean and environmentally-friendly form of energy storage.
What are the applications of pneumatic/hydraulic energy storage?
Pneumatic/hydraulic energy storage has a variety of applications, including powering vehicles, storing renewable energy, and providing backup power for emergency situations. It can also be used in industrial settings for powering machinery.
What are the disadvantages of using pneumatic/hydraulic energy storage?
Some potential disadvantages of pneumatic/hydraulic energy storage include the need for specialized equipment and infrastructure, potential safety hazards due to the high pressures involved, and the limited number of cycles before the storage container needs to be refilled or replaced.
  • Classical Physics
  • Classical Physics
  • Classical Physics
