Pneumatic Valve and Orifice Issues
In summary: The valve should open at ~34-35 psig with the Ø0.0045” orifice, but it only seems to work intermittently. What do you think is causing the problem?In summary, the orifice size seems to be affecting how the valve opens.
Missile
I am working on a problem trying to find out why a 0.010” orifice can be used to open a pilot actuated, spring return pneumatic 5/2 directional control (spool) valve, but a 0.0045” orifice only seems to work intermittently.
The air system that I am working with is 100 psig. The air enters the control valve, is routed thru Ø0.063” passage thru the metal valve body, thru a flame arrestor, thru the orifice, thru a Ø0.068” x 6” length tube, and into a pilot. One the pilot is opened the air flows thru a Ø0.068” x 5” length tube, into a Ø0.068” orifice, thru another flame arrestor, and into a different port of the valve body, with the same Ø0.063”, and into a chamber where the air is trying to force the piston to open. The piston is being held closed by a spring.
The spring rate is 4.59 lb/in (or 804 N/m). While assembling the valve in the assembly, the spring is compressed by 0.183” from free length. When the piston is moved to the open position, it compressors the spring an additional 0.209”
The diameter of the piston is 0.407”.
I do not have a device to measure flow rate of the air going thru the orifice, but I did some online research that say that thru the Ø0.0045” orifice the air flow at 100 psig should be 0.0215 CFM and the air flow thru the Ø0.010” orifice at 100 psig should be 0.1412 CFM.
If I do simple calculations for the forces, setting the spring force equal to the force (thrust) from the air, I get that the valve should open at ~ 34-35 psig. But, I know flow rate HAS to have something to do with it , but can’t decipher what that is.
How do I figure out what is keeping the valve from piston from actuating with the Ø0.0045” orifice, but working with the 0.010” orifice?
Hi Missile, welcome to the board. I think what you're saying is you have a piston in a cylinder which is being charged with air from either a 0.0045" orifice or a 0.010" orifice and when you use the smaller orifice, the piston isn't moving. Is that right?
Have you checked the pressure in the cylinder to verify you have pressure? Seals on the piston could be leaking so you may not even have any pressure.
Q_Goest - Yes, what you ask about the system set-up is correct.
I do have pressure in the chamber and am able to measure it. The chamber pressure goes from 0 to 100 psig in about 3.7 seconds after the pilot is activated when using the Ø0.0045” orifice and from 0-100 psig in 1.1 seconds using the 0.010” orifice.
Related to Pneumatic Valve and Orifice Issues
What is a pneumatic valve?
A pneumatic valve is a type of valve that uses pressurized air or gas to control the flow of fluids or gases. It is commonly used in industrial and manufacturing processes to regulate the movement of liquids or gases through pipes or tubes.
How does a pneumatic valve work?
A pneumatic valve works by using compressed air or gas to push a piston or diaphragm, which in turn opens or closes the valve. This allows for precise control of the flow of fluids or gases, as the valve can be adjusted to various levels of openness.
What are common issues with pneumatic valves?
Some common issues with pneumatic valves include leaks, malfunctions due to contamination or wear and tear, and incorrect pressure settings. These issues can lead to reduced efficiency, decreased accuracy, and potentially costly downtime.
What is an orifice and how is it related to pneumatic valves?
An orifice is a small opening or hole in a valve or pipe that controls the flow of fluids or gases. In pneumatic valves, the orifice size and shape can greatly affect the flow rate and pressure of the fluid or gas passing through. Improperly sized or damaged orifices can cause issues such as flow restriction or loss of control.
How can pneumatic valve and orifice issues be resolved?
Pneumatic valve and orifice issues can be resolved by regularly inspecting and maintaining the valves, checking for leaks and proper pressure settings, and replacing any damaged or worn parts. It is also important to properly size and select valves and orifices for the specific application to avoid potential issues.
