Pogo Stick Elastic Energy: Substituting Correct Variables
In summary, to determine the height that a 35 kg child will bounce on a pogo stick with a 4945 N/m spring compressed 25 cm, we can use the conservation of energy principle. By considering the gravitational potential energy, kinetic energy, and stored mechanical energy of the spring, we can set the initial and final total energies equal to each other. Solving for the height, we find that the child will bounce approximately 0.45 m high.
n3w ton
A 35 kg child is jumping on a pogo stick. If the spring has a constant of 4945 N/m and it is compressed 25 cm, how high will the child bounce?
Answer: 0.45 m
Need help substituting the right variable.
ETi= ETf
Egi + Eki + Eei = Egf + Ekf + Eef
mghi + 0.5mvi2 + 0.5ksi2 = mghf + 0.5mvf2 + 0.5ksf2
The real problem I have is setting the defined variables; everything I can solve for. I used trial and error and got 0.45 but I NEED TO KNOW WHY I use the variables (magnitudes in the right place)!
m = 35 kg
k = 4954 N/m
g = 9.8 m/s²
si = 0 m
sf = 0.37 m
hi = 0 m
hf = ?
vi = 0 m/s²
vf = 0 m/s²
I rearranged and solved and I got -0.45 m, some please tell me where what variables I have to substitute correctly! Thank you!
There are a number of different ways to answer this question but from the "relevant equations" you list, you appear to be using "conservation of energy". That's what your first equations says- initial total energy equals final total energy. There are three types of energy involved in such a jump- the gravitational potential energy, kinetic energy, and the stored mechanical energy of the spring. Those are your "[itex]E_g[/itex]", "[itex]E_k[/itex]", and "[itex]E_e[/itex]". The additional "i" and "f" subscripts "initially", at the beginning of the jump, and "finally", at the highest point of the jump. The third equation replaces those with the standard formulas.
We can take the ground as our base for potential energy so the potential energy is 0 there and mgh at h feet at h meters above the ground. At the start and at the highest point, the child is motionless so kinetic energy is 0 at both points. On the ground the stored mechanical energy is, as you say, [itex]0.5ks_f^2[/itex]. That is, on the ground the total energy is 0+ 0+ 0.5(4945)(.25)^2 and at the highest point of the jump the total energy is (35)(9.88)(h)+ 0+ 0. Set those equal and solve for h.
FAQ: Pogo Stick Elastic Energy: Substituting Correct Variables
What is pogo stick elastic energy?
Pogo stick elastic energy refers to the potential energy stored in the elastic material of a pogo stick when it is compressed or stretched.
Why is it important to substitute correct variables in the calculation of pogo stick elastic energy?
Substituting correct variables ensures that the calculated energy is accurate and reflects the true potential energy of the pogo stick. Using incorrect variables can lead to incorrect results and inaccurate understanding of the energy involved.
What are the correct variables to use in the calculation of pogo stick elastic energy?
The correct variables to use are the spring constant (k), which is a measure of the stiffness of the pogo stick's elastic material, and the displacement (x), which is the distance the pogo stick's spring is compressed or stretched from its equilibrium position.
How is pogo stick elastic energy related to the height of a jump?
Pogo stick elastic energy is directly proportional to the height of a jump. This means that the higher the pogo stick can be compressed, the greater the potential energy stored in its elastic material, and the higher the jump will be.
Can pogo stick elastic energy be converted into other forms of energy?
Yes, pogo stick elastic energy can be converted into other forms of energy, such as kinetic energy, when the pogo stick is released and the potential energy is converted into motion. It can also be converted into heat energy when the pogo stick's elastic material is compressed and stretched repeatedly, causing friction and generating heat.
