Poincare Transformations: Parametrization-Independent
In summary, the relation for \eta= \Lambda^T \eta \Lambda holds for the Poincare transformations, but it does not hold for the Lorentz transformations.
ChrisVer
464
Well if I have a worldline given by [itex]x^{\mu}(\tau) [/itex]
And I want to make a Poincare transformation: [itex] x^{\mu} (\tau) \rightarrow \Lambda^{\mu}_{\nu} x^{\nu}(\tau) + a^{\mu}[/itex].
I have one question,why can't [itex]a, \Lambda[/itex] explicitly depend on [itex]\tau[/itex]? that is to have:
[itex] x^{\mu}(\tau) \rightarrow \Lambda^{\mu}_{\nu}(\tau) x^{\nu} (\tau)+ a^{\mu}(\tau)[/itex].
Somehow I have a feeling this would make the Poincare transformations local...
Is it consistent with [itex] \Lambda^\alpha _{\ \mu} \Lambda^\beta_{\ \nu} \ \eta_{\alpha \beta}=\eta_{\mu \nu} [/itex]? I doubt it!
But even if it is, There will be some restrictions on the [itex] \tau [/itex] dependence of the transformations!
maybe you can find someway to make this work.
But for example if that was the case, then the free particle relativistic action [itex]\int d^4x \sqrt{ \dot{x} \cdot \dot{x}}[/itex] will not be invariant as it is, because of the [itex] \dot{a}, \dot{\Lambda}[/itex] terms... For simplicity I can put the time dependence only on the Lambdas... this would introduce a connection term as it does for gauge symmetries.
You should note that [itex] \eta_{\mu \nu} [/itex] is spacetime independent and so [itex] \Lambda^\alpha_{\ \mu} \Lambda^\beta_{\ \nu} \ \eta_{\alpha \beta} [/itex] should be. So if the Lorentz transformation depends on spacetime coordinates, it should be somehow that is eliminated in the product [itex] \Lambda^\alpha_{\ \mu}\Lambda^\beta_{\ \nu} \ \eta_{\alpha \beta} [/itex], but it seems impossible to me!
Remember both [itex] \Lambda [/itex]s are indicating the same transformation and so the condition means a restriction on the form of transformation. But I fail to see any physical interpretation of restrictions coming from such considerations and so I suspect its not possible.
I should confess I really wish I had enough mathematical experience so that I could do the calculations but I don't know what to do with it.
Where are all the real physicists of the PF?
Are you looking for Poincare gauge theory? It starts with gauging the Poincare transformations (i.e. the 10 group parameters are not constant wrt [itex]x^{\mu}[/itex]) and then goes on to explore the consequences on field theory.
The Poincare transformations are not so simple I think... why? because, the relation for [itex]\eta= \Lambda^T \eta \Lambda[/itex] is a result of the isometry, that is you asked for: [itex] (x',y')= (x,y)[/itex] and this for Lorentz transformations gave you the above result.
However that stops being the case for the Poincare transformations.
[itex] (x',y')= g_{\mu \nu} x'^{\mu} x'^{\nu}= g_{\mu \nu} (\Lambda^{\mu}_{\rho} x^{\rho} + a^{\mu})(\Lambda^{\nu}_{\sigma} x^{\rho} + a^{\nu}) =(\?) g_{\rho \sigma} x^{\rho} x^{\sigma}[/itex]
... So because of that I can't see why the [itex]\eta= \Lambda^T \eta \Lambda[/itex] should hold.
Partially I just did not see the reason why not assigning a parameter dependence on your transformations. Eg in U(1) let's say global symmetry you had a spacetime independent transformation parameter [itex]a[/itex]: [itex]e^{ia}[/itex]... which then you turned into spacetime dependent to get the local U(1).
What stops from doing that in Poincare case? I didn't even try to make them spacetime dependent, but "parameterization" dependent.
[itex] \Lambda^\alpha _{\ \mu} \Lambda^\beta_{\ \nu} \ \eta_{\alpha \beta}=\eta_{\mu \nu} [/itex] is the definition of a Lorentz transformation regardless of the fact that its going to be followed by a translation or not!
In the U(1) case, the only condition on the transformation is unitarity which is untouched by making the transformation local. But here it doesn't seem trivial that a spacetime dependent [itex] \Lambda [/itex] satisfies the definition of a Lorentz transformation or not.
This relation is just a result of the isometry you impose on the Minkowski space, that is for lorentz invariant quantities to remain invariant under Lorentz transformations. That is not true for the Poincare transformations and that's what I wanted to show above (you can't impose the same isometry for Poincare transfs). In other words minkowski space by itself is not invariant under poincare transformations but only under a subgroup of the Poincare group [that are the lorentz transformations of boosts and rotations], or not?!
I could as well say the SU(N).
For example if I impose the Poincare transformation [itex]\Lambda x +a(\tau) [/itex] to keep the particle invariant, I would have to change the derivatives to covariant derivatives.
I know what you mean, but here we aren't imposing the condition on the Poincare transformation.
I'm just telling, in order for [itex] x'^{\mu}=\Lambda^\mu_\rho x^\rho+a^\mu [/itex] to be a Poincare transformation, [itex] \Lambda^\mu_\rho [/itex] should be a Lorentz transformation, i.e. should satisfy [itex] \Lambda^\mu_{\ \rho}\Lambda^\nu_{\ \sigma} \eta_{\mu\nu}=\eta_{\rho \sigma} [/itex].
I'm OK with making the translation part spacetime dependent, I'm just telling that its not trivial that a spacetime dependent matrix can be a Lorentz transformation. So either its impossible or there will be a restriction on the kind of dependence.
So I think this issue is treated in a paper before all those I mentioned and all physicists working in this field know it well enough that they don't bother mentioning it in every paper.
Also I should say that, it seems to me you can have a spacetime dependent transformation that is not parametrization dependent but you can't have a parametrization dependent transformation that is not spacetime dependent.
Also, note that the condition [itex] \Lambda^\mu_{\ \rho}\Lambda^\nu_{\ \sigma} \eta_{\mu\nu}=\eta_{\rho \sigma} [/itex] doesn't come from [itex] \eta_{\mu \nu} x^\mu x^\nu=\eta_{\rho \sigma} x'^\rho x'^\sigma [/itex] but from [itex] \eta_{\mu \nu} dx^\mu dx^\nu=\eta_{\rho \sigma} dx'^\rho dx'^\sigma [/itex], so (global) Poincare transformations are isometries too.
I think I understand what you are trying to say.
Also, note that the condition [...]
Yes you are right. That was a bad mistake.
However if I made the Poincare transformations local (at least their translation parts), that would break, because [itex]da[/itex] would not be trivially zero... Also I'd try to stand on the local translation parts, since local lorentz transformations indeed sound weird, and I think it's impossible to have them. You would need a local metric tensor as well, which would bring GR into game, and GR is not Poincare invariant (it gets replaced by coordinate transformation invariance)
How can you say that?
ChrisVer said:
However if I made the Poincare transformations local (at least their translation parts), that would break, because dada would not be trivially zero... Also I'd try to stand on the local translation parts, since local lorentz transformations indeed sound weird, and I think it's impossible to have them. You would need a local metric tensor as well, which would bring GR into game, and GR is not Poincare invariant (it gets replaced by coordinate transformation invariance)
You're mixing up things!
1) A Lorentz transformation is a coordinate transformation [itex] \Lambda^\mu_{\ \rho} [/itex] satisfying [itex] \Lambda^\mu_{\ \rho}\Lambda^\nu_{\ \sigma} \eta_{\mu\nu}=\eta_{\rho \sigma} [/itex].
2) A Poincare transformation is a Lorentz transformation followed by a translation.
3) Global Lorentz and Poincare transformations are isometries of the Minkowski spacetime.
4) Making the translation part of a Poincare transformation to depend on parametrization, has nothing to do with the Lorentz transformation part of the Poincare transformation. The non-vanishing of [itex] da [/itex] only means a Poincare transformation with a local translation part, is not an isometry of Minkowski spacetime. Its still a Poincare transformation, its just not an isometry of the Minkowski spacetime. But its special case, the global Poincare transformation, is!
5) 1 means, a Lorentz transformation is defined as the most general homogeneous isometry of the Minkowski spacetime. So here, if anything causes a homogeneous coordinate transformation to change the length of spacetime intervals, it means that transformation is not a Lorentz transformation. So if you want to have a local Lorentz transformation, you should look for local homogeneous coordinate transformations that are also isometries of the Minkowski spacetime. The existence of such a thing is not trivial.(That's the reason I'm confused why every one is that much OK with Poincare gauge theory without asking such questions! It can't be because "we're going to talk about curved spacetime, so we should forget Minkowskian things" because spacetime is still locally Minkowskian.)
Its not clear to me too but It seems to me it should be the case. I try to give an argument.
Let's assume there is a parametrization dependent transformation that is spacetime independent. But it means this transformation is global i.e. changes things the same amount everywhere. Oh...that's the flaw! Different parametrizations can see different global constants! But I think that's the only way the transformation can be parametrization dependent without being spacetime dependent. It should be a global constant depending on the parametrization. I should stress it doesn't depend on the coordinates but only on which parametrization you're using.
For the non-rel. particle this is how you can couple the particle to Newtonian gravity, see
http://arxiv.org/abs/1206.5176
Making the translations local, you can introduce a potential which transforms inhomogeneously, such that the action is invariant under local translations, i.e. accelerations. The usual gauging procedure however would consist of introducing D gauge fields which have a Stuckelberg transformation, i.e. a shift symmetry.
Likes ChrisVer
Related to Poincare Transformations: Parametrization-Independent
1. What are Poincare transformations?
Poincare transformations are a set of mathematical operations that describe the way in which coordinates and measurements of space and time change when viewed from different reference frames in special relativity.
2. What is parametrization-independent?
Parametrization-independent refers to the fact that Poincare transformations do not depend on the specific mathematical coordinates used to describe space and time. This means that the transformations will be the same regardless of the reference frame or coordinate system chosen.
3. Why are Poincare transformations important?
Poincare transformations are important because they allow us to understand how space and time behave in different reference frames, and are essential in the development of special relativity and the understanding of the principles of causality and the constancy of the speed of light.
4. How are Poincare transformations represented mathematically?
Poincare transformations are typically represented using a set of 4x4 matrices, with each matrix representing a different type of transformation (such as translations, rotations, and boosts) in four-dimensional spacetime. These matrices can be multiplied together to describe the transformation between any two reference frames.
5. Can Poincare transformations be applied to any coordinate system?
Yes, Poincare transformations can be applied to any coordinate system, as long as the system is consistent and follows the principles of special relativity. This is because the transformations are parametrization-independent and do not depend on the specific coordinates used.
