MHB Point (a, b) Reflected About Two Lines
  • Thread starter Thread starter mathdad
    Lines Point
The discussion focuses on reflecting a point (a, b) across the line y = 3x, resulting in the coordinates [(3b - 4a)/5, (3a + 4b)/5]. The participants explore a general method for reflecting points across lines of the form y = mx + k, deriving formulas for the reflected coordinates. They establish the distance from the point to the line and create equations to find the reflected point's coordinates. The derived formulas are confirmed with the specific case of m = 3 and k = 0, leading to the final results for the reflected point. This mathematical approach provides a systematic way to tackle reflection problems in geometry.
mathdad
This question is found in the challenge section of the textbook. This is a two-part question. Like always, I am looking for steps or hints that will allow me to work out the math.
1. If the point (a, b) is reflected in the line y = 3x, show that the coordinates of the reflected points are as follows:
2. If the point (a, b) is reflected in the line y = mx, what are the coordinates of the reflected point?
Mathematics news on Phys.org
What have you tried?
-Dan
Let's generalize the method I posted http://mathhelpboards.com/pre-calculus-21/reflection-about-y-x-20690-post94058.html#post94058 to reflect a given point $(a,b)$ about the line $y=mx+k$, where ($m\ne0$). We will call the reflected point $(a',b')$.
First, we want the distance $d$ between the given point and the line:
$$d=\frac{|ma+k-b|}{\sqrt{m^2+1}}$$
So, we know $(a'b')$ must lie along the line:
$$y=-\frac{1}{m}(x-a)+b$$
Hence:
$$mb'-mb=a-a'\tag{1}$$
We also know the distance from $(a'b')$ to the line must be $d$, so we have:
$$d=\frac{|ma'+k-b'|}{\sqrt{m^2+1}}$$
Thus, we want to look at (to ensure the two points are distinct):
$$ma+k-b=-ma'-k+b'$$
$$b+b'-k=ma+ma'+k\tag{2}$$
From (1), we find:
$$b'=\frac{mb+a-a'}{m}$$
And from (2):
$$b'=ma+ma'-b+2k$$
Hence:
$$\frac{mb+a-a'}{m}=ma+ma'-b+2k$$
Solving for $a'$, there results:
$$a'=\frac{(1-m^2)a+2m(b-k)}{m^2+1}$$
And so plugging this value into either expression for $b'$ above gives us (after simplification):
$$b'=\frac{(m^2-1)b+2(ma+k)}{m^2+1}$$
Now we have a general formula. (Clapping)
In the given problem, we have $m=3$ and $k=0$, thus:
$$a'=\frac{(1-3^2)a+2(3)(b-0)}{3^2+1}=\frac{-8a+6b}{10}=\frac{3b-4a}{5}$$
$$b'=\frac{(3^2-1)b+2((3)a+0)}{3^2+1}=\frac{8b+6a}{10}=\frac{4b+3a}{5}$$
Hence:
From (1), we find:
And from (2):
$$b'=ma+ma'-b+2k$$
Hence:
Thank you very much. Great work!
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
