Point Charge and Charged Sphere; Gauss' Law
In summary, I struggled to properly analyze the situation and decided on the net charge included in the arbitrary symmetrical-shapes used for Gauss's Law. Specifically, this one includes two spherical shells. The attempt at a solution involved first drawing a (not so) arbitrary sphere of radius 7.2 cm so that P is enclosed in the surface. Based off the wording of the problem, I assumed that the total Qenclosed in this arbitrary sphere is 1.1μC. Given this, I calculated 1.1μC/4∏(.072m)2ε° which, evidently, came out to be incorrect. As I referred to earlier, it seems that I am struggling to find out what the actual enclosed
SeanFM21
Gauss' Law has been fairly tough for me and I seem to be struggling to analyze situations properly and, specifically, decided on the net charge included in arbitrary symmetrical-shapes used for this law. Specifically, this one includes two spherical shells.
A point charge q1 = -5.3 μC is located at the center of a thick conducting shell of inner radius a = 2.1 cm and outer radius b = 4.2 cm, The conducting shell has a net charge of q2 = 1.1 μC.
1) What is Ex(P), the value of the x-component of the electric field at point P, located a distance 7.2 cm along the x-axis from q1?
E=Qenc°=∫E (dot) dA
For Spherical Symmetry - E=Qenc/4πr2εo
Initially, I drew a (not so) arbitrary sphere of radius 7.2cm so that P is enclosed in the surface. Based off the wording of the problem, I assumed that the total Qenclosed in this arbitrary sphere is 1.1μC. Given this, I calculated 1.1μC/4∏(.072m)2ε° which, evidently, came out to be incorrect. As I referred to earlier, it seems that I am struggling to find out what the actual enclosed charge is.
Can you explain your reasoning for saying that the total enclosed charge is 1.1uC? How does the q1 charge factor into this problem?
My reasoning was that despite q1 being given an explicit charge, it says that q2=1.1μC represents the net charge, which I interpret as the total charge enclosed by the whole figure. I guess I'm not completely sure how to account for q1? Once I saw that a net charge was given, I assumed that the charge in the shell of radius b=4.2cm was 6.4μC, cancelling out the q1 charge and leaving a net of +1.1μC.
I don't think that's what the problem is saying. I would read that as saying that the total charge on the shell alone is +1.1uC, and then there's an additional charge of -5.3uC inside of the shell. The use of the word "net" to describe the shell just sounds to me like a poor choice of words.
I took a guess at what you were saying, so I ended up getting the problem correctly. May I ask a theoretical/problem solving question for situations like these? Is it always as simple as this problem actually was once I realized I was just misinterpreting the numbers they gave me? Is Gauss Law as simple as finding the total charge enclosed and applying other given conditions to it (depending on the shape of the surface)? In retrospect, this just seems like a very basic problem, but would I be wrong to assume they don't get much harder than this?
Well, they can definitely get trickier than this, but the basic idea behind Gauss's Law problems is always the same: the total field (integrated across the whole surface) is proportional to the total enclosed charge. That makes the problem pretty simple, as long as you can make some deductions about how the total field relates to the field at one point.
For instance, in a problem like this, you know that the field will be spherically symmetric (since the charges are all spherically symmetric). So you know that the field will point straight in/out from the center of the sphere, and be identical in magnitude everywhere. That means that the field at any point is just equal to the total field divided by the area of the sphere, which is why you divided by [itex]4\pi r^2[/itex].
If the problem hadn't had spherical symmetry, it would have been trickier to relate the total surface integral (which is what Gauss's Law tells you) to the strength of the field at one point. The real trick with a Gauss's Law problem is always in picking a surface whose shape will allow you to easily set up that relation between total surface integral and value at the point of interest.
FAQ: Point Charge and Charged Sphere; Gauss' Law
What is a point charge?
A point charge is a hypothetical charge that is considered to be concentrated at a single point in space. It has no physical dimensions and can be either positive or negative. Point charges are often used to simplify calculations in electrostatics.
What is a charged sphere?
A charged sphere is a conductive or insulating object that has a net electric charge. It can be either a hollow sphere with the charge distributed on its surface or a solid sphere with the charge distributed throughout its volume. Charged spheres are commonly used in experiments to study electrostatics.
What is Gauss' Law?
Gauss' Law is a fundamental law in electrostatics that describes the relationship between electric charges and the electric field they create. It states that the electric flux through a closed surface is proportional to the enclosed electric charge. In mathematical terms, it can be written as ∮E·dA = Qenc / ε0, where E is the electric field, dA is an infinitesimal area element, Qenc is the enclosed charge, and ε0 is the permittivity of free space.
How is Gauss' Law used to calculate electric fields?
Gauss' Law can be used to calculate electric fields in situations with high symmetry, such as a point charge or a uniformly charged sphere. By choosing an appropriate Gaussian surface and utilizing the fact that the electric flux through the surface is equal to the enclosed charge divided by the permittivity of free space, the electric field at any point can be found.
Can Gauss' Law be applied to non-symmetric charge distributions?
Yes, Gauss' Law can be applied to non-symmetric charge distributions, but it requires more complex mathematical techniques. In these cases, the surface integral of the electric field must be evaluated using vector calculus. However, the fundamental principle of Gauss' Law remains the same - the electric flux through a closed surface is still proportional to the enclosed charge.
