Point of Maximal Tension for Vertical Circular Motion
In summary, the wire will break when the tension is greatest and when the wire is at its lowest point.
vijayram
A heavy mass m is attached to thin wire and whirled in a vertical circle. Then the wire is most likely to break
A only when mass is at the lowest
B somewhere between lowest point and horizontal point
C only when mass is horizontal
D only when mass is at highest point
T equal to mgcos(theta) + mv2/r
The wire will break when tension is maximum it will be maximum at the bottom ie theta equal to zero so I marked a but answer given is between lowest and horizontal point[/B]
The question is ambiguous. What does "most likely" mean, precisely? And what does "only" mean?
I would have gone for A, but the word "only" would have made me a bit suspicious.
It must be most likely when the tension is greatest, as you calculated.
So the solution is saying that the wire could break somewhere along where the red here touches the outside of the circle.
Perhaps the best way to go about this problem is process of elimination. We understand that C and D are obviously wrong. D because it just doesn't make sense, and C because it is far more likely that the wire will break at some other point.That leaves A and B. Both have in common the fact that the wire could break at the lowest point. At this point, A could only be correct in certain circumstances. It would depend on the exact problem and numbers given, but there are only certain scenarios where an object being swung in a vertical circle could only break at the bottom of its swing. It is possible that the tension in the horizontal point could be enough to break the swing as well as anywhere else in the bottom half of that circle. That is why B is correct.
This is really a poorly-worded question. When it says "only at its lowest", or "only when horizontal", or "only at its highest", it effectively means "exactly" at those angles (0, 90, 180, or 270°). There is zero tolerance on "only". Therefore, the wire is infinitely more likely to break within any non-zero range of angle centered around the lowest point than it would be at any exact angle.
It would be like setting up a lottery where, in order to win, you have to guess the "exact" random number between 0 and 1.
Customer: "Well, how many digits is that?"
Seller: "Well it's not a number of digits, you have to get it exactly right."
Customer: "Okay, I'll give it a shot."
Seller: "Do you want to pick your own random number or would you like a quick pick."
Customer: "Just give me a quick pick."
Seller: "This is amazing! I've never seen anyone come as close to winning as you got. You matched the first 1, 579,687 digits of the random number. Unfortunately, you missed the next digit. Want to try again?"
Also, the angle that it breaks depends on the rate of the angular acceleration. If I chose an infinitesimally small acceleration, I could guarantee that the wire would always break at the lowest point. And if you were so generous as to put a tolerance on "lowest", I could even perform the experimental verification is less than infinite time. :)
Sorry to go on so long about this, but this question just kind of bugged me. :)
I disagree. It asks for "most likely". The maximum likelihood of breaking is precisely at the lowest point.
Likes vijayram
If the required answer is B then it's a poor question.
Is it moving at constant velocity?
Is the thin wire stiff enough that it can be radial?
Related to Point of Maximal Tension for Vertical Circular Motion
What is the Point of Maximal Tension for Vertical Circular Motion?
The Point of Maximal Tension for Vertical Circular Motion is the point at which the tension force in a string or rope attached to a mass moving in a vertical circle is at its maximum.
What factors affect the Point of Maximal Tension for Vertical Circular Motion?
The Point of Maximal Tension for Vertical Circular Motion is affected by the mass of the object, the speed of the object, and the radius of the circular path.
How do you calculate the Point of Maximal Tension for Vertical Circular Motion?
The Point of Maximal Tension for Vertical Circular Motion can be calculated using the equation T = mg + (mv^2)/r, where T is the tension force, m is the mass of the object, g is the acceleration due to gravity, v is the speed of the object, and r is the radius of the circular path.
What is the significance of the Point of Maximal Tension for Vertical Circular Motion?
The Point of Maximal Tension for Vertical Circular Motion is important because it is the point at which the string or rope is under the most stress, and is therefore a critical point to consider when designing structures or devices that involve vertical circular motion.
Can the Point of Maximal Tension for Vertical Circular Motion be exceeded?
Yes, the Point of Maximal Tension for Vertical Circular Motion can be exceeded if the mass, speed, or radius of the circular path are increased beyond certain limits. This can lead to the string or rope breaking, which can be dangerous and should be avoided.
