Pointless in talking about atomic term for a certain micro-state?
In summary: So, it seems that the most important thing is to know the term symbols for a given electron configuration, rather than trying to determine the specific microstate that corresponds to a given term symbol.
bearcharge
28
I'm a chemist trying to understand atomic term symbol.
If we list all the micro-states of certain multi-electron configuration, these micro-states can be grouped into several certain terms characterized by L and S. In other words, when we compute the ML and MS for each of the micro-state, they should belong to certain (L, S) configuration, much analogous to the single electron case where l sets boundary for ml, s for ms. It is legitimate to do so because the operator L and S commute with H, so L and S are good quantum numbers describing the states. After deriving L and S, we use RS coupling scheme to calculate J.
If my understanding is correct, then this point should follow: certain micro-state can arbitrarily belong to several terms. For example, 3d2 contains terms 1D and 3P. A micro-state with ML=1, MS=0 can be either 1D or 3P, right? In that sense, it seems pointless talking about specific term of a micro-state, right?
Usually, the point of listing microstates for equivalent electrons is to determine which term symbols are possible, such that the Pauli exclusion principle is obeyed. For that purpose, microstates are assigned to term symbols without regard to which term symbol they actually belong to. In your example, once you have identified that you have a 1D term and therefore need an ##M_L = 1, M_S=0## microstate, you "remove" one such microstate from the list only to see what other terms you can have.
I would venture to say that in many cases, if you have more than one microstate with a given pair of ##M_L, M_S## values, then these microstates will appear in linear combinations in the actual terms
Thanks for the answer! So can we say what is important is what are the term symbols for a given electron configuration, rather than what is the term symbol for a specific microstate?
Yes. As I said, except for the extreme cases (e.g., maximum ##M_L=L##), you can't say specifically which microstate will belong to which term symbol.
Thanks!
Related to Pointless in talking about atomic term for a certain micro-state?
1. What is the atomic term for a micro-state?
The atomic term for a micro-state is the specific energy level of an atom in a particular electronic configuration.
2. Why is it considered pointless to talk about the atomic term for a certain micro-state?
It is considered pointless because the atomic term is constantly changing due to interactions with other atoms and external factors, making it difficult to pinpoint a specific value.
3. What factors can affect the atomic term for a micro-state?
External factors such as temperature, pressure, and electromagnetic fields can affect the atomic term for a micro-state. Additionally, interactions with neighboring atoms and the overall electronic structure of the atom can also impact the atomic term.
4. Is the atomic term for a micro-state important in understanding atomic behavior?
While the atomic term can provide insight into the energy levels of an atom, it is not the only factor that determines atomic behavior. Other factors such as electron configuration and interatomic forces also play a significant role.
5. How is the atomic term for a micro-state measured or calculated?
The atomic term can be calculated using quantum mechanical models and advanced spectroscopic techniques. These methods allow scientists to determine the energy levels and transitions of atoms in a micro-state.
