Points of intersection of two vector curves
In summary, to find the point(s) of intersection of two curves $r_1(t)$ and $r_2(s)$, we need to find the values of $t$ and $s$ that satisfy the equations $t=7-s$, $2-t=s-5$, and $35+t^2=s^2$. After solving for $t_0$ and $s_0$, we can find the angle of intersection, $\theta$, by finding the tangent vectors $T_1$ and $T_2$ at the intersection point and using the formula $\cos(\theta)={T_1\cdot T_2\over ||T_1||\times||T_2||}$.
carl123
56
a) At what point do the curves r1(t) = (t, 2 − t, 35 + t2) and r2(s) = (7 − s, s − 5, s2) intersect?
(x,y,z) =
b) Find their angle of intersection, θ, correct to the nearest degree.
a) To find the point(s) of intersection of two curves $r_1(t)$ and $r_2(s)$ you want to find those $t$ and $s$ with $r_1(t)=r_2(s)$; i.e. $t=7-s$, $2-t=s-5$ and $35+t^2=s^2$. For this problem, it turns out there is exactly one $t=t_0$ and $s=s_0$ that satisfy these equations. You can find $t_0$ and $s_0$.
b) The angle of intersection of the two curves is the angle between the two tangent vectors at the intersection point. So find $T_1=r_1^\prime(t_0)$ and $T_2=r_2^\prime(s_0)$. Then with $\theta$ the angle of intersection,
$$\cos(\theta)={T_1\cdot T_2\over ||T_1||\times||T_2||}$$
You can finish from here.
FAQ: Points of intersection of two vector curves
What is the definition of points of intersection of two vector curves?
The points of intersection of two vector curves refer to the points where the two curves meet or cross each other on a coordinate plane. These points have the same coordinates on both curves.
How do you find the points of intersection of two vector curves?
To find the points of intersection, you can set the equations of the two vector curves equal to each other and solve for the variables. The resulting values will be the coordinates of the points of intersection.
Can two vector curves have more than one point of intersection?
Yes, two vector curves can have multiple points of intersection. This occurs when the curves cross each other more than once on the coordinate plane.
Do all vector curves intersect?
No, not all vector curves intersect. Some curves may never cross each other, while others may have one or more points of intersection.
How can points of intersection of two vector curves be used in real life applications?
Points of intersection of two vector curves have various real-life applications, such as in physics, engineering, and economics. They can be used to analyze the motion of objects, to determine optimal solutions in optimization problems, and to identify equilibrium points in economic models.
