Points that are symmetric with respect to a circle C
In summary, in a given circle C with center (x nought, y nought) and radius R, if two points P (x nought, y noight tilde) and P prime (x nought, -y nought tilde) are symmetric with respect to the x-axis, then they are also symmetric with respect to Circle C if and only if the y-coordinate of P and P prime, represented by y nought tilde, is equal to the square root of the difference between the square of the circle's y-coordinate and the square of its radius. This can be proven by showing that the product of the lengths CP and CP´ is equal to the square of the circle's radius, given that the length
brcole
Lemma 1: Fix the circle C with center (x nought, y nought); y nought is greater than 0 and
radius R is less than y nought. Consider two points P (x nought, y noight tilde) and P prime (x nought, -y nought tilde) which are symmetric with respect to x-axis by construcion.
Prove that P and P prime are also symmetric with respect to Circle C if and only if y nought tilde is equal to the sqrt (y nought squared - radius squared).
on the attachment
I believe that these two points are orthogonal with respect to the x-axis. and they are symmetric because they fall on the same ray.
Welcome to PF!
on the attachment
Hi brcole! Welcome to PF! :smile:
You're making this too complicated …
all the points are on the same "vertical" line …
so just give every point a name, don't use || of vectors, just talk about the length of lines …
Call (x0,0) Q.
Then you have to prove that CP.CP´ = r2,
and you know what CQ and QP and QP´are … :smile:
FAQ: Points that are symmetric with respect to a circle C
What does it mean for a point to be symmetric with respect to a circle?
When a point is symmetric with respect to a circle, it means that the point lies on the circle and is equidistant from the center of the circle. This creates a mirror image of the point on the other side of the circle.
How can I determine if a point is symmetric with respect to a circle?
To determine if a point is symmetric with respect to a circle, you can use the distance formula. If the distance from the point to the center of the circle is equal to the radius of the circle, then the point is symmetric with respect to the circle.
Can a point be symmetric with respect to multiple circles?
Yes, a point can be symmetric with respect to multiple circles. This means that the point is equidistant from the centers of multiple circles, creating multiple mirror images of the point.
How does the symmetry of a point with respect to a circle affect its coordinates?
If a point is symmetric with respect to a circle, its coordinates will be reflected across the center of the circle. For example, if the original point has coordinates (x,y), the symmetric point will have coordinates (-x,-y).
What are some real-life applications of points that are symmetric with respect to a circle?
Points that are symmetric with respect to a circle are commonly used in geometry and design. They can also be found in nature, such as the formation of bubbles and ripples in water. In technology, they are used in creating 3D images and animations, as well as in computer graphics and image processing.
