MHB Pointwise and uniform convergence
mathmari
MHB
Hey! :o
I want to check the pointwise and uniform convergence for the following sequences or series of functions:
  1. $f_n:[0, \infty)\rightarrow \mathbb{R}, f_n(x)=xe^{-nx}$ for all $n\in \mathbb{N}$
  2. $f_n:[0, \infty)\rightarrow \mathbb{R}, f_n(x)=nxe^{-nx}$ for all $n\in \mathbb{N}$
  3. $f_n:[0, 1]\rightarrow \mathbb{R}, f_n(x)=\sqrt[n]{n^2x}$ for all $n\in \mathbb{N}$
  4. $\displaystyle{\sum_{n=1}^{\infty}\frac{1}{nx-n^2}}$ for $x\in (0,1)$
  5. $\displaystyle{\sum_{n=0}^{\infty}\frac{\sin (x)}{(1+x^4)^n}}$ for $x\in \mathbb{R}$
We have the following:
  • The sequence of functions $(f_n)$ is on $D$ pointwise convergent iff for each $x\in D$ the sequence $(f_n(x))$ is convergent.
  • The series of functions $\displaystyle{\sum_{n=1}^{\infty}f_n}$ is on $D$ pointwise konvergent iff for each $x\in D$ the sequence $(s_n(x))$ is convergent.
  • $(f_n)$ converges on $D$ uniformly to $f: D\rightarrow \mathbb{R}$ iff $\forall \epsilon>0 \ \exists n_0=n_0(\epsilon)\in \mathbb{N}\ \ \forall n\geq n_0 \ \ \forall x\in D: |f_n(x)-f(x)|<\epsilon$.
  • $\displaystyle{\sum_{n=1}^{\infty}f_n}$ converges on $D$ uniformly to $f: D\rightarrow \mathbb{R}$ iff $\forall \epsilon>0 \ \exists n_0=n_0(\epsilon)\in \mathbb{N}\ \ \forall n\geq n_0 \ \ \forall x\in D: |s_n(x)-f(x)|<\epsilon$.
I have done the following:
  1. We have that $$f(x)=\lim_{n\rightarrow \infty}f_n(x)=\lim_{n\rightarrow\infty}\frac{x}{e^{nx}}=0$$
    For each $x\in [0, \infty)$ the sequence $(f_n(x))$ converges. So the sequence of function $(f_n)$ converges on $[0,\infty)$ pointwise to $f$.
    To check the uniform convergence we have that $|f_n(x)-f(x)|=\frac{x}{e^{nx}}$. What do we do next? (Wondering)
  2. We have that $$f(x)=\lim_{n\rightarrow \infty}f_n(x)=\lim_{n\rightarrow\infty}\frac{nx}{e^{nx}}=\lim_{n\rightarrow\infty}\frac{nx}{\frac{\sum_{k=1}^{\infty}(nx)^k}{k!}}=\sum_{k=1}^{\infty}\frac{xk!}{\lim_{n\rightarrow \infty}\left (\frac{nx}{n}+\sum_{k=2}^{\infty}(nx)^{k-1}\right )}=0$$ Is this correct? (Wondering)
    To check the uniform convergence we have that $|f_n(x)-f(x)|=\frac{nx}{e^{nx}}$. How could we continue? (Wondering)
  3. We have that when $x=0$ then $$f(x)=\lim_{n\rightarrow \infty}f_n(x)=\lim_{n\rightarrow \infty}\sqrt[n]{n^2\cdot 0}=0$$
    When $x\in (0,1]$ we have that $$f(x)=\lim_{n\rightarrow \infty}f_n(x)=\lim_{n\rightarrow \infty}\sqrt[n]{n^2x}$$ Is this equal to $1$ ? (Wondering)
For the cases 4. and 5. do we use the Weierstrass criterium? Or do we use the definition? (Wondering)
For the case 5. :
We have that for $x\neq 0$ :
$$\sum_{n=0}^{\infty}\frac{\sin (x)}{(1+x^4)^n}=\sin (x)\sum_{n=0}^{\infty}\left (\frac{1}{1+x^4}\right )^n=\sin (x)\frac{1}{1-\frac{1}{1+x^4}}=\sin (x)\frac{1+x^4}{1+x^4-1}=\sin (x)\frac{1+x^4}{x^4}$$
and for $x=0$ : $$\sum_{n=0}^{\infty}\frac{\sin (x)}{(1+x^4)^n}=0$$
What do we get from that about the pointwise and uniform convergence? (Wondering)
mathmari said:
For the case 5. :
That's good, and it tells you that the series converges pointwise.
To decide about uniform convergence, there are two useful techniques. The Weierstrass M-test is the most useful tool to prove that a series converges uniformly. To show that a series does not converge uniformly, it often helps to use the theorem that a uniformly convergent sequence or series of continuous functions has a continuous limit. So if each term in a sequence or series is continuous but the (pointwise) limit function is not continuous, then the convergence cannot be uniform.
According to the definition of pointwise convergence of a series of functions we have to check if $s_k$ converges for each $x$.
So, we have that for $x\neq 0$ :
$$s_k=\sum_{n=0}^{k}\frac{\sin (x)}{(1+x^4)^n}=\sin (x)\sum_{n=0}^{k}\left (\frac{1}{1+x^4}\right )^n=\sin (x)\frac{1-\left (\frac{1}{1+x^4}\right )^{k+1}}{1-\frac{1}{1+x^4}}=\sin (x)\frac{1-\frac{1}{(1+x^4)^{k+1}}}{1-\frac{1}{1+x^4}}=\sin (x)\frac{(1+x^4)^{k+1}-1}{(1+x^4)^{k+1}-(1+x^4)^k}=\frac{\sin (x)}{(1+x^4)^k}\left (\frac{(1+x^4)^{k+1}-1}{1+x^4-1}\right )=\frac{\sin (x)}{x^4(1+x^4)^k}\left ((1+x^4)^{k+1}-1\right )$$
and for $x=0$ we have : $s_k=\sum_{n=0}^{k}\frac{\sin (x)}{(1+x^4)^n}=0$.
So, in each case $s_k$ is convergent. Therefore, $\sum_{n=0}^{\infty}\frac{\sin (x)}{(1+x^4)^n}$ convergence pointwise.
mathmari said:
For the case 5. :
We have that $\frac{\sin (x)}{(1+x^4)^n}$ is continuous as a fraction of continuous functions, right? (Wondering)
To check if the limit function is continuous we have to check it at $x=0$ :
We have that $$\lim_{x\rightarrow 0}\sin (x)\frac{1+x^4}{x^4}=\lim_{x\rightarrow 0}\sin (x)\left (\frac{1}{x^4}+1\right )=\lim_{x\rightarrow 0}\frac{\sin (x)}{x^4}+\lim_{x\rightarrow 0}\sin (x)=\lim_{x\rightarrow 0}\frac{\sin (x)}{x}\frac{1}{x^3}=1\cdot \infty=\infty\neq 0$$
So, it is not continuous at $x=0$, and therefore the series does not converge uniformly. Is this correct? (Wondering)
For 4. we have the following:
Since $0<x<1\Rightarrow 0<nx<n\Rightarrow -n<-nx<0\Rightarrow n^2-n<n^2-nx<n^2$ we have that $$\frac{1}{n^2-nx}<\frac{1}{n^2-n}=\frac{1}{n(n-1)}=\frac{1}{n-1}-\frac{1}{n}$$
Since the series $\sum_{n=2}^{\infty}\left (\frac{1}{n-1}-\frac{1}{n}\right )$ converges, we have from the Weierstrass criterion that the sum $\sum_{n=2}^{\infty}\frac{1}{nx-n^2}$ converges uniformly.
So, the series $\sum_{n=1}^{\infty}\frac{1}{nx-n^2}=\frac{1}{x-1}+\sum_{n=2}^{\infty}\frac{1}{nx-n^2}$ converges also uniformly.
And from that it follows that the series converges also pointwise.
Or dowe have to take into consideration that if $x\rightarrow 1$ then $\rightarrow \infty$ ? (Wondering)
For the case 1. I have done the following:
From the definition ofthe exponential function we have that $e^{nx}=\sum_{k=1}^{\infty}\frac{(nx)^k}{k!}\geq \frac{(nx)^2}{2}$. So, $\frac{1}{e^{nx}}\leq \frac{2}{n^2x^2}$.
Therefore, we have that \begin{equation*}|f_n(x)-f(x)|=\left |\frac{x}{e^{nx}}\right |=\frac{x}{e^{nx}}\leq \frac{2x}{n^2x^2}=\frac{2}{n^2}\end{equation*}
It holds that $\lim_{n\rightarrow \infty}\frac{2}{n^2} =0$.
So, $(f_n)$ converges uniformly.
For the case 3. I have done the following:
The limit function is \begin{equation*}f(x)=\left\{\begin{matrix}
0 & x=0\\
1 & x \in (0,1]
\end{matrix}\right.\end{equation*}
We have that $\sqrt[n]{n^2x}$ is continuous, or not? (Wondering)
We have that \begin{equation*}\lim_{x\rightarrow 0}f(x)=1\neq 0\end{equation*}
So, $f$ is not continuous at $x=0$ and therefore $(f_n)$ does not converge uniformly. Is everything correct? (Wondering) Could you give me a hint for the case 2. ? (Wondering)
The world of 2\times 2 complex matrices is very colorful. They form a Banach-algebra, they act on spinors, they contain the quaternions, SU(2), su(2), SL(2,\mathbb C), sl(2,\mathbb C). Furthermore, with the determinant as Euclidean or pseudo-Euclidean norm, isu(2) is a 3-dimensional Euclidean space, \mathbb RI\oplus isu(2) is a Minkowski space with signature (1,3), i\mathbb RI\oplus su(2) is a Minkowski space with signature (3,1), SU(2) is the double cover of SO(3), sl(2,\mathbb C) is the...
