Poisson again - totally stumped as compressive column?
In summary: You are wondering if the second symbol is for the modulus of elasticity or thePoissons ratio. The second symbol is for the Poissons ratio.(3) The expected strain is calculated based on the load and the length of the column.(4) The strain gauge is used to measure the strain in the horizontal plane.
LDC1972
65
Column supports a mass on its' top. So force is downwards.
Column properties:
Do = 50mm (outer dia)
Di = 40mm (inner dia)
E = 250 GNm^-2 (modulus of elasticity)
V = 0.33 (Poissons ratio)
Poissons ratio = Transverse strain = - εt / εl
Transverse strain εt = (Reduction in Diameter - Original Diameter) / Original Diameter
Axial strain = Transverse strain / V
Δd = εtd
ε = εt / -V
ε = σ / E
σ = F/A
Those that saw my recent post will realize I've worked out how to calculate axial strain / transverse strain etc.
But that was where strain was 'pulling' a member and thereby reducing its' diameter and increasing its' length.
This problem is the opposite! There are also some additional technical questions related to strain gauges and wheatstone bridges. But I'll discuss this with my tutor Monday when he is available...
In the mean time I want to crack the first part of the problem.
The question:
Sketch a graph of expected strain against applied load, for the range 0 to 500kg. Make load the horizontal axis and strain the vertical.
The column is fixed vertically and the mass is placed on top.
So intuitively the diameter will increase and the length will decrease.
My first question is do I apply the same formula as before in my last post? Or will being a column effect the required equations?
My previous workings:
(0.3999 - 0.4000) / 0.4000 = -0.00025 Transverse strain (εt)
-0.00025 / 0.3 = .00083333333 Axial strain
I confirmed these by dividing Transverse strain by Axial strain = -0.3
Since decrease in diameter = transverse strain x Original Diameter then:
Δd = εtd = -0.00025 x .40 = 0.1mm which is correct.
As εt = -Vε Then:
-0.00025 = -0.3 x ε
ε = εt / -V
ε = 0.00083333333
ε = σ / E
σ is unknown ∴
σ = ε x E
σ = 16666666 Pa (stress value)
σ = F / A
Force = σ x A (Area)
So far I have done the following:
Calculated area by A = ∏/4 [(0.05m^2) - (0.04m^2)]
A = 7.0685834 x10^-4 m^2
E = 250 x10^9 Nm^-2
l = 0.2m
Force = mass x gravity
I calculated force at 50kg intervals to 500kg
So F = 490.5N @ 50kg
to F = 4905N @ 500kg
I then calculated stress as σ = F/A , using the 10 values of force I derived.
So σ = 693915.6 Pa @ 490.5N
to σ = 6939155.6 Pa @ 4905N
So I believe I have the load (force) worked out to plot already correctly?
And can use ε = σ / E to calculate strain for the vertical axis?
Many many thanks,
Lloyd
How to calculate strain against an applied load on top of a column
This question: (I also posted in Engineering but had no replies :-(, but have since done more work, so hopefully will get a nudge?).
Tubular column supports a mass on top (column is vertical). X is the horizontal, Y is the vertical.
Outside diameter = 50mm
Inside diameter = 40mm
Modulus (youngs) = 250 GN m^-2
Poison's = 0.33
Mass varies from 0 - 500kg.
Column length = 200mm
A strain gauge is applied to the column and measures strain in the horizontal plane.
Ignore the weight of the column for all calculations.
Q1: Sketch a graph of the expected strain against the applied load, for the range 0 - 500kg. Make the load the horizontal axis on the graph and the train the vertical axis.
Area = ∏/4 [(Do^2) - (Di^2)]
F = mg
σ = F/A
ε = σ/E
So using the above equations, and from the question, I don't think the strain gauge position is relevant (yet - there are more questions after). I "think" the question is saying calculate strain downwards? On this basis I have done the following:
Area = ∏/4 [(Do^2) - (Di^2)] = 7.0685834x10^-4 m^2 (I've ignored the length for area, as most examples for strain do this in the examples in book but am unsure if I'm right to omit the length?)
Calculated F = mg for values 50kg to 500kg in ten increments giving 490.5N to 4905N
Calculated σ = F/A for above F values giving 693915.55Pa to 6939155.59Pa
Calculated ε = σ/E for above values giving 0.00000277566 to 0.00002775662
Plotted a graph with x-axis Load(kg) 0 to 500kg and y-axis strain (ε x10^-6) 0 to 28
My graph looks good as a straight diagonal line with strain increasing from 0 to 27.75662 x10^-6 at 500Kg.
Does that seem right?
Thank you!
LDC1972: The answers to your four questions in post 1 are, yes, no, yes, yes. The answer to your last question in post 2 is, yes.
(1) By the way, always leave a space between a numeric value and its following unit symbol. E.g., 0.2 m, not 0.2m. See the international standard for writing units (ISO 31-0).
(2) Two unit symbols multiplied together must be separated by, e.g., an asterisk or a space. E.g., N*m, not Nm.
Likes 1 person
Thank you for the reply.
I do apologise for the messy post and double posting(!) - I've been "told off"!
Thanks for the reply, I'm going to keep at this all week, it's a long question in the whole part...
Further help / confirmation needed please?
Question 1: calculate change in column length:
I have done the change in ten increments of 50 kg through to 500 Kg. But to keep the post short, for ultimate length at 500 kg / 4905 N = Δl = εlo (change in length = strain value at 4905 N x original length) =
27.75662x10^-6 m x 0.2 m = 0.005551324mm
Lo - Δl = 199.9944487 mm
Question 2: Here's where I'm getting confused! Question is increase in diameter? Now, once I have these values I can start to also get strain in the horizontal plane as well, which leads me nicely to sorting out the most appropriate positioning of the strain gauge.
What I have done so far:
Increase in diameter at maximum load (500 Kg / 4905 N):
εl = Δl / lo (compressive strain = change in length / original length)
εl = 0.00000555132 m / 0.2 m = 0.0000277566
εt = Δd/ do (expansion strain = change in diameter / original diameter)
Δd = unknown, therefore:
We do know poisson's = 0.33, therefore:
v = εt / εl transpose to
εt = v x εl = 0.33 x 0.0000277566
εt = 0.00000915967 (expansion strain).
Δd = εtd = 0.00000915967 m x 0.05 m = 0.00045798 mm (expansion strain at 500kg load of outer diameter of column).
If the above is right then I can proceed with the question change in inner diameter in same manner? And having those values calculate strain in the horizontal plane?
Thank you...
Poison's = 0.33
F = mg
σ = F/A
ε = σ/E
Thank you!
I've just realized that these values should be negative as stress and strain are are compressive in the vertical plane?
FAQ: Poisson again - totally stumped as compressive column?
What is a Poisson distribution?
A Poisson distribution is a probability distribution that is used to model the number of times an event occurs in a specific time period or space, given that the event occurs randomly and independently. It is named after French mathematician Siméon Denis Poisson and is often used in fields such as statistics, physics, and finance.
How is a Poisson distribution different from a normal distribution?
A normal distribution is a continuous probability distribution that is symmetrical around the mean, while a Poisson distribution is a discrete probability distribution that measures the number of occurrences of an event within a specific time period or space. Additionally, a normal distribution can take on any value, while a Poisson distribution only takes on non-negative integer values.
What is a compressive column?
A compressive column is a structural element that is designed to support a compressive load or force. It is typically used in construction and engineering to provide stability and resistance against buckling.
How does Poisson's ratio affect a compressive column?
Poisson's ratio is a material property that measures the ratio of lateral strain to axial strain when a material is under stress. In a compressive column, a higher Poisson's ratio can lead to a decrease in the column's ability to resist buckling. This is because a higher Poisson's ratio means the material is more likely to deform laterally when compressed, making it less stable.
How can the Poisson distribution be used to understand compressive columns?
The Poisson distribution can be used to model the number of times a compressive column experiences a specific amount of load before buckling. By understanding the probability of different load levels occurring, engineers can design compressive columns that are more likely to resist buckling under expected loads.
