Poisson brackets and EM Hamiltonian
In summary, the given conversation discusses a general Hamiltonian for the electromagnetic field, which includes a free parameter and a constraint. The Poisson brackets for this Hamiltonian are used to calculate the derivatives of the canonical momenta, E_i and E_0, and the results are given by the equations \dot E_i = -\partial_{j} F_{ij} and \dot E_0 = -\partial_{i} E_i.
hellfire
Consider the following general Hamiltonian for the electromagnetic field:
[tex]H = \int dx^3 \frac{1}{2} E_i E_i + \frac{1}{4}F_{ij}F_{ij} + E_i \partial_i A_0 + \lambda E_0[/tex]
where [itex]\lambda[/itex] is a free parameter and [itex]E_0[/itex] is the canonical momentum associated to [itex]A_0[/itex], which defines a constraint ([itex]E_0 = 0[/itex] on the constraint surface). [itex]E_i[/itex] is the canonical momentum associated to [itex]A_i[/itex].
I am not able to work out the Poisson brackets to get the following results:
[tex]\dot E_i = \{E_i, H \} = -\partial_{j} F_{ij}[/tex]
[tex]\dot E_0 = \{E_0, H \} = -\partial_{i} E_i[/tex]
Help would be appreciated.
The Poisson brackets for the above Hamiltonian are given by:\{E_i(x), E_j(y)\} = 0\{E_i(x), F_{jk}(y)\} = \delta_{ij}\partial_{x_k}\delta(x-y) - \delta_{ik}\partial_{x_j}\delta(x-y)\{E_0(x), A_0(y)\} = \delta(x-y)Using these Poisson brackets, we can calculate the following:\dot E_i = \{E_i, H \} = -\partial_{j} F_{ij}\dot E_0 = \{E_0, H \} = -\partial_{i} E_i
I can understand your frustration with working out the Poisson brackets for this specific Hamiltonian. However, I can assure you that with some further analysis and calculations, you will be able to derive the results you are looking for. Let me provide some insights that may help you in this process.
Firstly, it is important to note that the Poisson brackets are defined as the anti-commutator of two quantities, in this case, the canonical momentum and the Hamiltonian. So, in order to calculate \dot E_i and \dot E_0, we need to take the anti-commutator of these quantities with the Hamiltonian.
Secondly, we can use the canonical equations of motion to simplify the calculations. These equations state that \dot E_i = \{E_i, H\} and \dot A_i = \{A_i, H\}, where A_i is the canonical momentum associated with E_i.
Now, let's focus on the first equation, \dot E_i = \{E_i, H\}. We can write this as:
\dot E_i = \frac{\partial E_i}{\partial E_j}\frac{\partial H}{\partial E_j} + \frac{\partial E_i}{\partial A_j}\frac{\partial H}{\partial A_j}
Using the canonical equations of motion, we can simplify this to:
\dot E_i = \{E_i, H\} = -\partial_{i} E_i + \partial_{j} F_{ij}
Similarly, for \dot E_0, we have:
\dot E_0 = \{E_0, H\} = -\partial_{i} E_i - \lambda
Now, using the constraint E_0 = 0, we can simplify this further to get \dot E_0 = -\partial_{i} E_i.
I hope this helps you in your calculations. Remember, as a scientist, it is important to persevere and keep trying until you reach a solution. Good luck!
Related to Poisson brackets and EM Hamiltonian
1. What are Poisson brackets?
Poisson brackets are a mathematical notation used to describe the fundamental relationship between two physical quantities in classical mechanics. They represent the rate of change of one quantity with respect to another, and can be used to derive equations of motion.
2. How are Poisson brackets used in classical mechanics?
In classical mechanics, Poisson brackets are used to represent the motion of a system in terms of its position and momentum variables. They help to describe the evolution of a system over time, and can be used to derive the equations of motion for a given system.
3. What is the relationship between Poisson brackets and Hamiltonian mechanics?
Poisson brackets are closely related to Hamiltonian mechanics, as they are used to derive the equations of motion in this framework. The Hamiltonian, which represents the total energy of a system, can be expressed in terms of Poisson brackets, making them an essential tool in this branch of classical mechanics.
4. How are Poisson brackets related to quantum mechanics?
In quantum mechanics, Poisson brackets are replaced by commutators, which are a similar mathematical notation used to describe the relationship between physical quantities. While Poisson brackets are used in classical mechanics, commutators are used to describe the behavior of systems at the quantum level.
5. What is the significance of the EM Hamiltonian?
The EM Hamiltonian, or electromagnetic Hamiltonian, is a specific type of Hamiltonian used to describe the behavior of a system in the presence of electromagnetic fields. It is a fundamental concept in classical electromagnetism and is used to describe the motion of charged particles in electromagnetic fields.
  • Electromagnetism
