Poisson brackets for simple harmonic oscillator
In summary, using the given Hamiltonian and canonical transformation, it can be shown that all three identities are satisfied between the coordinates q, Q and the momenta p, P. This demonstrates the simplification of equations of motion through canonical transformations.
Siberion
33
Considering the Hamiltonian for a harmonic oscillator:
[itex]H=\frac{p^2}{2m}+\frac{mw^2}{2}q^2[/itex]
We have seen that the equations of motion are significantly simplified using the canonical transformation defined by [itex]F_1(q,Q)=\frac{m}{2}wq^2cot(Q)[/itex]
Show explicitly that between both coordinates, the following identities are satisfied
1) [itex][q,p]_{qp}=[Q,P]_{QP}[/itex]
2) [itex][q,p]_{QP}=[q,p]_{QP}[/itex]
3) [itex][Q,P]_{qp}=[Q,P]_{QP}[/itex]
where [ ] denote Poisson Brackets
This is a well known Hamiltonian frequently used to introduce canonical transformations in many books (e.g. Goldstein 378). Given the generating function presented above, we find the following expresions for the new coordinates:
[itex]p=\sqrt{2Pmw}cos(Q)[/itex]
[itex]q=\sqrt{\frac{2P}{mw}}sin(Q)[/itex]
Also, from the definition of Poisson Brackets,
[itex][u,v]_{qp}=\frac{\partial{u}}{\partial{q}}\frac{\partial{v}}{\partial{p}}-\frac{\partial{u}}{\partial{p}}\frac{\partial{v}}{\partial{q}}[/itex]
Well, by definition,
[itex][q,p]_{qp}=1=[Q,P]_{QP}[/itex]Also, using the expressions for p and q presented above, we have
[itex][q,p]_{QP}=cos^2(Q)+sin^2(Q)=1=[q,p]_{qp}[/itex]
Am I missing some fundamental formalism in here? I'm far from confident about this topic, so I'm not sure I followed the right procedure.
Also, for 3) I was thinking about obtaining expressions for Q and P straight from the presented expressions for p and q, and then just apply the same principle. What do you think about this?Thanks for your help and time! :smile:
Your approach is correct for the first two identities. For the third identity, you can indeed obtain expressions for Q and P from the given expressions for p and q, and then apply the same principle. This will show that [Q,P]_{qp} is equal to [Q,P]_{QP}. Overall, your solution is correct and you have successfully shown that all three identities are satisfied.
Related to Poisson brackets for simple harmonic oscillator
What is a Poisson bracket in the context of a simple harmonic oscillator?
A Poisson bracket is a mathematical operation used to calculate the time evolution of a system in classical mechanics. In the context of a simple harmonic oscillator, it measures the rate of change of one variable with respect to another, and is used to determine the equations of motion for the system.
How is a Poisson bracket calculated for a simple harmonic oscillator?
The Poisson bracket for a simple harmonic oscillator can be calculated using the formula {A, B} = ∂A/∂x * ∂B/∂p - ∂A/∂p * ∂B/∂x, where A and B are any two variables of the system, x is the position coordinate, and p is the momentum coordinate.
What is the physical significance of a Poisson bracket for a simple harmonic oscillator?
The Poisson bracket for a simple harmonic oscillator is physically significant because it represents the fundamental relationship between position and momentum in classical mechanics. It allows us to determine how the position and momentum of the oscillator change over time, and therefore understand the behavior of the system.
How does the value of the Poisson bracket affect the motion of a simple harmonic oscillator?
The value of the Poisson bracket can have a significant impact on the motion of a simple harmonic oscillator. If the Poisson bracket is zero, the system is in equilibrium and the motion will be stable. If the Poisson bracket is non-zero, the system is not in equilibrium and the motion will be oscillatory.
Can the Poisson bracket be used to analyze systems other than a simple harmonic oscillator?
Yes, the Poisson bracket can be used to analyze any classical mechanical system. It is a fundamental concept in Hamiltonian mechanics and is used to study the dynamics of a wide range of physical systems, including those in celestial mechanics, fluid mechanics, and quantum mechanics.
