Poisson distribution, likelihood ratios
In summary, we can see that the likelihood ratio test for this problem is a simple comparison between the sum of the data points and a constant value. This makes it a straightforward and easy to interpret test. Thank you for your attention.
Auron87
An independent, identically distributed sample, x = (x1, ... , xn) of size n, is drawn from a Poisson distribution, parameter A. We want to test the null hypothesis H0 : A = A1 against the alternative hypothesis H1 : A = A2 where A1 < A2.
Write down the likelihood ratio for the data, and show that all likelihood ratio tests of H0 against H1 are of the form: - Reject H0 if the sum from one to n of xi > c.
LR(x) = f1(x)/f2(x)
f0(xi) = (e^(-A1)*A1^xi) / xi!
f1(xi) = (e^(-A2)*A2^xi) / xi!
Then I'm not sure if this is right but I thought each f(x) is equal to the product of its f(xi)
so I have f0(x) = (e^(-A1)*A1^(sum of xi's from 1 to n)) / x1! ... xn!
Sorry don't know if I can put it sigma signs but don't know how and then obviously f1(x) is the same but with A2 instead.
So that gave me after some simplifying
LR(x) = e^(A1 - A2)*(A2/A1)^(sum of xi's)
Now I'm not sure if this is quite right or if I can simplify it further? Any help is much appreciated, thankyou.
Thank you for your post. Your approach to finding the likelihood ratio for this problem is correct. However, there are a few things that can be clarified and simplified.
Firstly, when finding the likelihood ratio, it is common to use the natural logarithm of the ratio instead of the ratio itself. This is because the natural logarithm is a monotonic function, meaning that it preserves the order of the values. This allows us to work with simpler expressions and still make the same decisions about whether to reject the null hypothesis or not.
Secondly, instead of finding the likelihood ratio for each individual xi, we can find the likelihood ratio for the entire data set x at once. This is because the data is independent and identically distributed, so the same likelihood ratio applies to each xi in the data set.
With these things in mind, we can simplify the expression for the likelihood ratio as follows:
LR(x) = ln(f1(x)/f0(x))
= ln((e^-A2*A2^Σxi)/Πxi!) / (e^-A1*A1^Σxi)/Πxi!)
= ln(e^(A1-A2)*(A2/A1)^(Σxi)/Πxi!) / e^-A1*A1^Σxi
= ln(e^(A1-A2)*(A2/A1)^(Σxi)) - ln(e^-A1*A1^Σxi)
= (A1-A2) + Σxi*ln(A2/A1) - (-A1*Σxi)
= (A1-A2) + Σxi*ln(A2/A1) + A1*Σxi
= A1 + Σxi*ln(A2/A1)
= A1 + n*ln(A2/A1)
So now we have a simplified expression for the likelihood ratio that only depends on the parameter values A1 and A2, and the sample size n. This makes it easier to see that the likelihood ratio test is of the form:
- Reject H0 if A1 + Σxi*ln(A2/A1) > c
or equivalently,
- Reject H0 if Σxi > c' where c' is some constant determined by the values of A1 and A2.
I hope this helps clarify the solution for you. If you have any further questions, please don't hesitate to
Related to Poisson distribution, likelihood ratios
1. What is the Poisson distribution?
The Poisson distribution is a probability distribution that is used to model the number of events that occur in a fixed interval of time or space. It is often used to analyze data related to rare events, such as the number of accidents in a given time period.
2. How is the Poisson distribution different from other probability distributions?
The Poisson distribution is different from other distributions because it only has one parameter, the mean, which represents the average number of events that occur in a given time or space. It also assumes that the events occur independently and at a constant rate.
3. What is a likelihood ratio?
A likelihood ratio is a measure used to assess the strength of evidence for a particular hypothesis. It compares the likelihood of the data under the null hypothesis to the likelihood of the data under the alternative hypothesis.
4. How is the likelihood ratio used in statistical analysis?
The likelihood ratio is used in statistical analysis to help determine the most likely hypothesis given the data. It is often used in hypothesis testing and model selection to compare the fit of different models.
5. Can the Poisson distribution and likelihood ratios be used for any type of data?
The Poisson distribution and likelihood ratios are most commonly used for count data, such as the number of events or occurrences. However, they can also be used for continuous data if it can be approximated by a count variable.
48K
