A Polar Fourier transform of derivatives
hunt_mat
TL;DR Summary
Computing Fourier transforms is simple in Cartesian co-ordinates but how do you do it for polar co-ordinates?
The 2D Fourier transform is given by: \hat{f}(k,l)=\int_{\mathbb{R}^{2}}f(x,y)e^{-ikx-ily}dxdy
In terms of polar co-ordinates: \hat{f}(\rho,\phi)=\int_{0}^{\infty}\int_{-\pi}^{\pi}rf(r,\theta)e^{-ir\rho\cos(\theta-\phi)}drd\theta
For Fourier transforms in cartesian co-ordinates, relating the Fourier transform of a derivative of a function to the Fourier transform of the function. However, what happens with the polar Fourier transform? I've done a simple calculation for the r-derivative and I get:
\widehat{\frac{\partial f}{\partial r}}=-\rho\sum_{n\in\mathbb{Z}}\int_{0}^{\infty}rf_{n}(r)J_{n-1}(r\rho)dr
This is after I expanded f(r,\theta) as a Fourier series:f(r,\theta)=\sum_{n\in\mathbb{Z}}f_{n}(r)e^{in\theta}
I feel a little lost at this point. Can anyone suggest anything?
hunt_mat said:
TL;DR Summary: Computing Fourier transforms is simple in Cartesian co-ordinates but how do you do it for polar co-ordinates?
The 2D Fourier transform is given by: \hat{f}(k,l)=\int_{\mathbb{R}^{2}}f(x,y)e^{-ikx-ily}dxdy[\tex]<br />
<br /> Did you mean to type this? <br /> The 2D Fourier transform is given by: ##\hat{f}(k,l)=\int_{\mathbb{R}^{2}}f(x,y)e^{-ikx-ily}dxdy##
I was correcting my memory on how to include LaTeX here, you'll see that it's corrected now.
Search for "Hankel transform". The Wikipedia article doesn't give an expression for the transform of a derivative, but differentiating the inverse transform and using Bessel function identities should work.
Likes vanhees71 and hunt_mat
I had a feeling that this would be the case. A lot of my undergraduate was pure maths, mainly analysis and mathematical physics. Solving PDEs was something I had to teach myself about.
This is about a water wave problem, looking for the free surface from a vorticity distribution. The azimuthal component will be the most important.
There is the following linear Volterra equation of the second kind $$ y(x)+\int_{0}^{x} K(x-s) y(s)\,{\rm d}s = 1 $$ with kernel $$ K(x-s) = 1 - 4 \sum_{n=1}^{\infty} \dfrac{1}{\lambda_n^2} e^{-\beta \lambda_n^2 (x-s)} $$ where $y(0)=1$, $\beta>0$ and $\lambda_n$ is the $n$-th positive root of the equation $J_0(x)=0$ (here $n$ is a natural number that numbers these positive roots in the order of increasing their values), $J_0(x)$ is the Bessel function of the first kind of zero order. I...
Are there any good visualization tutorials, written or video, that show graphically how separation of variables works? I particularly have the time-independent Schrodinger Equation in mind. There are hundreds of demonstrations out there which essentially distill to copies of one another. However I am trying to visualize in my mind how this process looks graphically - for example plotting t on one axis and x on the other for f(x,t). I have seen other good visual representations of...
