Polarisation (light on water surface)
In summary: Therefore, your explanation seems to be correct. In summary, when the polaroid is oriented parallel to the plane of the horizontally polarized light, it is absorbed and the puddle appears darker. When it is oriented perpendicular, the light is transmitted and the puddle appears brighter due to the remaining glare.
ravsterphysics
57
A student looks at the sunlight reflected off a puddle of water. She puts a polarising (Polaroid) filter in front of her eye. As she rotates the filter the puddle appears darker then lighter.
Explain this observation
Here's my answer:
"As the student rotates the filter so it is in the same plane of polarisation of the polarised light, the wave will be absorbed (ie blocked) thus the puddle will appear darker.
And when it is rotated so it is perpendicular to the plane of polarisation of the reflected wave, the wave is no longer absorbed so the glare remains and the puddle will appear brighter''
But according to the mark scheme this would be wrong because ''When planes are parallel puddle appears light OR when perpendicular puddle appears dark''
where have i gone wrong? since the light is reflected horizontally, wouldn't the filter that is perpendicular to the light NOT block out the light, thus making the puddle appear brighter? (because the glare remains)
Here's my answer:
I think you have the concept right, but it is probably just a convention in how the "direction" of the polarizer is defined. I'm most familiar with saying that light that is polarized in the same direction as the polarizer makes it through. But you are correct that the physical stretching/alignment of a Polaroid filter is the direction that absorbs the light. Have a look at this wikipedia page, for example:
https://en.wikipedia.org/wiki/Polarizer
Likes ravsterphysics
Okay using the above information, is this valid:
"Since reflected light is horizontally polarised, if the polaroid is oriented so it is perpendicular to the plane of the reflected light, the puddle will appear darker because the reflected light has been absorbed, ie blocked, because only light that is in the same direction as the polaroid is allowed through.
Whereas when the polaroid is oriented so it is parallel to the reflected light, the glare remains because the reflected light is in the same plane as the polaroid so it is let through thus the puddle appears brighter."
The way I read the wiki article, when the plane of the polarized light is parallel to the stretched direction of the Polaroid film, it is absorbed.
Stretching of the sheet during manufacture causes the PVA chains to align in one particular direction. Valence electrons from the iodine dopant are able to move linearly along the polymer chains, but not transverse to them. So incident light polarized parallel to the chains is absorbed by the sheet; light polarized perpendicularly to the chains is transmitted.
Related to Polarisation (light on water surface)
1. What is polarisation of light on water surface?
Polarisation of light on water surface refers to the phenomenon where light waves become aligned in a specific direction as they reflect off the surface of water. This results in a polarised reflection of light, which can be observed as a shimmering effect on the water's surface.
2. What causes polarisation of light on water surface?
The polarisation of light on water surface is caused by the interaction between the light waves and the water molecules. As the light waves hit the water's surface, they become partially absorbed and partially reflected. The reflected light waves become polarised due to the orientation of the water molecules, which act as tiny mirrors and align the light waves in a specific direction.
3. Can polarisation of light on water surface be seen with the naked eye?
Yes, polarisation of light on water surface can be seen with the naked eye. The shimmering effect on the water's surface is a visible indication of polarised light. However, polarised sunglasses can enhance the visibility of this phenomenon.
4. How does polarisation of light on water surface affect animals?
Many animals, such as fish and insects, have the ability to detect polarised light and use it for navigation, finding food, and avoiding predators. The polarisation of light on water surface can also help animals to detect water sources, as it appears different from surrounding land surfaces.
5. Is polarisation of light on water surface important for humans?
While polarisation of light on water surface does not directly affect humans, it can have practical applications, such as reducing glare and improving visibility in certain situations. It can also be used in photography and filmmaking to create visually stunning effects.
