Polariton Beams Provide Coherent Energy for 250x Less Power
In summary: Scientists have developed a new type of laser, called a polariton laser, which can be generated using 250x less power. This might be useful in applications involving microelectronics.
sanman
745
24
Scientists have developed a new type of laser, called a polariton laser, which can be generated using 250x less power:
http://www.eurekalert.org/pub_releases/2014-06/uom-anw060514.php
Polariton beams are said to have properties of both matter and light, since polaritons are a combination of a photon and an electron-hole pair. Could these unique properties provide benefits for a laser-sintering or electron-beam melting type of device?
After all, if energy-savings are involved, then that would be one way to improve performance. Furthermore, electron-beam melting is said to be useful for its very high energy levels, which allow it to melt higher-temperature metals, and to shape parts at high-resolution, since the heavier mass of the electron means its DeBroglie wavelength is lower.
What might be the pro's and cons of applying polariton beams towards additive manufacturing applications?
Likewise, could polariton beams be used for spectrometry, or LIDAR, or even fusion energy (a la NIF) for the benefit of these applications?
Science news on Phys.org
Lasers are generally pretty efficient. The little laser diode in your computer mouse, for example, is about 50% efficient in converting electrical energy into light energy. That's why your mouse does not heat up when you leave it on.
So I am quite certain a polariton laser is not 250x more efficient than a laser. I think it simply means that polariton lasers can be made a lot smaller and very low power, which may be useful in applications involving microelectronics.
Since industrial applications for lasers, such as very accurate cutting of materials, require very powerful lasers, I expect that conventional lasers will continue to be used.
AM
Related to Polariton Beams Provide Coherent Energy for 250x Less Power
What is a polariton beam?
A polariton beam is a type of light beam that is composed of both photons (particles of light) and excitons (quasiparticles that form when an electron and a hole are bound together). It is created by shining a laser onto a semiconductor material, which results in the formation of polaritons.
How do polariton beams provide coherent energy?
Polariton beams provide coherent energy by using a process called polariton condensation. This involves the polaritons in the beam all occupying the same quantum state, which leads to coherence and allows the energy to be efficiently transferred and used.
Why is the use of polariton beams important?
The use of polariton beams is important because it has the potential to greatly reduce the amount of energy needed to power certain devices. By providing coherent energy at a much lower power, polariton beams could lead to more efficient and sustainable energy usage.
What are the potential applications of polariton beams?
Polariton beams have potential applications in various fields, such as optoelectronics, telecommunications, and quantum computing. They could also be used to create new types of sensors and imaging devices.
How does the use of polariton beams compare to traditional energy sources?
Polariton beams have the potential to be much more energy-efficient than traditional energy sources. In fact, they have been shown to require 250 times less power to produce coherent energy. This could lead to significant cost savings and a reduction in carbon emissions. However, further research and development is needed before polariton beams can be widely used as an energy source.
  • Astronomy and Astrophysics
  • Science and Math Textbooks
17K
