Polarization of Laser vs Sunlight
In summary, the conversation discusses implementing a computer vision system with a near-infrared laser and a NIR bandpass filter. The user is experiencing interference from sunlight and is considering using a polarizing filter to cut out some of the sunlight. They ask about the polarization of laser light and if there are other ways to reduce sunlight interference. Suggestions are given, including checking the specifications of the laser, using wave plates to change polarization, and accounting for the changing polarization of sunlight throughout the day. Additional resources are also provided for further learning.
nepstein
Hi all,
I'm implementing a computer vision system with a near-infrared laser and a NIR bandpass filter. It shines a laser on things and looks for a reflection. I'm getting a bunch of interference from sunlight and was thinking of using a polarizing filter to cut some of the sunlight out.
Anyone know if laser light is polarized to begin with, and in which direction? Most of the sunlight interference isn't direct, but reflection off a concrete floor. Anyone have experience with this? Other ways to cut out sunlight from laser light other than polarization?
I'm open to all suggestions! Thanks so much.
Science news on Phys.org
Most lasers are polarized due to the design of the cavity/cut of the crystal. You can check the specifications for your laser. If Brewster's angle is used, it will be plane polarized as it exits, but it is easy to change via the correct wave plate - the angle can be rotated, or it can be converted to circular polarization. You can also verify the wavelength & bandwidth of the laser ... you may just need a better notch filter.
Wave plates: http://hyperphysics.phy-astr.gsu.edu/hbase/phyopt/quarwv.html#c1
Polarization concepts: http://hyperphysics.phy-astr.gsu.edu/hbase/phyopt/polarcon.html#c1
This is a good learning site!
Sunlight is not polarized, though the atmosphere does generate some partial polarization, which changes during the day - professional photographers have to allow for this when they choose filters:
http://www.polarization.com/sky/sky.html
http://www.cambridgeincolour.com/tutorials/polarizing-filters.htm
Also see http://en.wikipedia.org/wiki/Rayleigh_sky_model
Related to Polarization of Laser vs Sunlight
1. What is polarization?
Polarization is the property of light that describes the orientation of its electric field. In unpolarized light, the electric field oscillates in all directions perpendicular to the direction of the light's propagation. In polarized light, the electric field oscillates in a specific direction.
2. How do lasers produce polarized light?
Lasers produce polarized light through a process called stimulated emission. This process involves a special type of crystal called a laser medium, which is excited by an external energy source such as an electrical current or light. The excited atoms in the laser medium emit photons of light that are all in phase and have the same polarization, resulting in a highly polarized laser beam.
3. Is sunlight polarized?
Yes, sunlight can be partially polarized depending on the angle at which it is observed. Sunlight that is scattered by particles in the atmosphere, such as air molecules or dust, becomes partially polarized. This is why polarized sunglasses can help reduce glare from the sun.
4. How does the polarization of laser light differ from sunlight?
The polarization of laser light is typically much more controlled and intense than that of sunlight. Laser light is usually highly polarized, meaning that the electric field oscillates in a specific direction, whereas sunlight is only partially polarized. Additionally, the polarization of sunlight can vary depending on the angle and location of observation, while the polarization of laser light remains consistent.
5. Why is polarization important in scientific research?
Polarization is important in scientific research because it can provide valuable information about the physical properties of light and the substances it interacts with. For example, studying the polarization of light can help identify the composition of materials and the direction and intensity of electromagnetic fields. It also has practical applications in fields such as telecommunications, remote sensing, and medical imaging.
13K
  • Computing and Technology
