Polarization of light -- Determine the thickness of the crystal
In summary, the correct answer for how to make circularly polarized light is to have a slit that makes the light elliptically polarized and then change the relative phases.
Karl Karlsson
104
A double-breaking material can be used to convert linearly polarized light at right angles to circularly polarized. It is desired to utilize this to change the polarization of light at wavelength 589 nm. Calcite, or its full name, calcium carbonate (CaCO3) is an example of a double-breaking crystal. For the current wavelength, the refractive index is 1.658 for light polarized along the optical axis and 1.486 for light polarized perpendicular to the optical axis. The crystal is oriented so that the optical axis lies in the plane of the surface and the polarization direction of the incident linearly polarized light forms the angle 45 degrees towards the optical axis in the plane of the crystal. Determine the minimum thickness of the crystal required for outgoing light to be circularly polarized.
I assume Fresnel's formulas. Circularly polarized light in vector form:
(0, E*cos(kx - wt), E*cos(kx - wt +- pi/2)). Malus law (maybe)
Maybe (I don't know). Bragg condition for interference from an array (since it's a crystal, I don't know if that matters).
I don't even know where to start with this problem. What kind of slit makes linearly polarized light circularly polarized?
The correct answer is d = lambda/(4(n1 - n2)) = 856nm. But how do I get there?
Thanks in beforehand!
The incoming light polarized at 45 degrees is halfway between the ordinary and extraordinary axes. You can treat it as a sum of two waves aligned along each of the axes. Now, how much phase does each part accumulate passing through a thickness t of the calcite?
This is the key. Do you know what circularly polarised light is? How does it differ from linear polarized light, or unpolarized (randomly polarised) light.
Ooh, i must read wrong i thought i was some slit. Below is my attempt:
However the light is only elliptically polarized and not circular or maybe they meant elliptically polarized light
The light entering is at 45 degrees to the optical axis. It can be treated as a sum of two components. The two components have the same amplitude (because 45 degrees). The two components are eigen-polarizations of the birefringence. The crystal will not convert one to the other. The only thing it can do is change the relative phases. Of course you can get circular polarization.
The only thing I understood on the page was your correct calculation of the thickness based on the path length difference to wind up 1/4 wave out of phase. That is all you need. That is all the problem asked for.
I have no idea what you did at the top. Down at the bottom I have no idea why you think one of the two electric fields needs to be divided by a square root of two. If that is you creating the two parts out of the original 45 degree amplitude, why is only one of them a square root of two smaller than the original?
I think your application of Fresnel reflection/transmission is inappropriate here. Since you have normal incidence, it will not discriminate between p and s waves - or IMO there are no p and s, since all polarizations are perpendicular to the surface.
As KK says, just work out the thickness for 1/4 wave difference, as you did. Nothing in the question requires anything more.
Related to Polarization of light -- Determine the thickness of the crystal
1. What is polarization of light?
Polarization of light refers to the orientation of the electric field in a light wave. Light can be polarized in different directions, either horizontally, vertically, or at any angle in between.
2. How does polarization help determine the thickness of a crystal?
When light passes through a crystal, it can become polarized in a specific direction. By analyzing the polarization of the light before and after it passes through the crystal, scientists can calculate the thickness of the crystal based on how much the polarization has changed.
3. What is the relationship between polarization and crystal thickness?
The amount of polarization change in light passing through a crystal is directly related to the thickness of the crystal. The thicker the crystal, the more the polarization will change.
4. What type of crystals can be used to determine thickness using polarization of light?
Any type of crystal can be used, as long as it has a consistent thickness throughout. This method is commonly used with transparent crystals such as quartz or calcite.
5. Are there any limitations to using polarization to determine crystal thickness?
Yes, there are some limitations. This method is most accurate for thin crystals, as thicker crystals may cause the light to become too polarized and make it difficult to measure accurately. Additionally, the crystal must be transparent and have a consistent thickness for accurate results.
  • Quantum Interpretations and Foundations
