Pole of a function, as a geometric series
In summary, the pole of a function is a point where the function is undefined and approaches infinity or negative infinity. The pole can be identified by finding the values of x that make the denominator of the function equal to zero. A geometric series is a sequence of numbers with a common ratio, and the pole of a function can be represented as the limit of a geometric series as the number of terms approaches infinity. The pole of a function is important because it helps us understand the behavior of the function and identify any discontinuities or asymptotes.
cragar
2,552
Determine the order of the poles for the given function.
[itex] f(z)=\frac{1}{1+e^z} [/itex]
I know if you set the denominator equal to zero
you get z=ln(-1)
But if you expand the function as a geometric series ,
[itex] 1-e^{z}+e^{2z}... [/itex]
I don't see how there is a pole in the geometric series expansion , there is no division by zero. [/B]
You want to expand as a series consisting of powers of ##z-z_0## about the point ##z_0 = i\pi##.
Related to Pole of a function, as a geometric series
What is the pole of a function?
The pole of a function is a point where the function becomes undefined, meaning that the function approaches infinity or negative infinity.
How do you identify the pole of a function?
The pole of a function can be identified by finding the values of x that make the denominator of the function equal to zero. These values are known as the poles of the function.
What is a geometric series?
A geometric series is a sequence of numbers where each term is found by multiplying the previous term by a constant number, known as the common ratio. It has the form a, ar, ar^2, ar^3, ..., where a is the first term and r is the common ratio.
How is the pole of a function related to a geometric series?
The pole of a function can be represented as the limit of a geometric series as the number of terms approaches infinity. This means that as x approaches the pole, the function becomes an infinite geometric series.
Why is the pole of a function important?
The pole of a function is important because it can help us understand the behavior of the function near that point. It can also help us identify any discontinuities or asymptotes in the function.
