Pole shifting for Fourier transform
In summary, the conversation discusses a simple harmonic oscillation problem and its Green function. The Fourier transform of the Green function is found to have poles at $\omega=\pm\omega_{0}$. The speaker asks for guidance on how to shift these poles, mentioning that their instructor has mentioned four ways to do so. They also request recommendations for reading materials on this topic.
clumps tim
39
Hi, I have a simple harmonic oscillation problem whose Green function is given by
$$\Bigl[\frac {d^2}{dt^2}+ \omega_{0}^{2}\Bigl] G(t, t') = \delta(t-t')$$
Now I found out the Fourier transform of $G(t, t')$ to be $$G(\omega)= \frac{1}{2\pi} \frac{1}{\omega_{0}^{2}-\omega^2}$$ which has poles at $\omega=\pm\omega_{0}$
now how can i identify the way the poles can be shifted , like shifting $\omega_{0}\rightarrow \omega_{0}+ i\epsilon$
my instructor said there are four ways to shift. can you please guide me mathematically to pole shifting ?
also suggest me the reading materials to know about these shifting .
regards
Mathematics news on Phys.org
There are far more than 4 ways to have your system's poles be relocated to some desired location. In any case, did you happen to find out what these particular ways are?
FAQ: Pole shifting for Fourier transform
What is the Fourier transform and why is it important in pole shifting?
The Fourier transform is a mathematical tool used to decompose a function into its constituent frequencies. It is important in pole shifting because it allows us to analyze the frequency components of a signal and determine the poles (or resonant frequencies) of the system.
What is pole shifting and how does it relate to the Fourier transform?
Pole shifting is a technique used to modify the performance of a system by changing its poles. It relates to the Fourier transform because the poles of a system can be determined by analyzing the frequency components of the system using the Fourier transform.
How is pole shifting performed using the Fourier transform?
Pole shifting is typically performed by modifying the phase of the Fourier transform of the system. By shifting the phase, the poles of the system can be shifted to different frequencies, altering the system's performance.
What are the benefits of using pole shifting in the Fourier transform?
Pole shifting allows for the modification of a system's resonant frequencies, which can improve its performance. It can also be used to stabilize a system or reduce unwanted oscillations.
What are some real-world applications of pole shifting using the Fourier transform?
Pole shifting using the Fourier transform is commonly used in signal processing, control systems, and telecommunications. It can be used to improve the performance of audio and video signals, stabilize aircraft and spacecraft, and optimize communication systems.
10K
9K
11K
