Pole Vaulting (This should be interesting)
In summary, an athlete can do work by pushing on a pole before releasing it during a pole vault, with the pushing force given by F(x) = (160 N/m)x - (180 N/m^2)x^2 over a distance of 0.24 m. To find the work done by the athlete, the force exerted by the athlete on the pole must be determined, which can be found using the function F(x) = -(160 N/m)x + (180 N/m^2)x^2 as required by Newton's Third Law. This function can then be integrated to find the total work done.
harrinj4
27
At the top of a pole vault, an athlete actually can do work pushing on the pole before releasing it. Suppose the pushing force that the pole exerts back on the athlete is given by F(x) = (160N/M )x - (180n/m^2 )x^2 acting over a distance of 0.24m.
How much work is done by the athlete?
W=Fdcos(theta)
I don't understand what x is? is that .24 meters? The distance? It's confusing wording to me. I tried making x = .24 and got 28 and made it negative but that was wrong
Is there a question that the problem asks?
Oh my gosh haha, I'm trying to find how much work is done by the athlete
I would assume the work done by the athlete on the pole. To do this you need
(a) Find the force F(x) the the athlete exerts on the pole. If the problem does not say what x is, I would assume that x is some distance by which the pole bends as the athlete executes the vault.
(b) Find the work using the expression for a non-constant force
[tex]W = \int F(x) dx[/tex]
The limits of integration should be from 0 to 0.24 m. Should the work done by the athlete on the pole be positive or negative? Hint: This is like compressing a spring.
It should be negative.
But the problem here is that I'm in a calculus based physics class and have only taken the derivative sections of calculus and not the integral based parts. So is there anyway you could help me through this step by step?
Step (a) that I outlined above requires no knowledge of integration. Try that first.
if x=.24 then F(x) = 28.032
We are not looking for a number here. Your answer is not F(x) - it is F(0.24), the force that the pole exerts on the athlete when the vault is bent by 0.24 m. We are looking for the force exerted by the athlete on the pole for any x.
Prepositions are important here. If the force exerted by the pole on the athlete is F(x) = (160 N/m )x - (180 N/m2 )x2, what is the force exerted by the athlete on the pole?
Then since they are opposite
F(x) = -((160 N/m )x - (180 N/m2 )x2)
Not quite. Plus signs should change to minus and minus signs should change to plus. As required by Newton's Third Law, the force on the pole exerted by the athlete is
F(x) = -(160 N/m )x + (180 N/m2 )x2.
Since you say that you are familiar with the derivative sections of calculus, I will ask you this: Can you find a function W(x) such that, when you take its derivative with respect to x, you get the F(x) that I have above? In other words, can you find W(x) such that
[tex]\frac{dW}{dx}=-(160 N/m)x + (180 N/m^{2})x^{2}?[/tex]
Make an educated guess at a function W(x) and then take its derivative and see if it is indeed F(x).
Honestly I'm so lost and you're obviously much too smart for me so I guess I must find help elsewhere. Sorry for making you do all that work for nothing...
I am sorry too. However, I think your course instructor should be made aware of how lost you are. (S)he needs to know.
The problem is that its online homework and we don't actually learn or need this stuff in class. Any chance for last ditch answer?
harrinj4 said:
the problem is that its online homework and we don't actually learn or need this stuff in class. Any chance for last ditch answer?
Actually that is right. It's just written a little differently than kuruman wrote it.
The next part of the question requires you to integrate F(x), and the first step in that is just what kuruman said: find some function whose derivative is
[tex]-160 \frac{\mathrm{N}}{\mathrm{m}}x + 180 \frac{\mathrm{N}}{\mathrm{m}^2}x^2[/tex]
I think that it won't be as hard as you may think, you just need to try it. If you like, you can make a guess, post it here along with your reasoning (why you guessed it), and we can guide you to the right function.
No way, we're not too smart for you! There's no such thing. (Well... okay, maybe there is, but that's not a problem here) Just be persistent, we can help you through this; it just may take a while.
-80(n/m)x^2 + 60(n/m^2)x^3?
Excellent! Persistence pays. :approve:
What you have found is the "antiderivative" or "indefinite integral". In your case, this is the function
W(x) = -80 N/m x2 + 60 N/m2 x3
To complete the problem, you need to find the work as the pole is bent from x = 0 to x = 0.24 m. Another way of saying the same thing is "evaluate the integral from 0 to 0.24 m." The work that you are looking for is summarized with an equation as
W = W(0.24) - W(0)
What the above equation says is "First, replace x with 0.24 m in your expression for the antiderivative and calculate the result. Secondly, replace x with 0 m and recalculate (this one requires no calculator). Thirdly, subtract the second number from the first and that's the number you are looking for." The units will multiply out to N.m which in this case become Joules.
That wasn't too bad, was it?
W = W(0.24) - W(0)
God bless
FAQ: Pole Vaulting (This should be interesting)
What is pole vaulting?
Pole vaulting is an athletic event in which an athlete uses a long, flexible pole to propel themselves over a horizontal bar set at a certain height. It is a track and field event that requires a combination of speed, strength, and technique.
How is the pole chosen for a pole vaulting competition?
The pole is chosen based on the athlete's weight, height, and skill level. The pole must be able to support the athlete's weight while also being flexible enough to bend and propel them over the bar. The athlete and their coach will work together to determine the best pole for their individual needs.
What are the key techniques used in pole vaulting?
The key techniques in pole vaulting include the approach, takeoff, swing, and clearance. The approach is the run-up to the takeoff point, which requires speed and control. The takeoff is when the athlete plants the pole into the ground and begins to bend it. The swing is the motion of the athlete's body as they use the pole to propel themselves over the bar. The clearance is when the athlete releases the pole and successfully clears the bar.
How high can a pole vaulter jump?
The current world record for the highest pole vault jump is held by Renaud Lavillenie of France at 6.16 meters (20 feet 2 ½ inches). However, the average height for a professional male pole vaulter is around 5.50 meters (18 feet 1/2 inch) and for a professional female pole vaulter is around 4.50 meters (14 feet 9 inches).
What are the potential risks and safety precautions in pole vaulting?
Like any sport, pole vaulting carries some risks. Injuries can occur from falling off the pole or landing incorrectly. To minimize these risks, athletes must undergo proper training and use proper equipment, such as a landing mat and a sturdy pole. It is also important for athletes to properly warm up and stretch before practicing or competing. Coaches play a crucial role in ensuring the safety of their athletes by teaching proper techniques and closely monitoring their performance.
