How Long Does It Take for a Police Car to Catch a Speeder?
  • Thread starter Thread starter Heres2hoping
    Car Rest
A speeder traveling at 120 km/h is chased by a police car that accelerates from rest at 1.75 m/s². The chase duration is calculated to be 38.1 seconds. The initial equations used to solve the problem involved distance formulas for both the speeder and the police car. A misunderstanding in the algebraic manipulation caused confusion, but clarification helped correct the approach. Ultimately, the correct answer was achieved after addressing the calculation errors.
Heres2hoping
A speeder moving at 120km/h passes a police car that immediately begins to chase, starting from rest, with an acceleration of 1.75 m/s2. How long is the chase?
The answer is 38.1s
d=v1+at2
At least that's what I tried, but it didn't work out right..,
Speeder:
(In m/s)
d=33.3(t)
Police car:
d=1.75(t)2
Then attempting to equate them together:
33.3t=1.75t2
33.3t/33.3t=1.75t2/33.3t
0=0.053t
0=t
...I did something weird and it's just stopped making sense... Please help (´Д` )
*1/2at2... That's might be my problem, but it's been an issue for almost an hour now (¬_¬)
That's one problem. Here's another:
0=0.053t
you seem to have subtracted on the left instead of dividing.
Likes Heres2hoping
(0o0) thank you so much! I can't believe I did that (-。-; I got the right answer this time (^-^)
Thread 'Minimum mass of a block'
Here we know that if block B is going to move up or just be at the verge of moving up ##Mg \sin \theta ## will act downwards and maximum static friction will act downwards ## \mu Mg \cos \theta ## Now what im confused by is how will we know " how quickly" block B reaches its maximum static friction value without any numbers, the suggested solution says that when block A is at its maximum extension, then block B will start to move up but with a certain set of values couldn't block A reach...
Thread 'Calculation of Tensile Forces in Piston-Type Water-Lifting Devices at Elevated Locations'
Figure 1 Overall Structure Diagram Figure 2: Top view of the piston when it is cylindrical A circular opening is created at a height of 5 meters above the water surface. Inside this opening is a sleeve-type piston with a cross-sectional area of 1 square meter. The piston is pulled to the right at a constant speed. The pulling force is(Figure 2): F = ρshg = 1000 × 1 × 5 × 10 = 50,000 N. Figure 3: Modifying the structure to incorporate a fixed internal piston When I modify the piston...
