Polygon Coordinates given the Area and Center point
In summary, the polygon has 4 points and the formula to calculate the coordinates of the points is given.
PhysicsInept
TL;DR Summary
Polygon
I’m wondering if there is a formula for calculating the coordinate points of a polygon given the following
- Center point is known
- area is known
- Point A is known
- Points B, C, and D are UNKNOWN
I am NOT a math pro - this is for a puzzle I’m trying to solve and I can’t remember if this was even covered in high school math!
Thanks
Mathematics news on Phys.org
So the polygon has 4 points meaning it's a quadrilateral of some sort like a square, rectangle, rhombus, parallelogram, trapezoid or some arbitrary shape.
One could start with a right triangle contain the center point and point A choose B such that the triangle has one quarter of the area given.
Hmmm okay so bear with me as I try to understand ..
So I would use the Center point as Point A of a right triangle, then I know Point B already, and I can calculate the last Point since I have area. Why would the area be 1/4 of what I have been given? A polygon isn’t 4 equal triangles right?
As you only mention four points we need to assume the polygon is a quadrilateral - this is important. It is also important to define what you mean by the "center point": if you mean what is usually called the centroid (also sometimes geometric centre/center or even barycentre/barycenter) then yes this should be solvable with some work; it will probably involve Varignon's parallelogram.
I assume you mean that the "centre point" is the right angled vertex of the triangle? That will construct a quadrilateral with the "centre point" at the intersection of the diagonals which is not in general the centroid.
A polygon with four sides has 8 degrees of freedom (e.g. the 4 corners), we only have 5 values given. This can only be solved if we know it's a special type of polygon.
Likes pbuk
It can only be solved uniquely if we have more information, but I'm not sure if uniqueness is required (the OP doesn't ask for "the polygon").
If a question asks for the coordinates of points without saying anything else it's usually a unique solution (only dependent on given parameters). A general polygon doesn't have a single unambiguous center either, that makes me think there is some information missing in the first post. If you require some special shapes and define their center then you can find solutions of course.
jedishrfu said:
To my mind it implies a square or a rhombus.
I don't agree, based on the OP. If someone asks about a polygon, without additional information, it's a stretch to infer that a more specific geometric figure is meant. Even if we take the mention of points A, B, C, and D to mean that these are vertices, and that there are no other vertices, the figure could still be a rectangle, trapezoid, or just an irregular quadrilateral.
Seeing the exact problem statement would clear up these uncertainties.
Likes mfb
If you take a polygon with 4 points, there is always an inner diagonal. Take as origin one of the endpoints of the diagonal and name the 3 other endpoints u, v and w as vectors where v is the other endpoint of the inner diagonal.
Then the formula for the surface of the polygon equals ##|(Det(u\: v) + Det(v\: w)/2|##
Thus if this area a is known, you can take angle phi and take 2 matrices from ##SL_2(R)## where the 1st times ##cos(\phi)## has as 2nd column the 1st column of the 2nd matrix times ##sin(\phi)##. These matrices multiplied with ##a\sqrt(1/2)cos(\phi)## or ##sin(\phi)## for the 2nd have as columns the vectors we wanted to find.
FAQ: Polygon Coordinates given the Area and Center point
What are polygon coordinates?
Polygon coordinates refer to the set of points that make up the vertices of a polygon. These points are represented by their x and y coordinates on a coordinate plane.
How is the area of a polygon calculated?
The area of a polygon can be calculated by dividing it into smaller shapes, such as triangles or rectangles, and using their respective area formulas. The sum of these smaller areas will give the total area of the polygon.
What is the center point of a polygon?
The center point of a polygon is the point where all the lines of symmetry intersect. It is also known as the centroid and is the average of all the coordinates of the polygon's vertices.
Can the polygon coordinates change if the area and center point are given?
Yes, the polygon coordinates can change depending on the shape of the polygon. The area and center point only provide information about the size and location of the polygon, but not the exact shape.
How do you find the polygon coordinates given the area and center point?
To find the polygon coordinates, you can use the area and center point to determine the length of the sides and angles of the polygon. Then, using basic geometry and trigonometry, you can calculate the coordinates of each vertex based on the known information.
