Polymerase Chain Reaction (PCR)
In summary, the technique of amplifying DNA involves heating the sample to around 95 degrees to break the hydrogen bonds between base pairs and prevent the strands from sticking together. This high temperature is necessary to denature the DNA and requires the use of thermostable polymerases such as Taq polymerase. Originally, regular E. coli DNA polymerase was used but had to be added during each cycle at a lower temperature.
_Mayday_
808
Hey!
I have learned that one of the first steps in this technique involves heating the DNA sample to around 95 degrees. Now as far as I am aware the only thing holding the two Sugar Phosphate backbones together is the Hydrogen bonding between base pairs. Why is such a high temperature needed to break such weak bonds?
_Mayday_
Biology news on Phys.org
The DNA sample you're trying to amplify from could be a very long strand of DNA, so there could be a large number of hydrogen bonds that you'll have to break. You don't really want the strands to be associated with each other, so you use a relatively large amount of heat to help keep them from 'sticking' to each other.
Thank you Faustus.
I don't believe that temperature is really necessary, but just preferable because it can make the whole reaction go faster.
Originally it was not used at such temperature because the polymerase would denature at such high temperatures, then polymerases were adapted from thermophilic archaea, like Taq polymerase, which allowed the reaction to go at higher temps.
Not really. The actual polymerization temp is around 68-72° C depending on the polymerase. Some hot-start polymerase require activation at 94° C , though.
The high temperature is needed to denature the DNA strands. Thermostable polymerases such as taq polymerase are required for the enzyme to survive the 95oC denaturation step. Otherwise, if one were to use regular E. coli DNA polymerase (as was done in the early days of PCR), one would have to cool to 37oC and add fresh enzyme during each cycle of the PCR reaction.
Related to Polymerase Chain Reaction (PCR)
1. What is Polymerase Chain Reaction (PCR)?
Polymerase Chain Reaction, or PCR, is a laboratory technique used to amplify a specific segment of DNA. It involves repeated cycles of heating and cooling to copy and amplify a desired DNA sequence, allowing for the production of millions of copies of the target DNA.
2. What is PCR used for?
PCR is used in various scientific fields, including genetics, forensics, and medical research. It is commonly used to detect and diagnose genetic diseases, identify DNA fingerprints, and analyze gene expression.
3. How does PCR work?
PCR involves three main steps: denaturation, annealing, and extension. First, the DNA sample is heated to separate the double-stranded DNA into single strands. Next, primers (short DNA sequences) are added to bind to the single-stranded DNA. Finally, a heat-resistant DNA polymerase enzyme copies the DNA sequence, creating multiple copies of the target DNA.
4. What are the benefits of PCR?
PCR is a fast, efficient, and sensitive technique that allows for the amplification of a specific DNA sequence. It requires only a small amount of DNA sample and can be completed in a matter of hours. Additionally, PCR can be used to amplify DNA from a variety of sources, including blood, saliva, and tissue samples.
5. What are the limitations of PCR?
While PCR is a powerful tool, it does have some limitations. It is highly sensitive and can be affected by even small amounts of contamination, which can lead to false results. Additionally, PCR can only amplify specific DNA sequences and cannot produce a complete sequence of an entire genome.
19K
  • Cosmology
  • Other Physics Topics
59K
19K
9K
