Polymers with piezoelectric effect
In summary, piezoelectric polymers, such as vinyl fluoride and polyvinylidene fluoride (PVDF), can be manipulated and expand when pressure is applied due to the piezoelectric effect. This effect is achieved by cooling the polymer in a high electric field during manufacturing. The physical movement from this effect is very small and may not be felt, but it can produce vibrations when modulated power is applied. Pre-made strips of piezoelectric polymer with good uniformity are available for purchase. Goodfellow offers a variety of PVDF sheets for experimentation.
bio2000
I am looking for a polymer that can be manipulated and that expands after applying pressure between the fingers, as a result of piezoelectric effect.
the commercial one used is vinyl fluoride, iirc.
It's 'activated' at manufacture by cooling in a high electric field.
physical movement from the piezoelectric effect is extremely tiny.
you wouldn't be able to feel the expansion but you could feel vibration if you applied modulated power.
you can buy the piezopolymer in strips, already made with good uniformity.
A typical piezoelectric film is polyvinylidene fluoride, PVDF.
The piezoelectric effect means a charge is generated when a stress is applied, or a mechanical effect can be achieved by passing a charge across the sample.
Goodfellow sell a variety of PVDF sheet which you can play around with.
Related to Polymers with piezoelectric effect
1. What is the piezoelectric effect in polymers?
The piezoelectric effect in polymers refers to the ability of certain polymers to generate an electric charge when subjected to mechanical stress or pressure. This phenomenon is due to the alignment of electric dipoles within the polymer, resulting in a separation of positive and negative charges.
2. How are polymers with piezoelectric effect used?
Polymers with piezoelectric effect are used in various applications such as sensors, actuators, energy harvesting devices, and biomedical devices. They are also used in the production of piezoelectric films and fibers, which can be integrated into electronic devices and structures for improved performance.
3. What are the advantages of using polymers with piezoelectric effect?
One of the main advantages of using polymers with piezoelectric effect is their flexibility and lightweight nature, making them suitable for use in flexible and wearable electronics. They also have a low cost of production compared to other piezoelectric materials such as ceramics. Additionally, they have a high sensitivity and can generate relatively high voltages and currents when subjected to mechanical stress.
4. Are there any limitations to using polymers with piezoelectric effect?
One limitation of polymers with piezoelectric effect is their relatively low piezoelectric coefficient, which means they produce a weaker electric charge compared to other materials. They also have a lower durability and stability compared to ceramics, making them less suitable for long-term use in harsh environments.
5. How can the piezoelectric effect in polymers be enhanced?
The piezoelectric effect in polymers can be enhanced by incorporating fillers or additives such as carbon nanotubes or graphene, which can increase the mechanical strength and piezoelectric properties of the polymer. Additionally, the orientation and alignment of polymer chains can also be controlled during processing to enhance the piezoelectric effect.
  • Materials and Chemical Engineering
