Polynomial Basis and Linear Transformation
In summary, the set B={1,x,...,x^M} is a basis for the vector space X of polynomials of order less than or equal to M. The mapping T from X to X, defined as f(x)=Tg(x)=d/dx g(x), is linear. The matrix representation for T in terms of the basis B is a diagonal matrix with elements 0,1,2,...M. The eigenvalues of T are lambda = [0,1,2,...M] and an eigenvector associated with lambda = 1 is [1,1,...1]. However, there are errors in the solution attempts, such as using the wrong variables and not fully establishing linear independence.
zairizain
Let X be the vector space of polynomial of order less than or equal to M
a) Show that the set B={1,x,...,x^M} is a basis vector
b) Consider the mapping T from X to X defined as:
f(x)= Tg(x) = d/dx g(x)
i) Show T is linear
ii) derive a matrix representation for T in terms of the basis B
iii) what are the eigenvalues of T
iv) compute one eigenvector associated with one of the eigenvalues
a) i)Linear independence;
a1(1) + a2(x)+...+an(x^M) = 0
a1=a2=an=0
ii)Span
a+bx+...+cx^M=0
Such that; a1(1) +a2(x)+...+an(x^M) = a+bx+...+cx^M
a1=a, a2=b, an=c
b)
i) f(x) = a0 + a1X+...+amX^M
g(x) = b0 + b1X+...bmX^M
g(t) = b0+b1t+...+bmt^M
Tg(t) = b0t + b1t^2+...+bmt^(M+1)
For any scalar, k is element K
T(k g(t)) = t (k g(t))
= k (t g(t))
= KT (g (t))
Thus T is linear
ii) B= {1, x ,x^2,...,x^M}
matrix T,=
0 0 0 ...0
0 1 0 ...0
0 0 2 ...0
0 0 0 ...0
0 0 0 .. M
iii) eigenvalues of T, lambda = [0, 1, 2...M]
iv)for lambda = 1;
(A-lambda I)=0
(A- I ) = 0
[matrix T] [ a1;a2;...am] = [ a1;a2;...am]
a1=a2=...=am
eigenvector for lambda =1 is;
[1, 1, ...1]
Is this correct?Please help me.
This should be "Show that the set B={1,x,...,x^M} is a basis for X."
i) Show T is linear
It's probably more convenient to label the constants as a0, a1, a2, ..., aM. That way they match the exponent on x.
zairizain said:
a1=a2=an=0
This is true whether the functions are linearly independent or linearly dependent. The critical difference is whether this is the unique solution (independent set of functions) or one of many (dependent set).
How can you establish that there are no other solutions for a0, a1, a2, ..., aM?
zairizain said:
ii)Span
a+bx+...+cx^M=0
a1=a, a2=b, an=c
Why do you think that a+bx+...+cx^M=0? Are there only three terms on the left side? That's what you're implying with constants a, b, and c.
When you say "Such that; a1(1) +a2(x)+...+an(x^M) = a+bx+...+cx^M" what is a3? a4?
zairizain said:
b)
No, this is wrong. f(x) = d/dx(g(x)). There is no t, but there is T and these are different letters.
For example, if g(x) = b0 + b1x + b2x + ... + bMxM, what is f(x)?
= k (t g(t))
= KT (g (t))
Thus T is linear
matrix T,=
0 0 0 ...0
0 1 0 ...0
0 0 2 ...0
0 0 0 ...0
0 0 0 .. M
iv)for lambda = 1;
(A-lambda I)=0
(A- I ) = 0
a1=a2=...=am
[1, 1, ...1]
FAQ: Polynomial Basis and Linear Transformation
What is a polynomial basis?
A polynomial basis is a set of polynomials that can be used to represent any polynomial of a given degree. It is a fundamental concept in algebra and is often used in linear algebra to represent a vector space.
How is a polynomial basis related to linear transformation?
A polynomial basis is used to define a coordinate system in a vector space. This coordinate system can then be used to represent linear transformations, which are operations that map one vector space to another. By using a polynomial basis, we can easily perform calculations and analyze the effects of linear transformations.
Can a polynomial basis be used for non-polynomial functions?
Yes, a polynomial basis can be used to approximate non-polynomial functions. This is known as polynomial interpolation, where polynomials are used to "fit" a function to a set of data points. However, the accuracy of the approximation depends on the degree of the polynomial and the complexity of the function being approximated.
How do you determine the degree of a polynomial basis?
The degree of a polynomial basis is equal to the highest degree of the polynomials in the set. For example, if the basis is {1, x, x^2}, then the degree is 2. Generally, the degree of a polynomial basis is chosen to be equal to the dimension of the vector space being represented.
What are some applications of polynomial basis and linear transformation?
Polynomial basis and linear transformation have various applications in fields such as computer graphics, signal processing, and data analysis. They are also used in engineering and physics to model and analyze systems. Additionally, they play a crucial role in machine learning and artificial intelligence algorithms.
