Polynomial Challenge V: Real Solution Implies $p^2+q^2\ge 8$
In summary, to find a real solution for $x^4+px^3+2x^2+qx+1$ with real coefficients, it must be true that $p^2+q^2\ge 8$.
anemone
MHB
POTW Director
3,883
115
Show that if $x^4+px^3+2x^2+qx+1$ has a real solution, then $p^2+q^2\ge 8$.
Mathematics news on Phys.org
anemone said:
Show that if $x^4+px^3+2x^2+qx+1 = 0$ has a real solution, then $p^2+q^2\ge 8$.
[sp]Divide through by $x^2$: $(x+x^{-1})^2 + px+qx^{-1} = 0$. Now let $y = x+x^{-1}$, so that the equation becomes $y^2 = -(px+qx^{-1}).$
By the Cauchy–Schwarz inequality, $(px+qx^{-1})^2 \leqslant (p^2+q^2)(x^2+x^{-2}) = (p^2+q^2)(y^2 - 2).$ If $y^2 = -(px+qx^{-1})$, then $y^4 = (px+qx^{-1})^2 \leqslant (p^2+q^2)(y^2 - 2)$, so that $y^4 - (p^2+q^2)y^2 + 2(p^2+q^2) \leqslant0$. The discriminant of that quadratic expression in $y^2$ is $(p^2+q^2)^2 - 8(p^2+q^2) = (p^2+q^2)(p^2+q^2-8).$ If $p^2+q^2<8$, the discriminant is negative and so the quadratic expression will have no real zeros. There would then be no real solutions for $y$ and therefore no real solutions for $x$.[/sp]
you need to show that y does not lie between -2 and 2 ( or $y^2 \ge 4 $) else x becomes complex)
[sp]I was expecting to have to do that. But when I came to write out the solution, I saw that if $p^2+q^2<8$ then there is no real solution for $y$ (never mind whether it lies between $-2$ and $2$ or not), and therefore no real solution for $x$.[/sp]
Well done, Opalg! It never occurred to be to approach this problem using your method! Thank you Opalg for your neat and easy-to-follow solution and thanks for participating as well.
A solution that I saw online somewhere:
Note that the degree of the polynomial is even, if there exists one real root, then there must exist either two roots of multiplicity one or one root of multiplicity two. Therefore we may write:
$x^4+px^3+2x^2+qx+1=(x^2+ax\pm1)(x^2+bx\pm1)$ for some real $a,\,b$.
We now split the problem into two cases:
Case I: $x^4+px^3+2x^2+qx+1=(x^2+ax+1)(x^2+bx+1)$
The coefficient of $x^2$ from the RHS equals to $2+ab$, setting this equals to 2 gives $ab=0$. WLOG, let $a=0$, then the factorization boils down to $(x^2+1)(x^2+bx+1)$. Since $x^2+1$ has no real rots, $x^2+bx+1$ must have one, so $b^2\ge 4$. Finally, expanding out the RHS and comparing coefficients gives $p=q=b$, so $p^2+q^2=2b^2\ge2(4)=8$, as desired.
Case II: $x^4+px^3+2x^2+qx+1=(x^2+ax-1)(x^2+bx-1)$
The coefficient of $x^2$ from the RHS equals to $-2+ab$, setting this equals to 2 gives $ab=4$. WLOG, let $p=a+b$, and $p=-(a+b)$. This means that $p^2+q^2=2(a+b)^2=2(a^2+b^2)+4ab=2(a^2+b^2)+16$ and since $a^2+b^2\ge 0$, the entire expression is $\ge 16$, which obviously makes the expression greater than 8, as desired.
Finally, note that when both $x^2$ coefficients are negated, the only aspect of the problem that differs is the sign of the $ax$ and $bx$ coefficients. Running through the steps shown above, it can be seen that this does not affect the value of $p^2+q^2$.
Hence all cases are covered, and so we're done.
FAQ: Polynomial Challenge V: Real Solution Implies $p^2+q^2\ge 8$
What is the "Polynomial Challenge V"?
The "Polynomial Challenge V" is a mathematical problem that involves finding real solutions to a polynomial equation with two variables, p and q, while also satisfying the condition that p^2 + q^2 is greater than or equal to 8.
What is the significance of the condition "p^2+q^2>=8"?
The condition "p^2+q^2>=8" is significant because it limits the range of possible solutions for the polynomial equation. It ensures that the solutions are not too small and also provides a lower bound for the solutions.
Why is it important to find real solutions?
Finding real solutions to a polynomial equation is important because it provides a concrete and tangible solution to the problem. Real solutions also have practical applications in fields such as physics, engineering, and economics.
What are some strategies for solving "Polynomial Challenge V"?
One strategy for solving "Polynomial Challenge V" is to use the quadratic formula to find the roots of the polynomial equation. Another strategy is to graph the equation and find the points of intersection with the line y = 8 - x^2, which represents the condition p^2+q^2>=8.
Are there any other conditions that need to be satisfied besides "p^2+q^2>=8"?
No, "p^2+q^2>=8" is the only condition that needs to be satisfied for "Polynomial Challenge V". However, there may be additional constraints or parameters given in a specific problem that need to be considered when finding the solutions.
