Polynomial Division (continued from osnarf's problem)
In summary: Yes it became degree of k at most because we subtracted a[k+1]x[k+1].So, we should have :f(x)-a[k+1]x[k+1] = (x-a)g(x) + b, is this correct, since we have degree at k the most?Yes, this is correct.
jimpap
Hello,
My problem is the same as osnarf's problem in thread "Polynomial division proof",
https://www.physicsforums.com/threads/polynomial-division-proof.451991/
But, I would like some further help.
The problem:
Prove that for any polynomial function f, and any number a, there is a polynomial function g, and a number b, such that f(x) = (x - a)*g(x) + b for all x.
After some steps
a) n=1,
f(x) = a[1]x+a[0]=a[1](x-a)+(a[0]+a[1]a)
b) Suppose it is true for n=k,
f(x)= a[k]x[k]+ a[k-1]x[k-1] +...+ a[1]x+a[0]
f(x)=(x-a)g(x) + b
c) n=k+1 : f(x) = a[k+1]x[k+1]+ a[k]x[k] +...+ a[1]x+a[0]
and since we have supposed that f(x) is true for n= k, it turns into a new polynomial :
h(x) = f(x) - a[k+1](x-a) and has degree <=k?
I understand f(x), but a[k+1](x-a) is it correct? Did it come from a[k+1]x[k+1]?
thanks
Sorry for any inconvenience on reading this thread.
First write out very formally and clearly what you can assume for n=k+1 by using your Induction Hypothesis - ie write out the fact that you get by assuming it's true for n=k.
Once you do that, it may be easier to see how you can prove the required fact for n=k+1. Even if you can't see it, it will be easier for people to help you if you've done the work to define the relevant variables.
jimpap said:
Hello,
My problem is the same as osnarf's problem in thread "Polynomial division proof".
The problem asks : Prove for every f and number a, there are g(x) and number b, that f(x) = (x-a)g(x) + b.
After some steps
a) n=1,
and since we have supposed tha f(x) is true for n= k, it turns into a new polynomial :
thanks
Here is a link to osnarf's thread, which is dated from the year 2010 and has been closed: https://www.physicsforums.com/threads/polynomial-division-proof.451991/
The wording of the problem there is:
thanks
As I understand it, this seems to be the very issue osnarf had.
It looks like Spivak has a typo in the statement:
##\displaystyle \ h(x)=f(x)-a_{k+1}(x-a) \ ## and has degree ≤ k .​
I looks to me that the correct statement is:
##\displaystyle \ h(x)=f(x)-a_{k+1}(x-a)x^k \ ## and has degree ≤ k .​
Of course ƒ(x) is a polynomial of degree k+1, and the resulting polynomial, h(x), has degree less than k+1 .
Thanks for your instant response.
But :
a[k+1](x-a)x[k]
isn't it equal to:
a[k+1]x[k+1] - a[k+1]ax[k].
So, turning from
a[k+1]x[k+1]
to
a[k+1](x-a)x[k]
wouldn't require to add
a[k+1]ax[k]?
But :
a[k+1](x-a)x[k]
isn't it equal to:
So, turning from
a[k+1]x[k+1]
to
a[k+1](x-a)x[k]
a[k+1]ax[k]?
What are we adding a[k+1]ax[k] to ? Does that matter?
The important thing is that the result is a polynomial having degree of k at most.
Sorry, I still miss something.
And then
a[k+1]x[k+1] = a[k+1](x-a)x[k] and we don't take into consideration
the + a[k+1]ax[k] because it will only add a small amount?
And then
No, we don't count on it only being a small amount. It is not discarded at all.
To quote a bit more from osnarf's thread:
osnarf said:
Proving a polynomial of degree 1 is easy enough for the induction proof.
For proving it for a degree k+1, spivak writes :
suppose the result is true for polynomials of degree <= k.
The resulting polynomial is of degree k or less.
That polynomial is ##\displaystyle \ h(x)=f(x)-a_{k+1}(x-a)x^k \ ##.
It is not claimed that this is the same as f(x) minus its leading term.
If it not claimed that this is the same as f(x) minus its leading term, did we take
the polynomial h(x)=f(x)-a[k+1](x-a)x[k], meaning
that f(x) a random polynomial of k+1 power and subtract another polynomial also to the k+1 power?
So the a[k+1]x[k+1] has nothing to do with a[k+1](x-a)x[k]?
No. They are the very same ak+1 .
Write out the two or three highest degree terms of h(x)
You mean to try different k for:
f(x)=ak+1xk+1+akxk+...+a1x+a0,
and
h(x)=f(x)-ak+1xk+1
or
h(x)=f(x)-ak+1(x-a)xk
f(x) = ak+1xk+1 + akxk +...+ a1x + a0,
and
h(x)=f(x)-ak+1xk+1
or
h(x) = f(x) - ak+1(x-a)xk
Combine the first and the last expressions.
Then expand ## \displaystyle \ -a_{k+1}(x-a)x^k \ ## to ## \displaystyle \ -a_{k+1}x^{k+1}+a\cdot a_{k+1}x^k \ ## , and simplify.
Likes jimpap
I see that the degree is the same as number k and ak+1xk+1 is simplified.
But since ak+1xk+1 is irrelevant to ak+1(x-a)xk, against my original thought,
I can't understand how should I think the h(x) polynomial.
Thank you for your time!
Do you see that h(x) is a polynomial with degree of k or less ?
The inductive step assumes that the result we want to prove "is true for polynomials of degree <= k.", as Spivak puts it.
Added in Edit:
## \displaystyle\ f(x)= a_{k+1}x^{k+1} -a_{k+1}x^{k+1}+a\cdot a_{k+1}x^k +a_zx^x+a_{k-1}x^{k-1}+...\ ##
Yes it was quite explanatory , I see that the degree is <=k.
Then either:
1. h(x) is a number (degree zero polynomial)
2. h(x) is a polynomial of degree, n, where 1 ≤ n ≤ k, so that there is a number, c, and a polynomial, p(x), of degree n-1 such that
## \displaystyle \ h(x)=(x-a)p(x)+c \ ## .​
It does not really matter what other details pertain to h(x), only that its degree is k or less.
Likes jimpap
SammyS said:
Then either:
1. h(x) is a number (degree zero)
Appreciate your interest. I think spivak's book is pretty difficult. What I was asking clarified at https://www.physicsforums.com/threa...ued-from-osnarfs-problem.842252/#post-5285189.
And again thank you.
jimpap said:
After some steps
a) n=1,
f(x)=(x-a)g(x) + b
I see you have now written out the induction hypothesis, but I think maybe you are getting lost in the notation. Using ##f## for both the degree ##k## and the degree ##k+1## polynomial creates confusion.
Stick with ##f## for the degree ##k## polynomial and call the degree ##k+1## polynomial
$$F(x)=a_{k+1}x^{k+1}+ a_kx^k +...+ a_1x+a_0\equiv\sum_{j=0}^{k+1}a_jx^j$$
Then you can write ##F(x)=xf^*(x)+a_0##.
Writing out ##f^*(x)## is straightforward, and I'll leave that to you.
Now you can apply the induction hypothesis to ##f^*(x)##, since it has degree ##k##, to write:
$$f^*(x)=g^*(x)(x-a^*)+b^*$$
Substitute that into the above formula for ##F(x)## and then rearrange. What do you get?
FAQ: Polynomial Division (continued from osnarf's problem)
1. What is polynomial division?
Polynomial division is a method used to divide one polynomial expression by another polynomial expression. It is similar to long division but involves dividing terms with variables instead of just numbers.
2. How is polynomial division performed?
To perform polynomial division, the divisor (the polynomial being divided into) is multiplied by the highest degree term of the dividend (the polynomial being divided) to obtain a partial quotient. This partial quotient is then subtracted from the dividend, and the process is repeated until the remainder is a lower degree than the divisor.
3. What is the difference between polynomial long division and synthetic division?
The main difference between polynomial long division and synthetic division is that long division can be used for any polynomial division problem, while synthetic division can only be used for dividing by linear expressions (expressions of the form ax + b).
4. How do you know when to stop dividing in polynomial division?
In polynomial division, you stop dividing when the degree of the remainder is lower than the degree of the divisor. This means that the remainder cannot be divided any further and is the final answer.
5. What is the purpose of polynomial division in mathematics?
Polynomial division is an important tool in algebra and is used to solve various problems, such as finding roots of polynomials and simplifying expressions. It is also used in calculus to find the derivative and integral of rational functions.
