Polynomial inequality
In summary, the conversation is about proving that a polynomial with non-negative coefficients and $n$ real roots has a minimum value of $3^n$ when $x=2$. The polynomial is specified as $P(x) = 1 + a_1x +a_2x^2+...+a_{n-1}x^{n-1}+x^n$ with non-negative integer coefficients, and it is mentioned that this condition is necessary for the result to hold. A hint is also given to help with the proof.
lfdahl
MHB
749
The polynomial: $P(x) = 1 + a_1x +a_2x^2+...+a_{n-1}x^{n-1}+x^n$
with non-negative integer coefficients has $n$ real roots. Prove, that $P(2) \ge 3^{n}$
Mathematics news on Phys.org
with non-negative coefficients has $n$ real roots. Prove, that $P(2) \ge 3^{n}$
I guess that should be "The polynomial: $P(x) = 1 + a_1x +a_2x^2+...+a_{n-1}x^{n-1}+x^n$ with non-negative integer coefficients has $n$ real roots." Otherwise the result is not true.
Hint:
Consider the sign of the roots ... - and then take a closer look at $P(2)$
I do not see why Opalg mentioned that coefficients should be integers
Because all coefficients are positive so all n roots are -ve and hence
$P(x) = \prod_{k=1}^{n} (x+ a_k)$ where all $a_k$ are positive
further $\prod_{k=1}^{n} (a_k) = 1$
so $P(2) = \prod_{k=1}^{n}(2+a_k)\cdots(1)$
now taking AM GM between 1,1 $a_k$ we get $(2+a_k) >= 3\sqrt[3]{(a_k)}\cdots(2)$
so from (1) and (2)
$P(2) >= 3^n \sqrt[3]{\prod_{k=1}^{n} (a_k)} = 3^n$ and hence $P(2) >= 3^n$
You are quite right. I somehow overlooked the fact that the constant term and the coefficient of $x^n$ are both $1$.
so from (1) and (2)
$P(2) >= 3^n \sqrt[]{\prod_{k=1}^{n} (a_k)} = 3^n$ and hence $P(2) >= 3^n$
Thankyou, kaliprasad, for your solution. Well done!
so from (1) and (2)
$P(2)>=3^n\sqrt[]{\prod_{k=1}^n (a_k)}=3^n$ and hence $P(2)>=3^n---(*)$
typo
(*)should be
$P(2) \geq 3^n \sqrt[3]{\prod_{k=1}^{n} (a_k)} = 3^n$ and hence $P(2) \geq 3^n$
so from (1) and (2)
typo
(*)should be
I have done the needful
FAQ: Polynomial inequality
What is a polynomial inequality?
A polynomial inequality is an inequality that contains one or more polynomial expressions. A polynomial expression is a mathematical expression that consists of variables, coefficients, and non-negative integer exponents.
How do you solve a polynomial inequality?
To solve a polynomial inequality, first simplify the inequality by combining like terms and moving all terms to one side of the inequality. Next, factor the polynomial expression into linear factors. Then, plot the zeros of the polynomial on a number line and determine the intervals where the polynomial is positive or negative. Finally, use these intervals to write the solution to the inequality.
What is the degree of a polynomial inequality?
The degree of a polynomial inequality is the highest degree among all the polynomial expressions in the inequality. For example, in the inequality 2x^3 + 4x^2 - 6x + 1 > 0, the degree is 3.
What are the different types of polynomial inequalities?
The different types of polynomial inequalities include linear inequalities, quadratic inequalities, cubic inequalities, and higher degree inequalities. The degree of the polynomial determines the type of inequality.
How do polynomial inequalities relate to real-life situations?
Polynomial inequalities can be used to model real-life situations, such as determining the minimum or maximum number of items that can be produced to maximize profits, or finding the range of values for a variable that satisfies a given condition. They can also be used to solve optimization problems in various fields, including economics, engineering, and physics.
