Polynomial Rings - Gauss's Lemma
In summary: I cannot see why the ideal (p_1) is a prime ideal - I was looking at definitions of prime ideals and trying to reason from there.I just looked up the definition of a prime element in D&F to find the following on page 284:The non-zero element p \in R is called prime if the ideal (p) generated by p is a prime ideal!So the answer to my question seems obvious:p_1 irreducible \Longrightarrow p_1 prime \Longrightarrow (p_1) prime ideal
Math Amateur
MHB
3,998
48
I am trying to understand the proof of Gauss's Lemma as given in Dummit and Foote Section 9.3 pages 303-304 (see attached)
On page 304, part way through the proof, D&F write:
"Assume d is not a unit (in R) and write d as a product of irreducibles in R, say [TEX] d = p_1p_2 ... p_n [/TEX] . Since [TEX] p_1 [/TEX] is irreducible in R, the ideal [TEX] (p_1) [/TEX] is prime (cf Proposition 12, Section 8.3) so by Proposition 2 above the ideal [TEX] p_1R[x] [/TEX] is prime in R[x] and [TEX] (R/p_1R)[x] [/TEX] is an integral domain. ..."
My problems with the D&F statement above are as follows:
(1) I cannot see why the ideal [TEX] (p_1) [/TEX] is a prime ideal. Certainly Proposition 12 states that "In a UFD a non-zero element is prime if and only if it is irreducible" so this means [TEX] p_1 [/TEX] is prime since we were given that it was irreducible. But does that make the principal ideal [TEX] (p_1) [/TEX] a prime ideal? I am not sure! Can anyone show rigorously that [TEX] (p_1) [/TEX] a prime ideal?
(2) Despite reading Proposition 12 in Section 8.3 I cannot see why the ideal [TEX] p_1R[x] [/TEX] is prime in R[x] and [TEX] (R/p_1R)[x] [/TEX] is an integral domain. ...". (Indeed, I am unsure that [TEX] p_1R[x] [/TEX] is an ideal!) Can anyone show explicitly and rigorously why this is true?
I would really appreciate clarification of the above matters.
Peter
Note: Proposition 2 referred to above states the following:
Let I be an ideal of the ring R and let (I) = I[x] denote the ideal of R[x] generated by I (the set of polynomials with co-efficients in I). Then
\(\displaystyle R[x]/(I) \cong (R/I)[x]\)
In particular, if I is a prime ideal of R then (I) is a prime ideal of R[x]
Peter
In trying to answer my problem (1) above - I cannot see why the ideal [TEX] (p_1) [/TEX] is a prime ideal - I was looking at definitions of prime ideals and trying to reason from there.
The non-zero element [TEX] p \in R [/TEX] is called prime if the ideal (p) generated by p is a prime ideal!
[TEX] p_1 irreducible \Longrightarrow p_1[/TEX] prime [TEX] \Longrightarrow (p_1) [/TEX] prime ideal
Although this now seems obvious, I would like someone to confirm my reasoning (which as I said now seems blindingly obvious! :-)
Peter
That is correct. In fact, the reason prime ideals were given that name is that they are the ideals generated by primes!
Thanks Opalg
Can someone now help with problem (2) above
To repeat this problem is as follows:
(2) Despite reading Proposition 2 in Section 9.1, I cannot see why the ideal \(\displaystyle p_1 R[x] \) is prime in R[x] and [FONT=MathJax_Main]\(\displaystyle (R/p_1 R) [x] \)[/FONT] is an integral domain. ...". (Indeed, I am unsure that \(\displaystyle p_1R[x] \) is an ideal!) Can anyone show explicitly and rigorously why this is true?
Peter
Peter said:
I cannot see why the ideal \(\displaystyle p_1 R[x] \) is prime in R[x] and \(\displaystyle (R/p_1 R) [x] \) is an integral domain. ...". (Indeed, I am unsure that \(\displaystyle p_1R[x] \) is an ideal!) Can anyone show explicitly and rigorously why this is true?
I will write $p$ rather than $p_1$, to avoid tiresome subscripts.
$pR[x]$ is the set of all polynomials whose coefficients are all multiples of $p$. It should be pretty obvious that this is an ideal in $R[x]$. In fact, if $pf(x)\in pR[x]$ and $g(x)\in R[x]$, then $(pf(x))g(x) = p(f(x)g(x))\in pR[x]$.
To see that $pR[x]$ is a prime ideal, suppose that $f(x),\ g(x) \in R[x]$ and $f(x)g(x)\in pR[x]$. We want to show that either $f(x)$ or $g(x)$ is in $pR[x]$. Suppose not: then both $f(x)$ and $g(x)$ have at least one coefficient that is not a multiple of $p$. Writing $f(x) = a_0+a_1x+a_2x^2+\ldots$ and $g(x) = b_0+b_1x+b_2x^2+\ldots$, let $a_m$ be the first coefficient in the expression for $f(x)$ that is​ not a multiple of $p$; and similarly let $b_n$ be the first coefficient in the expression for $g(x)$ that is​ not a multiple of $p$. Then you can check that the coefficient of $x^{m+n}$ in $f(x)g(x)$ is not a multiple of $p$ and hence $f(x)g(x)\notin pR[x]$ – contradiction.
To see that $(R/pR)[x]$ is an integral domain, we must show that it has no zero-divisors. So suppose that $f(x),\ g(x)\in (R/pR)[x]$ with $f(x)g(x)=0$. Because the coefficient ring $R/pR$ has no zero-divisors, it follows (by considering the term of highest degree in the product) that the degree of $f(x)g(x)$ is $\deg(f) + \deg(g)$, which must therefore be 0. But then $f(x)$ and $g(x)$ are both constants, and (again because $R/pR$ has no zero-divisors) one of them must be $0$.
FAQ: Polynomial Rings - Gauss's Lemma
What is a polynomial ring?
A polynomial ring is a mathematical structure that consists of polynomials with coefficients from a given field or ring. It is denoted as R[x], where R is the underlying ring and x is the indeterminate variable.
What is Gauss's Lemma?
Gauss's Lemma is a theorem in algebra that states that if a polynomial in a polynomial ring with coefficients from a field can be factored into two polynomials with coefficients in the same field, then it can also be factored into two polynomials with coefficients in the original ring.
Why is Gauss's Lemma important?
Gauss's Lemma is important because it allows us to prove the irreducibility of a polynomial in a polynomial ring by factoring it into simpler polynomials with coefficients in a field. It also provides a useful tool for finding roots of polynomials.
What is the relationship between polynomial rings and polynomial functions?
Polynomial rings and polynomial functions are closely related. A polynomial function is a function that can be expressed as a polynomial, while a polynomial ring is a mathematical structure that consists of polynomials. Polynomial functions can be evaluated at specific values, while polynomials in a polynomial ring can be manipulated algebraically.
What are some applications of polynomial rings and Gauss's Lemma?
Polynomial rings and Gauss's Lemma have various applications in mathematics and other fields such as physics and engineering. They are used to study algebraic structures, solve equations, and model real-world phenomena. They are also essential in coding theory, cryptography, and error-correcting codes.
