MHB Polynomials and Roots: Properties and Analysis
  • Thread starter Thread starter mente oscura
    Polynomials Roots
The discussion focuses on the properties and analysis of polynomials and their roots. It introduces three polynomials: P(x), Q(x), and T(x), with roots that are shifted by -1 and +1 respectively. The sums of coefficients and alternate coefficients of these polynomials are calculated, revealing relationships between them based on the parity of their degree. An example polynomial is analyzed in detail, demonstrating how to derive new polynomials from existing ones by adjusting the roots. This method aids in understanding polynomial behavior and factorization.
mente oscura
Hello.
I open this 'thread', in number theory, but he also wears "calculation".
I've done a little research, I share with you.
Let \ r_1, r_2, \cdots, r_n, roots of the polynomial.
P(x)=p_0x^n+p_1x^{n-1}+ \cdots+p_{n-1}x+p_n
Let \ Q(x)=q_0 x^n+q_1x^{n-1}+ \cdots +q_n, such that its roots are:
r_1-1, r_2-1, \cdots, r_n-1
Let \ T(x)=t_0^n+t_1x^{n-1}+ \cdots +t_n, such that its roots are:
r_1+1, r_2+1, \cdots, r_n+1
I will assume:
p_0=q_0=t_0=1Therefore:
\displaystyle\sum_{i=0}^n(p_i)=q_n
and
\displaystyle\sum_{i=0}^n(p_i)(-1)^{i+1}=t_n, if “n” it's even.
\displaystyle\sum_{i=0}^n(p_i)(-1)^i=t_n, if “n” it's odd.
Also I have found how to calculate "complete", recurrently cited polynomials.
Example:
P(x)=x^9-33x^8+149x^7+4431x^6-45669x^5+9081x^4+1506119x^3-7038363x^2+12556936x-7987980
Sum of coefficients=-995328, addition and subtraction of alternate coefficients=-29030400
Roots:-11, -7, 2, 2, 3, 5, 7, 13, 19.Q(x)=x^9-24x^8-79x^7+4634x^6-17676x^5-149768x^4+1177824x^3-2853504x^2+2833920x-995328
Sum of coefficients=0, addition and subtraction of alternate coefficients=-7987980
Roots:-12, -8, 1, 1, 2, 4, 6, 12, 18.T(x)=x^9-42x^8+449x^7+2380x^6-67152x^5+296240x^4+931632x^3-10983168x^2+30862080x-29030400
Sum of coefficients=-7987980, addition and subtraction of alternate coefficients=-71442000
Roots:-10, -6, 3, 3, 4, 6, 8, 14, 20.
This procedure can be useful for the analysis of the possible roots of the polynomial, and its factorization.
Regards.
Mathematics news on Phys.org
Hello.
Continuing with the topic.
I'm going to show, with an example, as it would generate a polynomial, with the roots of the original polynomial, decreased in 1 unit:
1º) Separate term=Sum of coefficients of P(x)=-995328
2º) Coefficient of x:
\dfrac{P'(x)}{1}=9x^8-264x^7+1043x^6+26586x^5-228345x^4+36324x^3+4518357x^2-14076726x+12556936
Coefficient of x, the new polynomialQ(x)=Sum of coefficients \dfrac{P'(x)}{1}=2833920.
3º) Coefficient of x^2:
\dfrac{P''(x)}{2}=36x^7-924x^6+3129x^5+66465x^4-456690x^3+54486x^2+4518357x-7038363.
Sum of coefficients=-2853504.
4º) Coefficient of x^3:
\dfrac{P'''(x)}{3!}=84x^6-1848x^5+5215x^4+88620x^3-456690x^2+36324x+1506119.
Sum of coefficients=1177824.
5º) Coefficient of x^4:
\dfrac{P''''(x)}{4!}=126x^5-2310x^4+5215x^3+66465x^2-228345x+9081.
Sum of coefficients=-149768.
6º) Coefficient of x^5:
\dfrac{P'''''(x)}{5!}=126x^4-1848x^3+3129x^2+26586x-45669.
Sum of coefficients=-17676.
7º) Coefficient of x^6:
\dfrac{P''''''(x)}{6!}=84x^3-924x^2+1043x+4431.
Sum of coefficients=4634.
8º) Coefficient of x^7:
\dfrac{P'''''''(x)}{7!}=36x^2-264x+149
Sum of coefficients=-79.
9º) Coefficient of x^8:
\dfrac{P''''''''(x)}{8!}=9x-33
Sum of coefficients=-24.
10º) Coefficient of x^9:
\dfrac{P'''''''''(x)}{9!}=1.
Therefore, the resulting polynomial is:
Regards.
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
