Polytropic Process for an Ideal Gas
In summary, a polytropic process is one in which PV\gamma = constant. Assuming n is constant, this does not mean that the temperature remains constant. In fact, in most cases, the temperature will change during a polytropic process. This is because PV\gamma is equal to nrT only when \gamma = 1. In other cases, there is no simple relationship between PV\gamma and T. Therefore, a polytropic process does not imply that nRT is a constant, even when n is constant.
LunaFly
35
Hi,
I have a general question about polytropic processes when working with an ideal gas.
A polytropic process is one for which PV[itex]\gamma[/itex] = constant.
What I am wondering is if we assume that n is constant, does that mean that the temperature does not change for the process?
I see that PV[itex]\gamma[/itex] = nrT = constant, but for some reason it doesn't seem right that a polytropic process would be equivalent to an isothermal process if the number of moles of the system doesn't change.
A little light on the subject would be great.
Thanks,
-Luna
LunaFly said:
Hi,
No. A good example of such a process is adiabatic expansion/compression, for which ##T## changes.
That equation is only valid if ##\gamma = 1##. Otherwise, there is no simple relationship between ##PV^\gamma## and ##T##.
Ok this concept finally sunk in.
PV[itex]\gamma[/itex] does not equal nRT unless [itex]\gamma[/itex]=1. So a polytropic process in no way implies that nRT is a constant (even when n is constant).
DrClaude, thanks for the input!
Another thing to consider that might be helpful for your understanding:
Consider a process for an ideal gas where ##PV^\gamma = \textrm{const.}##. Using the ideal gas law, ##PV=nRT##, we have
\begin{align}
P_iV_i^\gamma &= P_fV_f^\gamma \\
\left( \frac{n R T_i}{V_i} \right) V_i^\gamma &= \left( \frac{n R T_f}{V_f} \right) V_f^\gamma \\
T_i V_i^{\gamma - 1} &= T_f V_f^{\gamma - 1}
\end{align}
or ##TV^{\gamma - 1} = \textrm{const.}##
Obviously, if ##V## changes during the process, then ##T## changes (except if ##\gamma = 1##).
Likes 1 person
Hello Luna,
Thank you for your question about polytropic processes for an ideal gas. To answer your question, assuming that n (number of moles) is constant does not necessarily mean that the temperature will not change during the process. This is because in a polytropic process, the value of \gamma can vary depending on the conditions of the process. \gamma is known as the polytropic index and it represents the relationship between pressure and volume during the process. In an isothermal process, \gamma is equal to 1, but in a polytropic process, it can have any value between 0 and \infty.
Therefore, even if n is constant, if the polytropic index \gamma is not equal to 1, then the temperature will change during the process. This is because the relationship between pressure and volume is not the same as an isothermal process, where \gamma is equal to 1 and therefore, the temperature remains constant.
I hope this helps clarify your understanding of polytropic processes for an ideal gas. Please let me know if you have any further questions.
Best,
FAQ: Polytropic Process for an Ideal Gas
What is a polytropic process?
A polytropic process is a type of thermodynamic process in which a gas undergoes a change in volume while its pressure remains constant. This process is often used to model the expansion or compression of gases in real-life situations.
What is an ideal gas?
An ideal gas is a theoretical gas that follows the gas laws perfectly, meaning it has no intermolecular forces and its particles have no volume. This allows for simpler calculations and is often used in thermodynamic analyses.
How is the polytropic process represented mathematically?
The polytropic process can be represented by the equation P1V1^n = P2V2^n, where P1 and V1 are the initial pressure and volume, P2 and V2 are the final pressure and volume, and n is the polytropic index, which represents the relationship between pressure and volume.
What is the significance of the polytropic index in a polytropic process?
The polytropic index, also known as the exponent of the process, determines the type of process that is occurring. If n = 1, the process is isothermal, if n = 0, the process is isobaric, and if n = γ = c_p/c_v (ratio of specific heats), the process is adiabatic.
What are some real-life applications of the polytropic process?
The polytropic process can be observed in various real-life situations, such as the expansion and compression of gases in internal combustion engines, the compression and expansion of air in refrigerators and air conditioners, and the compression of air in scuba tanks.
