Poor convergence using Fe HMOs for FMO in Gamess
In summary, the author is trying to model an interaction between ligands and a heme group, but the program cannot seem to converge on a solution.
WillCawdell
Hello!
I'm trying to model an interaction between ligands and a heme group using FMO in Gamess.
I've tried to make HMOs for the FMOBND section of the input file (using an Fe-F complex), the HMOs are shown below:
STO-3G 19 5
0 1 0.992624, 0.019366, 0.000000, 0.000000,-0.000001,-0.014838, 0.000000,
0.000000, 0.000004, 0.005535, 0.005534, 0.005534, 0.000000, 0.000000,
0.000000,-0.000595, 0.000000, 0.000000,-0.000029
1 0 0.420492,-1.033033, 0.000000, 0.000000,-0.000111,-0.314157, 0.000000,
0.000000, 0.000062, 0.110327, 0.111004, 0.109981,-0.000339, 0.000000,
0.000000,-0.010802, 0.000000, 0.000000,-0.000514
0 1 -0.000040, 0.000094, 0.000000, 0.000000,-0.990859, 0.000170, 0.000000,
0.000000,-0.026700,-0.000085,-0.000086,-0.000094, 0.000001, 0.000000,
0.000000, 0.000139, 0.000000, 0.000000, 0.002284
0 1 0.000000, 0.000000, 0.928325, 0.346200, 0.000000, 0.000000, 0.025225,
0.009407, 0.000000, 0.000000, 0.000000, 0.000000, 0.000000, 0.000008,
0.000003, 0.000000,-0.001955,-0.000729, 0.000000
0 1 0.000000, 0.000000,-0.346473, 0.929057, 0.000000, 0.000000,-0.008635,
0.023155, 0.000000, 0.000000, 0.000000, 0.000000, 0.000000,-0.000003,
0.000009, 0.000000, 0.000689,-0.001848, 0.000000
These HMOs work to a certain extent, allowing monomer calculations on the heme group, cysteine donor and my ligand donor to converge, however the value they converge to is oscillating between 2 points thus never converging according to Gamess. So the calculation cannot proceed to the dimer stage.
Does anyone have any ideas how to make my convergence better? U currently use DIIS as a start an initial convergence mode then switch to SOSCF to fine tune the convergence value
Thannks a lot in advance!
Caveat 1: I've never been great at solving SCF convergence problems, and I'm not sure anyone actually is. It's a bit of an art.
Caveat 2: I never really used GAMESS as extensively as some other QC programs, so I'm not as familiar with its syntax and its capabilities.
If your convergence value is oscillating between two points, it might be the case that the ground state and the first excited state are fairly close in energy, and the program can't decide which one is which. If you know which one is your ground state, and if its orbital occupation numbers are significantly different from the first excited state, you might be able to resolve the problem with a better initial guess. Absent that, you could try DIIS damping or turn off DIIS completely. This will take longer but might help convergence. Good luck.
Likes berkeman
Thanks a lot for your help! I agree convergence is a black art! I appreciate what you're saying about the ground and excited states I should have thought of that sooner! I think I'll try the DIIS changes you suggested! Thanks!
Likes jim mcnamara and TeethWhitener
I'll keep my fingers crossed for you. If that doesn't work, it's not a bad idea to poke around google or some of the QC program forums for advice on convergence problems.
FAQ: Poor convergence using Fe HMOs for FMO in Gamess
What is Fe HMO and FMO in Gamess?
Fe HMO stands for Ferrous Hybrid Molecular Orbital and FMO stands for Fragment Molecular Orbital. Gamess is a quantum chemistry software program used for computational chemistry calculations.
What is convergence in the context of Fe HMOs and FMOs in Gamess?
Convergence refers to the accuracy and stability of the results obtained from computational chemistry calculations. In the context of Fe HMOs and FMOs in Gamess, it refers to the ability of the calculations to reach a consistent and reliable solution.
Why is poor convergence a common issue when using Fe HMOs for FMO in Gamess?
Poor convergence can occur due to a variety of factors, such as improper settings, inadequate basis sets, or complex molecular systems. Fe HMOs for FMO in Gamess are known to have a higher likelihood of poor convergence due to the complexity and size of the systems being studied.
How can poor convergence be addressed when using Fe HMOs for FMO in Gamess?
There are several strategies that can be used to improve convergence when using Fe HMOs for FMO in Gamess. These include increasing the number of iterations, using a larger basis set, and adjusting the convergence criteria. It may also be helpful to consult with other researchers or experts in the field for advice.
Are there any alternative methods to Fe HMOs for FMO in Gamess that may provide better convergence?
Yes, there are alternative methods that can be used for FMO calculations in Gamess, such as density functional theory (DFT) or coupled cluster (CC) methods. These methods may provide better convergence for certain systems, but they also have their own limitations and considerations that should be taken into account.
