yairsuari
- 8
I am trying to deploy my oceanic model currently runing on ubuntu linux and compiled with intel fortran on a cray sv1 machine with UNICOS operating system.
It actually went quite well until i tried to read unformatted files. i am using the following code to export the data to the new machine:
file_name=trim(datafolder)//'basin'
open(21,file=file_name,status='old',
+ form='unformatted',convert='little_endian')
read(21)h,alat,alon,dx,dy
read(21)fsm,dum,dvm
read(21) z,zz
close(21)
file_name='~/Documents/temp/phys/data/basin'
open(21,file=file_name,status='new',
+ form='unformatted',convert='cray')
write(21)h,alat,alon,dx,dy
write(21)fsm,dum,dvm
write(21) z,zz
close(21)
When i copy the produced file to the new machine and try running the model i get the following error massage:
lib-5026 ./a.out: UNRECOVERABLE library error
The COS blocked file contains an invalid BCW (block control word).
Encountered during a sequential unformatted READ from unit 21
Fortran unit 21 is connected to a sequential unformatted COS blocked file:
"/users/negev1/biu/ysuari/prog/bfm_3dcode/phys/data/basin"
Error initiated at line 225 in routine '_rdunf'.
Abort
Beginning of Traceback:
Interrupt at address 377677a in routine '_lwp_killm'.
Called from line 32 (address 374366a) in routine 'raise'.
Called from line 127 (address 302611d) in routine 'abort'.
Called from line 59 (address 704047a) in routine '_ferr'.
Called from line 225 (address 735714c) in routine '_rdunf'.
Called from line 357 (address 676525a) in routine '_xfer_iolist'.
Called from line 147 (address 742423c) in routine '_FRU'.
Called from line 6347 (address 110006b) in routine 'BASIN'.
Called from line 789 (address 2575a) in routine 'POM2K'.
Called from line 350 (address 324455c) in routine '$START$'.
End of Traceback.
IOT trap (core dumped)
the error is explained as:
A Fortran I/O or positioning operation or an FFIO() operation on a COS
blocked file encountered a BCW (block control word) that is not valid. The
file may not be a COS blocked file, or it may be corrupted.
Ensure that the file is COS blocked; if it is not, use the appropriate
specification on the assign(1) or asgcmd(1) command. If the file is
corrupted, re-create it if possible.
even after reading the section about the assign command this error massage is like Chinese to me.
does anyone know how the file migration should be done?
thanks yair
read(21)fsm,dum,dvm
read(21) z,zz
close(21)
write(21) z,zz
close(21)
Abort
End of Traceback.
thanks yair
