Position is no more an operator in QFT
In summary, there is a position operator in local relativistic quantum field theory, but not in non-relativistic quantum theory.
Heidi
418
40
In quantum mechanics there is no operator for time (problem with unbounded energy).
position is no more an operator in field theory. was there still a problem in QM?
Say there are many particles of same kind, position lose its meaning and number density takes its palce.
In general there is no position operator in relativistic quantum theory, at least not within the only kind of relativistic QT that's successful in describing the real world in terms of the Standard Model, which is local relativistic QFT.
However, for all massive particles you can define a position operator having the usual properties. Since only massive particles have a useful non-relativistic limit, there is no contradiction between having a position operator in non-relativistic quantum theory and local relativistic QFT.
The representations of the Galilei group for massless particles doesn't lead to a physically interpretable quantum theory. See also my comment on this here:
https://www.physicsforums.com/threa...r-the-gravitational-field.997062/post-6433476
Likes Heidi
Is there a position operator in QFT? The question does not make sense until one defines what exactly one means by "position operator". There is operator that satisfies some properties one would expect from a decent position operator, but not all. In particular, the Newton-Wigner position operator does not transform as a Lorentz vector.
Likes vanhees71
I was referring to the usual definition of position operators, as explained in
https://arnold-neumaier.at/physfaq/topics/position.html
It's of course not part of Lorentz four-vector operator, because otherwise time would be an operator too, but that cannot be by construction, because the energy spectrum is bounded from below.
Position in relativistic physics is an interesting thing. It happens that the classical position operator IS a Newton-Wigner operator and, also, does-not transform as a 4-vector (can't give a reference, is still in peer review).
Moreover, I think the Newton-Wigner position function (https://arxiv.org/abs/2004.09723) of Hamiltonian mechanics has the same property, though I'm not sure, I haven't read the article in full details.
Likes vanhees71 and Demystifier
FAQ: Position is no more an operator in QFT
1. What is the significance of position in quantum field theory (QFT)?
In QFT, position is no longer considered an operator as it is in classical mechanics. This is because the position of a particle in QFT is described by a wave function, which is a mathematical representation of the probability of finding a particle at a certain position. Therefore, the concept of a fixed position for a particle is no longer applicable in QFT.
2. How does this differ from the classical understanding of position?
In classical mechanics, position is considered a measurable quantity that is independent of the observer. However, in QFT, the position of a particle is described by a wave function that is dependent on the observer's frame of reference. This means that the position of a particle can vary depending on the observer's perspective, making it a more abstract concept in QFT.
3. Why is it important to understand that position is not an operator in QFT?
Understanding that position is not an operator in QFT is crucial for accurately describing the behavior of particles at the quantum level. It allows us to better understand the probabilistic nature of particles and how they interact with each other. It also helps us to reconcile the discrepancies between classical mechanics and quantum mechanics.
4. Does this mean that the concept of position is irrelevant in QFT?
No, the concept of position is still relevant in QFT, but it is described in a different way compared to classical mechanics. While position is no longer an operator, it is still a fundamental property of particles and is used in various calculations and equations in QFT.
5. Are there any other operators in QFT that behave similarly to position?
Yes, there are other operators in QFT that behave similarly to position, such as momentum and energy. These operators also have a probabilistic nature and are described by wave functions, rather than being fixed quantities like in classical mechanics.
